SoCal TRACON, Montgomery Field Tower Evacuated.
Old October 27th 03, 02:09 AM
Larry Dighera
Default SoCal TRACON, Montgomery Field Tower Evacuated.
From a TV news broadcast:
It appears that forest fires have forced the evacuation of SoCal
TRACON and Montgomery Field Tower. LA Center is handling LAX traffic.
Old October 27th 03, 03:50 AM
BTIZ
and many airlines have stopped flying into LAX for the moment..
I-15 is also closed.. stranding weekend travelers in Las Vegas..
"Larry Dighera" wrote in message
Old October 27th 03, 04:25 AM
Jay Honeck
The horror!
(I should be so lucky... :-)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 27th 03, 06:03 AM
BTIZ
I live here.. those trapped tourist keep my tax $ down..
BT
"Jay Honeck" wrote in message
news:xe0nb.38054$Tr4.78629@attbi_s03...
The horror!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 27th 03, 07:51 AM
Did you know that as a result of the fires / tower closure / poor pilot
judgement, a Mooney crash landed at Montgomery, or I should say, on the
freeway just west of the runway. Plane cartwheeled a few times per
witenesses, burst into flames, but the pilot walked away with no injuries!
Initial talk says the pilot was landing with a tailwind that had to have
been 20 kts at Montgomery (with a closed Tower) realized he wasn't going to
be able to land and stop with useable runway leftover so he initiated an
emergency go-around. Pilot was quoted saying the airplane just would not get
any lift on the go-around and so he "put it down" on the freeway albeit not
to gracefully.
Initial reporters were stating that he was attempting the landing with the
known tailwind so he could use the ILS for 28R. Obviously the reported and
the pilot in this case didn't know about a backcourse? Hmmm.
Should be interesting to read the reports on this when they are done..
JB
Old October 27th 03, 04:40 PM
Larry Dighera
On Mon, 27 Oct 2003 06:51:18 GMT, wrote in
Message-Id: :
No.
Fortune can be merciful occasionally.
to gracefully.
There's something wrong with that explanation. If the aircraft had
not yet landed, it would only require the application of full throttle
to continue to sustain it in the air. A climb might be difficult (but
possible) under such conditions if full flaps were extended.
It would be interesting to know what other landing options were open
to the pilot at that time, and what lead him/her to choose a downwind
landing at a closed field.
Agreed. The first report will likely appear he
http://www2.faa.gov/avr/aai/iirform.htm . Later he
http://www.ntsb.gov/ntsb/query.asp#query_start
I find nothing on either web site about the accident you mention yet.
JB
Old October 27th 03, 05:40 PM
Jim Weir
Larry Dighera
-There's something wrong with that explanation. If the aircraft had
-not yet landed, it would only require the application of full throttle
-to continue to sustain it in the air. A climb might be difficult (but
-possible) under such conditions if full flaps were extended.
Lessee...hotter than hell in San Diego, pilot scared out of his wits with the
smell of smoke in the air, full flaps, gear down, slow as mercifully possible to
make the lading short, near IFR (more probably LESS than IFR) conditions, no
visible horizon to keep things level while cleaning up the airplane...talk about
Monday morning quarterbacks.
-Initial reporters were stating that he was attempting the landing with the
-known tailwind so he could use the ILS for 28R. Obviously the reported and
-the pilot in this case didn't know about a backcourse? Hmmm.
There is no published backcourse for Montgomery. Sure, you can shoot the
backcourse any time you want, just don't get caught doing it in less than VFR
conditions. And, I might add, without glideslope. Finding the runway
centerline was one half of this poor feller's problems. Finding the end of the
runway was the other half.
-It would be interesting to know what other landing options were open
-to the pilot at that time, and what lead him/her to choose a downwind
-landing at a closed field.
Oh, dozens. And I'm sure that you can sit in your easy chair sipping a cold one
and figure out just exactly what you would have done. The airport wasn't
closed; the tower was. Montgomery is long enough that a 60 knot tailwind would
not cause overshoot if you hit the numbers. This poor ******* couldn't find the
numbers in the smoke.
http://www.rst-engr.com
Old October 27th 03, 07:09 PM
John T
"Jim Weir" wrote in message
a 60 knot tailwind would not cause overshoot if you hit the numbers.
This poor ******* couldn't find the numbers in the smoke.
Hence the question: Why did he feel that he *had* to land at Montgomery?
That's what I'm hoping winds up in the NTSB report.
John T
http://tknowlogy.com/tknoFlyer
__________
Old October 27th 03, 07:29 PM
Larry Dighera
On Mon, 27 Oct 2003 08:40:23 -0800, Jim Weir wrote
in Message-Id: :
Larry Dighera
The temperature at KMYF did not exceed 88 degrees F. on October 26,
2003: http://www.wrh.noaa.gov/cgi-bin/wrhq...cgi?MYF+Column *
pilot scared out of his wits with the smell of smoke in the air,
Then why did he launch?
