Uplink weather advice
Old August 10th 03, 03:19 PM
Richard Kaplan
Default Uplink weather advice
If you are planning to invest in an installed system then I agree the WSI
system is the best at this point. It is a "transmission" rather than
"request" system so therefore you can get continually updated weather data.
Even more importantly, WSI is an extremely well-established entity in the
weather data industry and therefore it is quite likely they will remain
around for the foreseeable future. Even more importantly, the data
displayed on their weather datalink system is basically the same data as you
can get on the web via www.intellicast.com so the learning curve to learn
how to interpret the data will be much less than with the other panel-mount
datalink providers.
I know of a client/student of mine who uses this system regularly and has
been very pleased, and I saw it installed in another student's plane and he
was similarly pleased with it.
Frankly, if I were to put an installed datalink system in my airplane at
this point then I would be most interested in the WSI system but the main
reason I have not done so yet is because I have an RDR-160 radar system in
my plane and the only current multi-function display which can interface
with that radar is the Avidyne display.
Richard Kaplan, CFII
www.flyimc.com
Old August 10th 03, 03:38 PM
Dan Luke
data.
What, in your opinion, makes this system superior to Bendix/King's KMD 250,
KDR 510 uplink system? Both are transmission systems, one satellite, one
ground, how do they compare otherwise?
I was pleasantly surprised by B/K's system at OSH. It seemed easy to use and
the update speed ane resolution were very good. Its high baud rate seemed to
eliminate some of the software funny business that satellite based systems
resort to for getting images through their limited bandwith.
Dan
C172RG at BFM
Old August 10th 03, 04:18 PM
Dan Luke
One of the main problems with the Bendix/King system is that since it is
ground-based, in many situations you cannot use it to get a weather
before takeoff or at "low" altitude ("low" depending on how near a
transmission station is to where you are flying, of course). So it might
not be available when you really want to use it.
Yes, that is a disadvantage of their system. But it looks like WSI's map is
not a moving map that will show the position and direction of the aircraft,
a big disadvantage, IMO - is that true?
Another nice feature of the WSI system is that the data is the same as
what
you see on the Internet at www.intellicast.com and it is also the same
data
most of us see at FBOs across the country -- please correct me if I am
wrong, but I do not think there is an Internet site to view the data in
Bendix/King system.
This is important because there is a learning curve in
any radar or Nexrad system to learn how to interpret the graphics from the
perspective of "Am I willing to fly thorugh that?" Most of us are
already
quite familiar with radar images from Intellicast or from WSI computers at
FBOs. With the Bendix/King system, you may not even be able to turn on
your avionics on the ground to work through this learning curve.
They have the brochure on line at
http://www.bendixking.com/static/bro...pdf/KDR510.pdf which shows the
MFD depicting NEXRAD base reflectivity. Looks just like what I see on
Intellicast. The unit also gives graphic METARS, etc.
My main concern about the satellite systems is still the bandwith question.
B/K had a pretty convincing demonstration of how other venders'
bandwith-saving software tricks could cause innacurate weather images. Also,
due to limited bandwidth, map resolution was not as good on the satellite
systems.
Dan
C172RG at BFM
Old August 10th 03, 04:44 PM
Richard Kaplan
"Dan Luke" wrote in message
is
aircraft,
That is true if you use a laptop as the display for the WSI system -- then
then again, a laptop is not even a display option for the Bendix/King
system.
If you connect the WSI system to an MFD then the MFD already has your
position on the map.
NEXRAD base reflectivity is the raw data from each data site; weather
datalink vendors then merge this data to create a composite national or
regional image. There is quite a bit of proprietary digital image
processing involved -- that is why, for example, weather on
www.intellicast.com looks different from weather on
www.theweatherchannel.com etc. The color coding can be different, some
vendors may choose to delete returns under 10dB or under 15dB, and some
vendors have different processes to remove ground clutter by either manual
or automated techniques.
The bottom line is that for the critical decision of deciding whether a
given area of Level 3 weather is convective or benign, it is a big help to
have experience with that particular source of weather data. The WSI system
lets you learn about their image processing on the ground via the Internet;
the Bendix/King system only lets you learn by trial-and-error in the air.
question.
