#21
"Happy Dog" wrote in message .. . "vincent p. norris" wrote in message You don't have positive G all the way around in an aileron roll. In a properly done aileron roll you certainly do... Were you thinking of a slow roll? I know the diffference between a slow roll and an aileron roll. If you think you maintain positive G in an aileron roll, (1). Take along a bottle of water and a drinking glass next time you fly. (2). Fill the glass with water and place it atop the instrument panel. (3). Do an aileron roll. Which proves what? Place a glass of water atop the instrument panel and execute a steep turn. It won't stay there, Are you saying that a steep turn isn't a positive G manoeuvre? You haven't thought this through... le moo If you stay coordinated it certainly will stay. Ever see the video of Hoover pouring a glass of water while doing a roll. |
"Happy Dog" wrote
Which proves what? Place a glass of water atop the instrument panel and execute a steep turn. It won't stay there, It should!!! If not, you're not using the controls properly. I teach my students to execute co-ordinated steep turns, doesn't everyone do it that way??? Bob Moore ATP CFI |
Big John wrote
1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. There are also a few fine points the experts use that I have not covered but above are the basics. Been there done that for longer (65 years) than BOb has been flying. )I have e-mailed BigJohn and posted at: alt.binaries.pictures.aviation a scan from William Kershner's book, The Flight Instructor's Manual, in which he describes the barrel roll as an acrobatic maneuver. You probably know that Mr. Kershner is one of the most respected names in the flight training field, having authored several books on the subject. Not as funny as Machado, but he has been around for a much longer period of time. I haven't scanned and OCRed the text because I think that the picture is self-explanitory, but if it would help, I will do the page of text describing the barrel roll. Note that as mentioned in my previous post quoting from: http://acro.harvard.edu that one cannot maintain "one G" in a barrel roll since it involves both a loop and a roll. In order to perform the loop portion, one must pull at least 3-3.5 Gs in the pull-up and a similiar force in the pull-out. While inverted, the g-force drops to .5-1 g as in a normal loop. I readily conceed that Big John as been around a bit longer than I, but by the the time that I flew in the military, we were learning to fly in "airplanes", not "birds". :-) :-) Bob |
"Dave Stadt" wrote in message
(2). Fill the glass with water and place it atop the instrument panel. (3). Do an aileron roll. Which proves what? Place a glass of water atop the instrument panel and execute a steep turn. It won't stay there, Are you saying that a steep turn isn't a positive G manoeuvre? You haven't thought this through... If you stay coordinated it certainly will stay. Ever see the video of Hoover pouring a glass of water while doing a roll. If you stay *perfectly* coordinated. I would have no problem demonstrating an aileron roll with a cup of MacDonald's most dangerous firmly secured in my lap. (Filled to no more than a couple inches below the brim.) I have a key fob that I sometimes watch during aerobatic manoeuvres. It doesn't move much during coordinated 1G stuff. But it moves a bit. le moo |
"Robert Moore" wrote in message . 8... "Happy Dog" wrote Which proves what? Place a glass of water atop the instrument panel and execute a steep turn. It won't stay there, It should!!! If not, you're not using the controls properly. I teach my students to execute co-ordinated steep turns, doesn't everyone do it that way??? The point is that it will likely move, not because there is a negative G situation, but because it takes very little lateral G force to knock it off. Have you actually tried this? Three times in a row? le moo |
Big John wrote: [...] 3. An aileron roll is just laying the aileron over (normally full aileron) and letting bird roll. Depending on type of aircraft (fighter or GA) the nose makes a circle around a point. Fighters can do at cruise with little or no nose above the horizon. GA requires a start with the nose above the horizon due to slower rate of roll and bird ending up nose low because no other control input to hold nose up while inverted is used The question for me -- and what prompted my earlier posting(s) -- is whether it's possible to do a standard aileron roll and get negative G's (or non-positive G's, to be precise). The puny GA planes I fly all have positive G forces all the way around an aileron roll (unless you do something funny with elevator and / or rudder), but is that true of all aircraft? Hamish |
Robert
You talk about doing a LOOP in association with a roll. A LOOP has no roll in it.The ailerons are only used to keep the wings 90 degrees to the plane of the loop. A IMMELMAN or CUBAN EIGHT has a roll associated with part of a loop. The description of making a corkscrew inside a tube is another way of defining the flight of the airplane when it does a BARREL ROLL. In my prior post I said to pull one 'G' when I should have said two 'G'. Same 'G' as pulled in a one 'G' turn (one gravity 'G' and one acceleration 'G'). Not sure you would or would not call a barrel roll a compition maneuver. Never flew in compiton. In the airshows we used to put on didn't do BARREL ROLLS becaue they were not very spectular from the ground nor percicsion manuevers.. In airshows many times we would do a 8 point SLOW ROLL stoppmg momentarily every 45 degrees of roll. This is a precison maneuver and takes a lot of practice with elevator, rudder and aileron in coordination