Shadin flowmeter problems - anyone else sees this?
Old October 31st 03, 02:22 AM
Bill Zaleski
Default Shadin flowmeter problems - anyone else sees this?
I have used a Microflo for 4000 hours now. I have found that unless
you leave power on for about one minute after setting FOB, the gal
remaining, or the fuel used, I can't remember which, will not be
correct. Yes, it is EEPROM memory, and does not need power to hold
data, but seems to need power for a little bit to insure the storage.
On Thu, 30 Oct 2003 12:39:02 +0000, Peter
Hi,
I've had a Shadin Microflo for a year and a half, and it has what
looks like a hardware or software bug: after setting a new FOB figure,
waiting for it to save it, turning off power, turning power back on,
it has lost the new FOB setting and has reverted to the original FOB
setting which was there before I started to change it.
There is a strong correlation between how long the unit has been ON
(or OFF) since the FOB was set, and losing the data: the longer one
waits, the less likely it is to get lost.
I have now had FOUR of these changed (under warranty) and they all do
it. Sometimes one has to set the FOB (at fill-up time) ten times or
more before it "sticks" in the memory.
Shadin always respond with a standard reply asking for serial number
and other into and don't acknowledge any knowledge of this. They have
however confirmed that there is no battery which might go flat, so I
assume it is an EEPROM/FLASH, in which case (I have designed lots of
electronic products) it would appear a pretty serious "feature".
Has anyone else seen this?
Peter.
Shadin flowmeter problems - anyone else sees this? Bill Zaleski Instrument Flight Rules 2 October 31st 03 09:29 PM
Shadin flowmeter problems - anyone else sees this? Steve Beaver General Aviation 2 October 31st 03 09:29 PM
Shadin flowmeter problems - anyone else sees this? Steve Beaver Owning 0 October 31st 03 04:03 PM
Shadin flowmeter problems - anyone else sees this? Bill Zaleski General Aviation 0 October 31st 03 02:22 AM
Shadin flowmeter problems - anyone else sees this? Bill Zaleski Owning 0 October 31st 03 02:22 AM