Also,
I saw the demonstration too, and my impression was that this degree of
accuracy only mattered to a turboprop or jet pilot attempting to penetrate a
line of thunderstorms, in which case he ought to have high-power vertical
profiling radar as well -- not an issue likely to be relevant to most of the
piston IFR pilots on this group, myself included. Far more important to me
is the ability to get an accurate view of the weather on the ground before
takeoff and in the initial climb segment of my flight... the Bendix/King
system may be more accurate, but its data is simply unavailable for these
important portions of flight or during flight planning. If I can plan
early and request a routing to give me a good margin around the weather,
then it really does not matter if my image has slightly less resolution
compared with an alternate system which only works above a given altitude.
One of the best advantages of weather datalink is the ability to depart from
a small airport which has no weather resources and be able to make a
pre-flight decision on flying around/through areas of convective activity.
A satellite-based system such as WSI works great for this purpose at any
airport; the Bendix/King system will often be completely unavailable on the
ground in the same situation.
www.flyimc.com
Old August 11th 03, 01:23 AM
Tom S.
"Richard Kaplan" wrote in message
news:0c9eb7ec245c44683f14df2697f2042c@TeraNews...
250,
what
data
Bendix/King system. This is important because there is a learning curve
in
How is it (Nexrad) different?
Most of us are already
I suspect the Garmin 400/500 series with a GDL49 uplink and a subscription
to EchoFlight would be more expensive?? Or EchoFlight with their Flight
Cheetah?
http://www.garmin.com/products/gdl49/
http://www.echoflight.com/data_link.html
Old August 11th 03, 02:15 AM
Richard Kaplan
"Tom S." wrote in message
Nexrad and radar are similar but Nexrad is better than radar at showing
intensities inside a given storm cell.
An isolated radar or Nexrad site base reflectivity return shows ground
clutter and other artifacts. For example, radar and Nexrad get less
sensitive at the fringes of a given radar site's coverage area.
When we talk of "Nexrad" we are usually talking about the composite national
Nexrad image. That image is created by digitally processing the images from
multiple sites into a national mosaic -- this process is usually partly
automated and partly done manually, but in any event there is some
subjectivity involved.
The end result is that a composite Nexrad image usually is easier to
interpret than comparing isolated radar sites. And Nexrad weather datalink
allows a pilot to view the big picture of the whole country rather than just
the coverage area of an airplane's onboard radar.
The primary disadvantage of Nexrad composite images compared with onboard
radar is that Nexrad provides no information regarding how high the
reflected precip goes. So what appears as precip on Nexrad may really be
no more than low-level mist; I have seen this often in flight.
Airplane-mounted radar does not have nearly the range of composite Nexrad
but does have the advantage that the pilot can tilt the radar's energy up or
down and thus -- with training -- calculate how high precipitation goes.
There is a solution to the problem of calculating Nexrad precip heights --
NOAA maintains a national network of doppler precip tops radar.
Unfortunately this government-generated precip tops radar data is not
available to FSS (!), but several subscription websites and some of the
weather datalink vendors do indeed have make available the precip tops radar
data.
www.flyimc.com
Old August 11th 03, 03:40 AM
Mark T. Mueller
The GDL49 / EchoFlight solutions are actually much less expensive that
either WSI or the XM/WxWorx systems. However, after considerable research, I
have concluded the GDL49 is not currently a viable solution for me. The
download rate is an anemic 2800 baud, and the data resolution is in the 4 -
10 km range, far to coarse to make any but the most basic strategic weather
decisions. There is also the issue with the VHF band used for the datalink
is VERY close to your Com bands, so I have heard some grumblings about bad
installs and interference with the datalink from Com (i.e. don't key the
mike if you are trying to get wx data...) I have also heard horror stories
about data age and delays in the request/receive. No other system is
compatible with the 430/530 at this time. I have personally written off this
technology unless Garmin figures out a better compression scheme and they
solve the interference and data age problem.
Notice that Garmin has opted for the WxWorx/XM Radio solution for their new,
high dollar G1000 system, the GDL49 wasn't considered.
WSI certified boxes run in the $5K range plus install. I still cannot
understand how you can mount an "uncertified" box on an aircraft without an
STC or 337 approval. You will need an additional antenna, and cable runs.
WxWorx claims to have a "portable" system, but I still think you need one of
their antennas mounted and cables run, so as far as a "less expensive"
system, I doubt it.
All the "broadcast" systems to date have been in the $50/month range.
Echoflight has three different subscription plans, I think it was in the
$40/month range.