to do correctly and with precision so looks good from ground. Seen in compition today. My reference is years and years of doing acrobatics and teaching same in both conventional aircraft and jets. As a matter of interest, most of the victory rolls you see of Fighters returning from a combat mission with kills are aileron rolls. You could see some (rare) put a little forward stick in when inverted but had to look close. Some birds didn't do good aileron rolls (P-51 for instanace) If you did an aileron roll on the deck you normally bumped the stick upside down to keep the nose up. The P-40 however aileron rolled like a spool on a thread. Big John On Sun, 09 Nov 2003 03:55:51 GMT, Robert Moore wrote: Big John wrote 1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. Hey John, I didn't make-up that post, it came straight from: http://acro.harvard.edu The Barrel Roll is a not competition maneuver. The barrel roll is a combination between a loop and a roll. You complete one loop while completing one roll at the same time. The flight path during a barrel roll has the shape of a horizontal cork screw. Imagine a big barrel, with the airplanes wheels rolling along the inside of the barrel in a cork screw path. During a barrel roll, the pilot experiences always positive G's. The maximum is about 2.5 to 3 G, the minimum about 0.5 G. Care to give us a reference for your definition? Bob |
#28
Big John wrote
You talk about doing a LOOP in association with a roll. No John, I didn't talk or write about...... I just quoted from the acro.harvard.edu web site and William Kershner's fine book. You may not have seen the picture from the Kershner book when you wrote this, but write back when you have seen the barrel roll as described by someone who is considered an authority in the field. My reference is years and years of doing acrobatics and teaching same in both conventional aircraft and jets. Still waiting for reference documentation. :-) Bob |
#29
Big John wrote
My reference is years and years of doing acrobatics and teaching same in both conventional aircraft and jets. Check-out Mr. William Kershner at: http://www.kershnerflightmanuals.com/ Bob |
#30
Robert
Talk me through a loop doing a Barrel Roll. We must be using different words or maneuvers? First let me try a different set of words for a GA barrel roll. 1. Drop the nose and pick up 20-25 mph. 2. Start a nose low left turn in the shallow dive and turn 20-30 degrees. 3, Start pulling nose up and reversing turn using 1 'G' of acceleration (plus 1 G of gravity). 4. Continue the constant rate of roll and the 2 'G's on aircraft. 5. After passing the inverted position continue roll pulling the 2 G's until bird is back with wings level. 6. Ending nose may be level or down depending on aircraft, starting airspeed and rate of roll. You can make a tight barrel roll pulling more that the 2 G's if you want and using more aileron. If tighter will go around faster of course. Now your turn with the help of the guy who wrote the book you read. Don't know what base you got your Pilot training at and the years. I was at Willie from '49 to '53 and taught Basic. Advanced and Gunnery. The Pilots always used the acronym "Bird". Lots of the paper forms that we filled out used the word 'aircraft' however. On a 172,. I'd do a barrel roll in the bird but not a slow roll or aileron roll .Either would over stress the bird 99 times out of a hundred. Enough. Let the others have the stage now. Big John On Sun, 09 Nov 2003 14:54:09 GMT, Robert Moore wrote: Big John wrote 1. A 'barrel roll' is a roll where (if done properly) you as a passenger, with your eyes closed, can not tell you did a roll. The ball stays centered and if one 'G' is maintained, it feels like straight and level flight. Starting nose position and of course air speed varies between underpoweed GA aircraft and super sonic Fghters. There are also a few fine points the experts use that I have not covered but above are the basics. Been there done that for longer (65 years) than BOb has been flying. )I have e-mailed BigJohn and posted at: alt.binaries.pictures.aviation a scan from William Kershner's book, The Flight Instructor's Manual, in which he describes the barrel roll as an acrobatic maneuver. You probably know that Mr. Kershner is one of the most respected names in the flight training field, having authored several books on the subject. Not as funny as Machado, but he has been around for a much longer period of time. I haven't scanned and OCRed the text because I think that the picture is self-explanitory, but if it would help, I will do the page of text describing the barrel roll. Note that as mentioned in my previous post quoting from: http://acro.harvard.edu that one cannot maintain "one G" in a barrel roll since it involves both a loop and a roll. In order to perform the loop portion, one must pull at least 3-3.5 Gs in the pull-up and a similiar force in the pull-out. While inverted, the g-force drops to .5-1 g as in a normal loop. I readily conceed that Big John as been around a bit longer than I, but by the the time that I flew in the military, we were learning to fly in "airplanes", not "birds". :-) :-) Bob |
| Thread Tools | |
| Display Modes | |
| ??Build rolling tool chest? | Michael Horowitz | Owning | 15 | January 27th 05 05:56 AM |
| Rolling Thunder | Mortimer Schnerd, RN | Military Aviation | 10 | June 14th 04 01:49 AM |
| B-52 crew blamed for friendly fire death | Paul Hirose | Military Aviation | 0 | March 16th 04 01:49 AM |
| Defensive circle | Dave Eadsforth | Military Aviation | 23 | October 9th 03 07:13 PM |
| Talk about runway incursions... | Dave Russell | Piloting | 7 | August 13th 03 03:09 AM |
