#121
![]() "Judah" wrote in message ... Not if he's operating VFR. There are no clearances for entry of Class D airspace by VFR aircraft in the US. What about a transition clearance? There ain't no such thing. |
#122
I stand corrected... Two-way radio communications must be established, but
a "clearance" is not required. Somehow the difference momentarily eluded me... After all, if an ATC authority can deny you the privilege of entering his/her airspace (either by requesting that you "Remain Clear the Class Delta", or by not acknowledging your tail number), it implies he is implicitly clearing you into his airspace when acknowledging your tail number and not restricting you from his airspace. That said, technically speaking, you are correct. There is no VFR clearance into Class D... "Steven P. McNicoll" wrote in ink.net: "Judah" wrote in message ... What about a transition clearance? It does not exist. |
#123
On Tue, 28 Oct 2003 17:57:43 -0500, "Ron Natalie"
wrote: "Judah" wrote in message ... Not if he's operating VFR. There are no clearances for entry of Class D airspace by VFR aircraft in the US. What about a transition clearance? There ain't no such thing. So when the guys in the choppers call up Lebanon tower up here in NH and request clearance through the class D airspace, they're just being thoughtful? Without that call, they'd be cruising through the traffic pattern at 500 feet unannounced. That's straight over the runways. It happens fairly regularly, and they call in and ask permission every time. What am I missing? Corky Scott |
#124
![]() "Corky Scott" wrote in message ... So when the guys in the choppers call up Lebanon tower up here in NH and request clearance through the class D airspace, they're just being thoughtful? Nope, they're just using the wrong terms. All you need to do wo enter the class D airspace is this: 27K: Lebanon Tower, Navion 5327K TWR: Navion 5327K, LebanonTower Without that call, they'd be cruising through the traffic pattern at 500 feet unannounced. That's straight over the runways. It happens fairly regularly, and they call in and ask permission every time. What am I missing? You're missing that it is not a clearance. All you need to be is in communication with them. While it's generally accepted procedure to tell the tower what you're doing, you're not asking their permission. If they need you to do otherwise, they can instruct you. |
#125
![]() "Judah" wrote in message ... I stand corrected... Two-way radio communications must be established, but a "clearance" is not required. Somehow the difference momentarily eluded me... After all, if an ATC authority can deny you the privilege of entering his/her airspace (either by requesting that you "Remain Clear the Class Delta", or by not acknowledging your tail number), it implies he is implicitly clearing you into his airspace when acknowledging your tail number and not restricting you from his airspace. A clearance is an authorization by air traffic control, for the purpose of preventing collision between known aircraft, for an aircraft to proceed under specified traffic conditions within controlled airspace. Clearances, for the most part, imply separation. ATC does not separate VFR aircraft in Class D airspace so a clearance is not required. |
#126
![]() "Corky Scott" wrote in message ... So when the guys in the choppers call up Lebanon tower up here in NH and request clearance through the class D airspace, they're just being thoughtful? No, they're just misusing the word "clearance". |
#127
When I go through Worcester's airspace going to and from FIT (MA), I call up them up and say
something like "Worcester tower, Cardinal 18738 is ten miles North, VFR Groton, transitioning your airspace at 2,000". There response is "transition approved", not "cleared through". Dave Reinhart Corky Scott wrote: On Tue, 28 Oct 2003 17:57:43 -0500, "Ron Natalie" wrote: "Judah" wrote in message ... Not if he's operating VFR. There are no clearances for entry of Class D airspace by VFR aircraft in the US. What about a transition clearance? There ain't no such thing. So when the guys in the choppers call up Lebanon tower up here in NH and request clearance through the class D airspace, they're just being thoughtful? Without that call, they'd be cruising through the traffic pattern at 500 feet unannounced. That's straight over the runways. It happens fairly regularly, and they call in and ask permission every time. What am I missing? Corky Scott |
#128
![]() Ron Natalie wrote: If they need you to do otherwise, they can instruct you. And if they want you to stay out, they will refuse to answer you. George Patterson You can dress a hog in a tuxedo, but he still wants to roll in the mud. |
#129
![]() "Peter Duniho" wrote in message ... ATC doesn't have enroute radar capable of determining when another aircraft is within those limits. Enroute radar? Do you mean Air Route Surveillance Radar? Why are we suddenly limited to ARSR for discussion purposes? Please, Pete, tell us about the capabilities of ATC radar. Furthermore, that assumes accurate reporting by the VFR target's transponder. Again, an unidentified target would not qualify for that assumption. It assumes nothing at all. If a pilot reports he's in the clouds, then any other aircraft that is within 2000 feet horizontally, 1000 feet above, or 500 feet below the reporting aircraft MUST be in IMC. There was no such part. Yes there was. You said ATC can't rely on PIREPs to KNOW something. That's obviously incorrect. |
#130
ink.net... It assumes nothing at all. If a pilot reports he's in the clouds, then any other aircraft that is within 2000 feet horizontally, 1000 feet above, or 500 feet below the reporting aircraft MUST be in IMC. ATC has no way of knowing that the VFR target in question is within those limits. Yes there was. You said ATC can't rely on PIREPs to KNOW something. That's obviously incorrect. Wow. With the "...about the VFR target" implied, your misunderstanding was understandable, if a bit surprising. But with it being called out explicitly to you, your ignorance is downright shocking. Pete |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
About when did a US/CCCP war become suicidal? | james_anatidae | Military Aviation | 96 | February 29th 04 03:24 PM |
US plans 6,000mph bomber to hit rogue regimes from edge of space | Otis Willie | Military Aviation | 14 | August 5th 03 01:48 AM |
Rogue State | jukita | Military Aviation | 18 | July 13th 03 02:22 PM |