Both are reasonable presumptions.
slow as mercifully possible to make the lading short,
That would be prudent in an intentional downwind landing. Of course,
we don't know if the pilot was aware of the direction and velocity of
the surface winds.
You'll find the viviparities for October 26th at the end of this
message.
no visible horizon to keep things level while cleaning up the airplane...
I doubt the pilot would have attempted the landing if he had had no
reference outside the cockpit nor inside.
talk about Monday morning quarterbacks.
So you don't disagree that the aircraft should be able to climb
despite it possibly being configured with full flaps?
Umm.. Let's see... You were at the airport and in communication with
the pilot at the time of the accident? Or are you just "Monday
morning quarter backing?
Oh, dozens.
What leads you to that conclusion?
This statement goes beyond Monday morning quarter backing, and verges
on clairvoyance. How are you at pickin' the ponies? :-)
The airport wasn't closed; the tower was.
The TV newscast wasn't clear about that fact. Do you have any
supporting evidence for it?
At 4,577' runway 28R would probably fail the 60 knot downwind landing
test, IMHO.
That fails to explain the pilot's alleged assertion, that "the
airplane just would not get any lift on the go-around and so he put it
down."
Observations for: Montgomery Field, San Diego
Raw Observation Format
Basic Format
date time wind vis weather sky condition temp dwpt pressure 6 hour
precipitation Remarks
PST (kts)
(mi)
(F) (F) altimeter
(in) sea level
(mb) high low 1 hr 3 hr 6 hr
27 08:53AM 00000KT 1 3/4 HZ FU BKN038 69 37 30.09 1018.4
27 07:53AM 13003KT 1 3/4 HZ FU OVC045 67 36 30.09 1018.5
27 07:53AM 13003KT 1 3/4 HZ FU FEW045 67 36 30.09 1018.5
27 06:53AM 00000KT 1 3/4 HZ FU BKN039 63 35 30.09 1018.6
27 06:29AM 00000KT 1 1/2 HZ FU SCT044 BKN060 63 34 30.09
27 06:09AM 00000KT 2 1/2 HZ FU SCT050 OVC065 63 34 30.10
27 03:53AM 09003KT 3 HZ FU FEW044 SCT070 66 32 30.10 1018.7 74 63
27 02:53AM VRB03KT 4 HZ FU OVC065 66 33 30.10 1018.7
26 10:53PM 33006KT 1 3/4 HZ FU CLR 72 29 30.11 1019.0
26 10:19PM 35005KT 1 1/4 HZ FU CLR 72 28 30.11
26 10:06PM 34006KT 2 1/2 HZ FU CLR 73 28 30.11
26 09:53PM 34007KT 1 1/4 HZ FU CLR 73 28 30.11 1019.2 86 69
26 09:42PM 34005KT 1 HZ FU CLR 73 27 30.12
26 09:34PM 36005KT 3/4 HZ FU CLR 73 28 30.12
26 09:31PM 34007KT 1 HZ FU VV011 73 28 30.12
26 08:53PM 32007KT 1 1/2 HZ FU FEW028 74 27 30.12 1019.5
26 08:30PM 00000KT 1 1/4 HZ FU FEW026 BKN060 OVC070 72 28 30.12
26 08:07PM 05003KT 2 HZ FU BKN055 OVC075 75 27 30.12
26 07:53PM 05004KT 3 HZ FU OVC050 76 54 30.12 1019.4
26 07:38PM 00000KT 2 HZ FU BKN050 OVC060 73 54 30.12
26 07:15PM 04003KT 1 1/4 HZ FU FEW030 BKN038 OVC055 75 54 30.11
26 07:07PM 36003KT 3/4 HZ FU BKN031 OVC050 75 55 30.11
26 06:53PM 00000KT 1 3/4 HZ FU BKN024 BKN035 OVC050 75 54 30.11
1019.0
26 06:46PM 00000KT 3 HZ FU BKN031 OVC050 75 55 30.11
26 06:16PM 22004KT 1 1/4 HZ FU FEW042 SCT060 BKN075 75 54 30.10
26 05:53PM 00000KT 2 1/2 HZ FU CLR 76 53 30.10 1018.7
26 05:21PM 35008KT 4 HZ FU BKN032 BKN041 79 55 30.10
26 05:14PM 01006KT 2 1/2 HZ FU BKN030 BKN039 OVC060 79 55 30.10