The King system using ground based towers has huge holes in coverage,
especially where I tend to fly, so it is useless for me, and I doubt a
ground based system will ever have utility for me.
The technology is here for quality broadcast weather, but it still looks
like it will be some time before a truely portable or certified system at a
reasonable cost is available. It really surprises me that I bought a Sirius
Satellite Radio for $100 that is 100% portable (including antenna that sits
on my glareshield) and plugs into my music jack and lighter outlet and pay
$12/month for 100 channels, but I can't get a 100% portable wx broadcast
system, and still have to shell out over $4K+ $50/month!!!! About the only
thing on the market that is reasonable and functional at the moment appears
to be AnywhereWx using a Globalstar sat phone, but there are issues with
interference from some models of the KT76 transponder.
Looks like it will be another year or two...
250,
one
might
what
data
in
at
Cheetah?
Old August 11th 03, 04:05 AM
Richard Kaplan
"Mark T. Mueller" wrote in message
I
The portable XM/WxWorx system is MUCH cheaper (well, cheaper if I presume
you already own a laptop computer).. The system costs between $650 and $850
for the hardware plus $49/month for the subscription. The downside is that
there are lots of wires to carry around; the upside is that it is portable.
of
No, the antenna can go right on the glareshield just like a portable GPS
antenna.
a
I agree there are some practical issues to the XMRadio/WxWorx system, but it
is indeed portable. My thought is that on the days when I know there will
be convective weather, it is worth putting up with the wires in order to
make the flight, but I suspect I will not use the system on non-convective
days.
appears
XM/WxWorx is notably cheaper and definitely more practical than AnywhereWx
with a sat phone. AnywhereWx has just as many wires and it is a
reply/request model. One really nice feature of XM/WxWorx is that you can
"set it and forget it" -- once you set it up before flight, just glance at
the laptop every 5 minutes or so and the automatically updated weather will
be there. The hard part of the technology is there (satellite reception)...
I just wish they would combine the battery/display/receiver all into one box
like a portable GPS.
www.flyimc.com
Old August 11th 03, 11:19 AM
Mark T. Mueller
$850
that
portable.
WOW! That's much less than I had heard. IF they actually MSRP for that,
EchoFlight is DEAD, and WSI will have to reduce the cost of their box and
make it up on the subscriptions...
Any idea when the WxWorx boxes will be available? I am ready now!
antenna.
I must have missed that one at OSH. The WxWorx reps were showing me
different antenna options, and a puck to throw on the glareshield was not
one of them. However, I would probably go for the COMDAT mast that combines
the XM and VHF Com into a single antenna. Cleaner install, and one for one
replacement on my turtleback. Hopefully Garmin will get its head out of its
ass and port this thing to the 430/530.
it
days.
I hope they work them out in short order. I would use it just about anytime.
My current plans are to drop a serial connection to my 530 so I can plug a
Fujitsu 4121 Tablet PC for GPS, then pull the WxWorx into the Tablet. The
4121 is daylight readable, and I can also use it as a "laptop" for work...
Flightprep offers subscriptions for pdf approach plates, and it would be a
great backup for that as well.
will
reception)...
box
Thanks for the updates. I am sure SOMEONE will produce an integrated
solution that can be plugged into a laptop or Tablet PC... God knows the
market is there. The lines at OSH for all of the current providers was quite
long.
www.flyimc.com
Old August 11th 03, 02:23 PM
James M. Knox
I bought a Sirius Satellite Radio for $100 that is 100% portable
(including antenna that sits on my glareshield) and plugs into my
music jack and lighter outlet and pay $12/month for 100 channels, but
I can't get a 100% portable wx broadcast system, and still have to
It needs a driver, and aviation isn't it. [The airlines don't care much -
heck, most of them don't have GPS yet; and there just aren't all that many
dollars in GA.] My big hope is the same as for GPS - the marine and sports
market. There are enough coastal small boats without weather radar to
force some competition. If they get interested, then we will see those
$200 portable color weather receiver/displays.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Ice meteors, climate, sceptics Brian Sandle General Aviation 43 February 24th 04 12:27 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
Uplink weather advice Richard Kaplan Instrument Flight Rules 15 August 31st 03 11:39 PM
Uplink weather advice Richard Kaplan Owning 14 August 31st 03 11:39 PM
Uplink weather advice Klein Gilhousen Owning 0 August 12th 03 05:59 PM
