Hi!
The other day I was flying in to Haugesund Karmoy (ENHD) on the west coast of Norway. The wind was 17 kts with 27 kts gust 30 degrees down the runway. I was flying an Arrow 180 with the old herskey bar wings. Normally final approach is done at 90 mph. However, in this wind I put on between 10-15 extra knots for safety. It worked out well, although the long final was interesting to say the least....the plane was jumping around madly, but never too scary, just glad I was alone in the plane without any scared passenger.... About 50 feet over ground, the riot calmed down, and landing was a non event. However, the crosswind component was still evident, so I landed in a slip to compensate. What do you other guys do in such a situation? Just put son some more speed and fly "normal", or do you still keep the numbers? (not such a good idea considering the gusts...) Frode P28R-180 LN-LMR |
Hi Frode
Add airspeed for gusts. Otherwise just nail the appropriate numbers. Get the aircraft's momentum pointed right down the center of the runway; it wants to stay that way. Coordinated flight in the approach, slip in the flare. Since I've been driving a P Baron (120 knot approach, 105 knots over the numbers) it doesn't matter much. But I have flown a 172 in 35 knot winds without incident. Or much pleasure. Blue skies. H. N502TB "Frode Berg" wrote in message ... Hi! The other day I was flying in to Haugesund Karmoy (ENHD) on the west coast of Norway. The wind was 17 kts with 27 kts gust 30 degrees down the runway. I was flying an Arrow 180 with the old herskey bar wings. Normally final approach is done at 90 mph. However, in this wind I put on between 10-15 extra knots for safety. It worked out well, although the long final was interesting to say the least....the plane was jumping around madly, but never too scary, just glad I was alone in the plane without any scared passenger.... About 50 feet over ground, the riot calmed down, and landing was a non event. However, the crosswind component was still evident, so I landed in a slip to compensate. What do you other guys do in such a situation? Just put son some more speed and fly "normal", or do you still keep the numbers? (not such a good idea considering the gusts...) Frode P28R-180 LN-LMR |
... The wind was 17 kts with 27 kts gust 30 degrees down the runway. What do you other guys do in such a situation? Just put son some more speed and fly "normal", or do you still keep the numbers? (not such a good idea considering the gusts...) I add a gust factor, reduce the flaps, and aim for the centerline. Flying a taildragger, I get 'pumped' or 'psyched' for the approach. In other words, I try to be extra alert, quick on the controls, and extra vigilant. I normally try to fly in a slip starting on short final. Perhaps not the optimal technique but it allows me to get comfortable with the slip picture and to 'warm up' the cross controls required. About 50 feet over ground, the riot calmed down, and landing was a non event. However, the crosswind component was still evident, so I landed in a slip to compensate. By flying short final in a slip, it allowed me to discover what you seemed to have discovered too. While 30 knots at 90 degrees exceeds my ability to keep it straight with the rudder, once I descended to within 10 feet or so of the runway, the wind often decreases enough for my rudder authority to catch up and allow me to get it straight. The 2 times that happened, I was a second away from an abort and a trip to another airport. While I work hard to keep it on the centerline while landing, I will use the width of wider runways to reduce the xwind component on takeoff. |
... What do you other guys do in such a situation? Just put son some more speed and fly "normal", or do you still keep the numbers? Your approach sounds typical, though with a little more airspeed than most people would use (normal final approach as well as your gust correction). A standard procedure, one I use, is to add half the gust to your approach speed (in your case, 17G27 means a 10 knot gust, so add 5 knots to your airspeed...you're flying mph, but 5 knots is close enough to 5 mph for this purpose ).Stay on top of things, but don't fight the plane too much. More often than not, if a gust tips the plane one way, another gust will come along shortly to put you back where you were. I'll give the plane at least a half-second to a second before making any large corrective actions, though I will still make minor adjustments to keep the airplane aligned with the runway, on centerline. It's a bit of an art, controlling the plane to keep yourself in the right place without controlling it so much that you are fighting the airplane the whole way down. Generally speaking though, the less work you do, and the more work you let the plane do, the better off you'll be. In a C172, I use less flaps in a strong headwind. The reason being that flaps and a headwind both steepen your approach. I like my descent angles on final to be as "normal" as possible (i.e. same way every time), so in a headwind, you can either add power or reduce flaps. I prefer reducing flaps and flying my usual gliding approach. One note about airspeed on final: if you do find yourself in a similar situation with passengers, a consideration, assuming no other priorities conflict (such as a very short runway, for example), you might consider flying final at a higher airspeed than normal, so as minimize the time spent on final. A nervous passenger may well be just that much worse in gusty, bumpy conditions when they've got 50% longer on final to think about it. Obviously, you wouldn't do this all the way down to the runway, but maybe up to a half-mile final or so would be okay, IMHO. Pete |
