I'm going to start training for Hi-perfromance aircraft. The plane is a 182.
I'm trying to locate info on the net that relate to hi perfromance and constant speed props. Any suggestions? TIA, Chris |
There's not much to learn. How much ? Here it is -
Manifold pressure is your power instrument, adjust it with your throttle knob. RPM is adjusted with the prop knob which is the blue one. Prop knob goes all the way forward for takeoff and landing, bring it back a little in cruise to set the RPM based on the POH performance you want. There, you've just learned 90% of what you need to know for the 182. Work on the details with your instructor for your plane's specifics, like what to do differently on the runup check. I'm going to start training for Hi-perfromance aircraft. The plane is a 182. I'm trying to locate info on the net that relate to hi perfromance and constant speed props. Any suggestions? |
Any suggestions?
Check out John Deakin's articles on Avweb. Manifold Pressure Sucks, Those Marvelous Props. |
Gene Whitts site has an extensive article on stepping up to a 182.
www.whittsflying.com or google for Cessna 182 transition training Jim "Chris Gumm" cmgummATcinciDOTrrDOTcom wrote in message ... I'm going to start training for Hi-perfromance aircraft. The plane is a 182. I'm trying to locate info on the net that relate to hi perfromance and constant speed props. Any suggestions? TIA, Chris |
Get yourself an operating handbook for the model you intend to
fly. Read and understand the "operations", "limitations", and the "checklist" items before you ever get in the airplane. If by reading the manual you generate questions, ask your instructor to explain before flying. MikeM 2700 hrs in Skylane '1MM Chris Gumm wrote: I'm going to start training for Hi-perfromance aircraft. The plane is a 182. I'm trying to locate info on the net that relate to hi perfromance and constant speed props. Any suggestions? TIA, Chris |
I'm still a student but I bought a 182 for my own. The transition from a 172
(or SP) is a piece of cake. Speeds are a little higher, the constant speed prop is no sweat, and the extra power . . . oh! How I love the extra power! I'll never go back. Chuckster41 "Chris Gumm" cmgummATcinciDOTrrDOTcom wrote in message ... I'm going to start training for Hi-perfromance aircraft. The plane is a 182. I'm trying to locate info on the net that relate to hi perfromance and constant speed props. Any suggestions? TIA, Chris |
That's my next step (getting a HP/complex endorsement), but I need to find
another FBO and don't have the time right now. So, the next best thing I did was to take the "Commercial Pilot" lessons in "Microsoft Flight Simulator 2004" which has a pretty good overview (for a beginner at least) of what flying high-performance/complex is all about. It's pretty basic so you may already know this stuff, but as an initial overview, it's great -- the initial FS2004 lesson discusses manifold pressure, the prop governor, and procedures for operating them and the retractable gear. Just FYI, in case you have FS2004 "Chris Gumm" cmgummATcinciDOTrrDOTcom wrote in message ... I'm going to start training for Hi-perfromance aircraft. The plane is a 182. I'm trying to locate info on the net that relate to hi perfromance and constant speed props. Any suggestions? TIA, Chris |
| Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 09:04 AM |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| High Performance Single Engine Choices | O. Sami Saydjari | Owning | 82 | January 6th 04 08:32 PM |
| More on High Performance Insurance | Jay Honeck | Owning | 25 | December 15th 03 04:24 AM |
| High performance homebuilt in the UK | NigelPocock | Home Built | 0 | August 18th 03 09:35 PM |