26 05:08PM 36005KT 1 1/2 HZ FU BKN026 BKN034 OVC060 79 55 30.09
26 05:01PM 01006KT 3/4 HZ FU FEW003 BKN020 OVC039 79 55 30.09
26 04:53PM 36006KT 1/2 HZ FU FEW003 BKN012 OVC039 79 55 30.09 1018.5
26 04:33PM 34008KT 1/4 HZ FU VV009 79 55 30.09
26 04:22PM 35004KT 3/4 HZ FU VV012 81 54 30.09
26 03:53PM VRB06KT 1 1/4 HZ FU BKN015 86 47 30.08 1018.3 88 82
0.0
26 03:21PM 05015KT 1 1/2 HZ FU BKN015 88 46 30.08
26 03:07PM 06013G17KT 1 HZ FU VV013 88 46 30.08
26 02:53PM 04009KT 3/4 HZ FU VV010 87 47 30.08 1018.2
26 02:14PM 07006G14KT 1 1/4 HZ FU OVC014 88 45 30.08
26 01:53PM 08014G18KT 1 1/2 HZ FU OVC016 87 45 30.07 1017.7
26 01:31PM 08010KT 1 1/2 HZ FU OVC014 88 45 30.07
26 01:15PM 06009G19KT 1 1/2 HZ FU OVC016 88 45 30.07
26 12:53PM 09008P27KT 2 HZ FU OVC018 87 43 30.07 1017.9 0.0
26 12:36PM 08014G18KT 1 3/4 HZ FU BKN016 88 43 30.08
26 12:19PM 08007KT 2 1/2 HZ FU SCT018 BKN029 86 41 30.08
26 12:16PM 09009KT 3 HZ FU SCT020 SCT029 86 41 30.09
26 11:53AM VRB03KT 6 HZ FU BKN026 BKN039 85 40 30.11 1019.0
26 11:30AM 11006KT 7 FU BKN026 BKN040 84 37 30.12
26 10:53AM 13010KT 8 FU OVC041 84 36 30.13 1019.8 0.0 RAE1755
26 09:53AM 14005KT 3 -RA FU OVC019 83 35 30.15 1020.3 83 64 0.0
0.0 RAB42
26 08:53AM 00000KT 6 HZ FU OVC022 75 30 30.15 1020.5
26 07:53AM 35004KT 6 HZ FU OVC022 76 27 30.15 1020.5
26 06:53AM 07007KT 6 HZ FU OVC036 77 27 30.13 1020.0 SMOKE AND
ASH NE-N
26 05:53AM 13005KT 6 HZ OVC034 71 36 30.12 1019.6 TSNO
26 04:53AM 04004KT 7 OVC044 67 39 30.11 1019.3 TSNO
26 03:53AM 00000KT 10 BKN038 OVC050 65 45 30.10 1018.8 67 59
70001 TSNO
26 02:53AM 33004KT 10 BKN036 OVC049 65 45 30.09 1018.5 TSNO
26 01:53AM 00000KT 10 OVC037 63 48 30.10 1018.8 TSNO
26 01:53AM 00000KT 8 CLR 63 52 30.09 1018.6 TSNO
26 12:53AM 31003KT 8 CLR 61 54 30.08 1018.0 402670133 TSNO
25 11:53PM 02003KT 5 BR CLR 61 58 30.06 1017.6 TSNO
25 11:08PM 00000KT 3 BR CLR 63 61 30.07 TSNO
25 10:53PM 00000KT 2 1/2 BR CLR 62 60 30.06 1017.7 78 60 TSNO
25 10:24PM 00000KT 2 BR CLR 63 61 30.07 TSNO
25 10:04PM 00000KT 1 1/4 BR SCT001 61 61 30.06 TSNO
25 09:53PM 33004KT 1 BR VV001 60 60 30.06 1017.8
25 09:32PM 34005KT 3/4 BR VV003 61 61 30.06
25 09:16PM 33005KT 1 1/4 BR FEW012 61 61 30.05
25 08:53PM 36003KT 2 1/2 BR CLR 63 62 30.05 1017.3
25 08:34PM 34005KT 2 1/2 BR CLR 63 63 30.05
25 07:53PM 36004KT 3 BR CLR 65 62 30.04 1016.8
25 06:53PM 00000KT 4 HZ CLR 67 62 30.02 1016.4
25 05:53PM 33007KT 4 HZ CLR 71 62 30.01 1015.9
25 04:53PM 00000KT 6 HZ CLR 77 58 29.99 1015.3 80 74
25 03:53PM 31008KT 7 CLR 78 52 30.00 1015.7
25 02:53PM 28006KT 8 CLR 79 57 30.00 1015.4
25 02:09PM VRB06KT 6 HZ CLR 77 59 30.00
25 01:53PM 31008KT 7 CLR 78 57 30.00 1015.6
25 12:53PM 30006KT 8 CLR 78 60 30.02 1016.3
25 11:53AM 27006KT 6 HZ CLR 78 61 30.05 1017.1
25 10:53AM 00000KT 7 CLR 75 56 30.06 1017.7 75 56 0.01
25 09:53AM 00000KT 3 HZ CLR 66 59 30.07 1017.9
25 09:25AM 00000KT 3 BR SCT001 61 61 30.07
25 09:13AM 35003KT 2 BR BKN001 59 59 30.07
25 09:04AM 35004KT 1/2 FG OVC001 59 59 30.07
25 08:53AM 35005KT 1/4 FG VV001 59 59 30.07 1017.9
25 07:53AM 36004KT M1/4 FG VV001 56 56 30.05 1017.4 0.01
Old October 27th 03, 07:36 PM
C J Campbell
According to AVweb and AP the pilot barely managed to pull himself from the
wreckage and was hospitalized.