On 15 Aug 2003 15:00:58 -0700, John Galban wrote:
Having the FBO guys act as mobile tiedowns is a fairly regular occurance at for high-wing pilots at some of the windier airports out west. It used to happen to me all the time when I was flying Cessnas. Since I started flying a Cherokee, it hasn't happened once. There's something to be said for a low center of gravity and a wide gear stance. If you compare a C172 with a Cherokee, you'll find the gear track is actually pretty similar. There's nothing to grab hold of on a low wing so they just leave you to it. Also, the Cherokee has steering system better suited to high winds. (I believe the C172 has springs/bungees linking the nosewheel steering, the Cherokee has a 'solid' linkage). My problem was that with the wind strength plus a tailwheel, the weathervaning tendency is just too strong. My tailwheel steering was provided by springs up to a certain limit, and then it goes into free castor if you jab the brake. Trouble is, this system doesn't work terribly well taxiing crosswind in a high wind, since the weathervaning tendency will overcome the power of the springs (and might even cause the tailwheel to come out of the detent and castor, at which point you're basically buggered from a steering point of view!) -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
"Dylan Smith" wrote in message If you compare a C172 with a Cherokee, you'll find the gear track is actually pretty similar. There's nothing to grab hold of on a low wing so they just leave you to it. Also, the Cherokee has steering system better suited to high winds. (I believe the C172 has springs/bungees linking the nosewheel steering, the Cherokee has a 'solid' linkage). My problem was that with the wind strength plus a tailwheel, the weathervaning tendency is just too strong. My tailwheel steering was provided by springs up to a certain limit, and then it goes into free castor if you jab the brake. Trouble is, this system doesn't work terribly well taxiing crosswind in a high wind, since the weathervaning tendency will overcome the power of the springs (and might even cause the tailwheel to come out of the detent and castor, at which point you're basically buggered from a steering point of view!) If you have effective brakes differential braking works if the tailwheel is free to caster or locked. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Hi! The other day I was flying in to Haugesund Karmoy (ENHD) on the west coast of Norway. The wind was 17 kts with 27 kts gust 30 degrees down the runway. I was flying an Arrow 180 with the old herskey bar wings. Normally final approach is done at 90 mph. However, in this wind I put on between 10-15 extra knots for safety. Caveat: I don't fly an Arrow with hershey bar wings. AFAIK, I fly a plane whose stall speed is *higher* than an Arrow's. 90 mph sounds quite high for normal final approach esp. w/ just you in the plane, assuming your stall speed is similar to or lower than mine. I target final approach at 80 mph, 75 if it's just me and partial fuel. I add 1/2 the gust factor as a rule of thumb ie 17 g 27 would add ~5 kts. JMO, but I don't think it adds to safety to put on too much extra speed. If it's really nasty and swirly near the ground, it just extends the time you have to spend in ground effect bleeding off extra speed. Why do you feel it's necessary, or safer, to add 10 to 15 kts to an approach speed which already sounds rather fast? Cheers, Sydney |
Snowbird wrote:
AFAIK, I fly a plane whose stall speed is *higher* than an Arrow's. 90 mph sounds quite high for normal final approach esp. w/ just you in the plane, assuming your stall speed is similar to or lower than mine. I target final approach at 80 mph, 75 if it's just me and partial fuel. I add 1/2 the gust factor as a rule of thumb ie 17 g 27 would add ~5 kts. JMO, but I don't think it adds to safety to put on too much extra speed. If it's really nasty and swirly near the ground, it just extends the time you have to spend in ground effect bleeding off extra speed. Why do you feel it's necessary, or safer, to add 10 to 15 kts to an approach speed which already sounds rather fast? Note thaty the original poster stated airspeed in MILES PER HOUR not knots. 90 MPH is about 75 kts, which is okay. The Arrow has a healthy sink rate the requires some extra speed initially to keep the sink rate below 500 fpm. |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
| High Flight NOTAM | Kirk Stant | Military Aviation | 1 | September 10th 03 04:31 AM |
