Spanaway crash
Old October 20th 03, 10:11 PM
John Galban
Newps wrote in message news:YYRkb.837091$uu5.148275@sccrnsc04...
Ben Jackson wrote:
Another plane was on the runway.
I don't get it. Land the damn plane. Move to one side or the other,
whatever.
Yep. That's where parallel taxiways come in handy. Looks like SPB
has two of them.
Old October 20th 03, 11:09 PM
David H
whatever.
has two of them.
Indeed. Scappoose has no shortage of available concrete - a long, wide runway, two good
sized parallel taxiways, some decent sized ramps, and it sits surrounded by large, flat,
open fields. Sure, there are some trees here and there and an occasional
fence/road/structure nearby - it's not quite the Bonneville Salt Flats - but if you were
going to come down someplace, this is a pretty forgiving location with lots of options
available. Heck, the taxiways there are a lot better than plenty of runways I've landed
on.
David H
Boeing Field (BFI), Seattle, WA
Visit the Pacific Northwest Flying forum:
http://www.smartgroups.com/groups/pnwflying
Old October 21st 03, 12:23 AM
Bob Gardner
I can't put myself in the place of a military pilot because I have never
flown anything that heavy or with that much power. Sad stories, both, and my
civil jet experience just doesn't match up. Carrier pilots are a breed
apart...I salute them.
Bob Gardner
"Big John" wrote in message
Lost a good friend on SE. Commander of Vermont ANG F-89 Squadron.
Had and engine explode and was cleared to land SE. Another Aircraft
(civilian on joint use airport) pulled on R/W without clearance and he
took it around SE. On downwid the bird blew up killing both him and
his Radar Observer.
Also lost a very good friend trying to come aboard the carrier in a
F2H3 on SE, but that's another story.
Big John
On Mon, 20 Oct 2003 15:24:01 GMT, "Bob Gardner"
When you get your twin rating, Ben, and I know that you will, remember
this:
Below 200 feet with an engine out, put it down somewhere...anywhere...do
not
even think of going around.
Bob Gardner
"Ben Jackson" wrote in message
news:VrLkb.827648$Ho3.232592@sccrnsc03...
Chris Hoffmann wrote:
A guy's got an engine out, and he has to go around? Is this normal, or
was
there some ball-dropping involved?
Ben Jackson
http://www.ben.com/
Old October 21st 03, 03:59 AM
Big John
Bob
You go to lots of funerals.
Navy Sq I was with had 13 pilots. Killed four before Sq went aboard
the Yorktown to go to WestPac.
You always say, "it won't happend to me" and go fly.
Big John
On Mon, 20 Oct 2003 23:23:29 GMT, "Bob Gardner"
Bob Gardner
his Radar Observer.
Big John
this:
not
Bob Gardner
was
Ben Jackson
http://www.ben.com/
Old October 21st 03, 05:53 AM
Robert Perkins
On Mon, 20 Oct 2003 05:39:55 GMT, "Chris Hoffmann"
A guy's got an engine out, and he has to go around? Is this normal, or was
Scappoose is uncontrolled and *busy*. Not as busy as Aurora State a
bit further south, but still, I haven't been in there at any time in
the last year when there wasn't at least one other aircraft in the
pattern.
Folks are right, tho. You can put a light single down on the taxiway,
there's flat grass on the field, and there shouldn't have been a go
around.
I haven't seen more than a blurb on the radio news and a three
paragraph thing on oregonlive.com. Any better place to go for a report
on the Scappoose accident?
Rob
[You] don't make your kids P.C.-proof by keeping them
ignorant, you do it by helping them learn how to
educate themselves.
-- Orson Scott Card
Old October 21st 03, 05:45 PM
Chris Hoffmann
http://www.kgw.com/news-local/storie...ash.17360595.h
tml
This from KGW, the site requires registration.
SCAPPOOSE, Ore. -- A preliminary report from the National Transportation
Safety Board says investigators don't know why a small plane crashed in
Scappoose last weekend, killing everyone on board.
The Cessna 340 crashed near the Scappoose Airport late Saturday afternoon
and burst into flames.
Columbia County authorities Monday identified the victims as James
Gillespie, 72, and Jessie Gillespie, 73, of the Steilacom, Wash. area. The
relationship of the victims was not immediately clear.
Federal aviation records indicate that James Gillespie, an accomplished
pilot registered as a flight instructor, owned the plane.
NTSB investigators spent much of Sunday sifting through the plane's charred
wreckage. They said witnesses are providing clues to what may have happened.
Witnesses said that as the Cessna was about to land, another plane took off
from the same runway. The Cessna's pilot then decided to go back around to
again attempt landing.
The plane crashed in a field near the intersection of Moore and Ring-a-ring
Road, northeast of the airport.
NTSB investigator Debra Eckrote said everything appeared normal until the
Cessna's pilot turned back toward the airport.
"It then started to lose altitude as it completed not quite a 180-degree
turn and then the witness saw that the nose dropped, the left wing
dropped.it started an inverted altitude," said Eckrote.
It is not known whether the two pilots were communicating. Scappoose Airport
is uncontrolled, meaning pilots are not required to communicate with one
another in the airfield.
Chris Hoffmann
Student Pilot @ UES
40 hours
Old October 21st 03, 09:07 PM
Robert Perkins
On Tue, 21 Oct 2003 16:45:57 GMT, "Chris Hoffmann"
(from the KGW report)
News to me. I thought the regs stated that if you had a radio, you had
to use it.
The KEX radio report I heard the following Monday reported "The pilot
was under 'visual flight rules' which means he was flying by reference
to what he could see, rather than using the onboard instruments."
(And to think, I spend time in every pattern looking at that
altimeter...)
Clearly most reporters need to get the *&^&*%^%^& out of aviation
reporting.
Rob
educate themselves.
-- Orson Scott Card
Old October 22nd 03, 05:03 AM
Newps
to use it.
No, the radio is optional.
That's accurate.
Old October 22nd 03, 07:20 PM
Snowbird
Robert Perkins wrote in message . ..
to use it.
Would you mind sharing with us what regulation
says this?
Thanks,
Sydney
Homebuilt Airplane Crash Harry O Home Built 1 November 15th 04 03:40 AM
Bizzare findings of Flight 93 crash in PA on 9-11 Laura Bush murdered her boy friend Military Aviation 38 April 12th 04 08:10 PM
AF investigators cite pilot error in fighter crash Otis Willie Military Aviation 0 January 9th 04 09:55 PM
Homemade plane crash Big John Home Built 9 October 17th 03 06:45 PM
1956 Valiant crash at Southwick, UK Nick Pedley Military Aviation 3 July 21st 03 08:05 PM
