Leaning / step climbing?
Old November 7th 03, 11:01 PM
John Galban
Thomas Borchert wrote in message ...
Btiz,
Some will argue it is not needed to lean below 3000MSL..
Uh, only those clinging to one of the more stupid OWTs (Old Wive's
Tale).
While it's true that leaning by altitude is somewhat of an OWT, it's
important to remember that, like most OWTs, it has some basis in fact.
Specifically, you should not be leaning if your engine in making 75%
power or better. Of course, in normally aspirated light singles, the
percentage of power available is greater at lower altitudes.
Old November 8th 03, 05:53 AM
Rick Durden
John,
power or better.
Not necessarily so. It is perfectly okay to lean at 75% power, the
manual for your airplane has a fuel burn for 75% with lean mixture.
In fact, if you don't lean when operating at 75% with that Lycoming,
you will significantly reduce your range and endurance and possibly
foul the plugs. www.gami.com has a good discussion of leaning and
what's going on during combustion. It may be perfectly okay to lean
at power settings above 75%.
While cliches may have some basis in fact, few of the OWTs do. Some
are erroneous carryovers from radial engine days (such as a power
reduction after takeoff on most horizontally opposed engines) and
some, such as not leaning below some arbitrary altitude come from a
very simple misreading of the Owner's Manuals/POHs where the manual
said to lean in the climb above some altitude and some folks
misinterpreted that as meaning not to lean in level flight below that
altitude and didn't notice that the cruise performance charts for
those altitudes stated clearly "with lean mixture".
All the best,
Rick
Old November 8th 03, 10:19 PM
Neal
On Sat, 08 Nov 2003 13:21:32 GMT, David Megginson
(Rick Durden) writes:
Quite right. That one surprised me as well.
I always simply just lean for peak RPM whenever climbing... or even
taking off, anymore. I don't think I can hurt my low compression
O-320 this way. Three years and well over 300 hours later since I
bought the plane and this leaning style seems to suit this engine
perfectly since I have no EGT/CHT guages. I do lean as agressively as
I can to keep the engine smooth once I've reached level cruise
altitude. My plugs stay clean, my fuel burn is spot-on what a 150hp
Cherokee ought to get too. If I don't lean to peak RPM in climbs, of
course the climb rate is lethargic, and it seems like all I'm doing is
wasting gas and loading up my plugs and crankcase oil with extra lead
ash.
Old November 9th 03, 02:37 AM
BTIZ
true
"Thomas Borchert" wrote in message
Btiz,
Tale).
Thomas Borchert (EDDH)
Old November 9th 03, 11:58 AM
Thomas Borchert
David,
Why?
Old November 9th 03, 10:59 PM
David Megginson
Thomas Borchert writes:
David,
Why?
Note the original statement:
power or better.
There may be planes where it's not OK to lean at 75%, but all of the
POH's I've looked at so far *require* leaning at 75% power to get the
performance numbers (fuel burn and range) that they list.
All the best,
David
Old November 10th 03, 05:09 AM
Tom S.
"David Megginson" wrote in message
power or better.
http://www.avweb.com/news/columns/182152-1.html (Article 57, but read 58 &
59 as well).
Old November 10th 03, 05:29 AM
Tom S.
Three part series - often contradicts the contradictions in the POH.
http://www.avweb.com/news/columns/182583-1.html
http://www.avweb.com/news/columns/182176-1.html
http://www.avweb.com/news/columns/182179-1.html
Old November 10th 03, 08:01 AM
Thomas Borchert
David,
got it. Thanks.
So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money [email protected] Owning 1 January 16th 05 06:48 AM
Glue for wing step grippy thingies Steven Barnes Owning 6 November 28th 04 09:56 PM
Re; What do you think? Kelsibutt Naval Aviation 0 September 29th 03 06:55 AM
STEP program helps advance hundreds of hand-picked airmen Otis Willie Military Aviation 0 September 19th 03 09:15 PM
