Rogue IFR
Old October 30th 03, 01:07 AM
Steven P. McNicoll
ATC has no way of knowing that the VFR target in question is within those
limits.
Irrelevant.
Wow. With the "...about the VFR target" implied, your misunderstanding
was
understandable, if a bit surprising. But with it being called out
explicitly to you, your ignorance is downright shocking.
There was no "...about the VFR target" implied.
Where's your dissertation on ATC radar capabilities?
  #132
Old October 30th 03, 01:13 AM
Robert Moore
"Steven P. McNicoll" wrote
It assumes nothing at all. If a pilot reports he's in the
clouds, then any other
aircraft that is within 2000 feet horizontally, 1000 feet above,
or 500 feet below
the reporting aircraft MUST be in IMC.
ATC's definition may be different, but I found these defined on
the web.
From FAR Part 1
IFR conditions means weather conditions below the minimum for
flight under visual flight rules.
This seems to be the definition that you are using for IMC.
From http://www.visi.com/~lindowdy/aviation/glossary.htm
Glossary of Aviation Terms
IMC instrument meteorlogical conditions; unable to see visual
references outside the plane
This seems to be the definition that most mortal pilots use.
Bob Moore
  #133
Old October 30th 03, 02:53 AM
Peter Duniho
ink.net...
those
limits.
Irrelevant.
You wish it was. Unfortunately for you, it's exactly the point.
You presume to tell me what is or is not implied by my own post?
What dissertation?
Pete
  #134
Old October 30th 03, 03:10 AM
Steven P. McNicoll
Yup.
What dissertation?
The one in which you explain the capabilities of ATC radar.
  #135
Old October 30th 03, 03:23 AM
Peter Duniho
ink.net...
Yup.
Not that your arrogance surprises me.
Isn't that something you, as a controller, already ought to be familiar
with?
Pete
  #136
Old October 30th 03, 04:15 AM
Steven P. McNicoll
Pot... Kettle...
with?
Most people would probably think so. You apparently don't share that
opinion.
  #137
Old October 30th 03, 05:15 AM
Peter Duniho
ink.net...
Pot... Kettle...
Yeah, you're right. It's incredibly arrogant of me to think that I know
what my own words mean.
opinion.
What makes you say that?
Pete
  #138
Old October 30th 03, 10:22 AM
Tom S.
"Robert Moore" wrote in message
the web.
From FAR Part 1
So is that "IN CLOULDS" only considered IMC, or is ON TOP considered IMC?
  #139
Old October 30th 03, 03:02 PM
Ron Natalie
"G.R. Patterson III" wrote in message ...
Ron Natalie wrote:
If they need you to do otherwise, they can instruct you.
And if they want you to stay out, they will refuse to answer you.
They'll get less frequency congestion if they tell me to stay out.
If they ignore me, I'll just keep calling. Fortunately the FAA pulled
a plug on this subterfuge in the class C's some time ago.
  #140
Old October 30th 03, 03:06 PM
Teacherjh
How?
Jose
(for Email, make the obvious changes in my address)
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield Paul J. Adam Military Aviation 1 August 9th 04 08:29 PM
About when did a US/CCCP war become suicidal? james_anatidae Military Aviation 96 February 29th 04 03:24 PM
US plans 6,000mph bomber to hit rogue regimes from edge of space Otis Willie Military Aviation 14 August 5th 03 01:48 AM
Rogue State jukita Military Aviation 18 July 13th 03 02:22 PM
