#21
"G.R. Patterson III" wrote in message
... "R. Hubbell" wrote: I don't know anything about that plane but I do know that any plane that was designed for passenger carrying doesn't make a great platform for delivering fire retardants. You know this how? The miltary has been using that plane as a tanker for decades. It should make a fine fire bomber. Obviously, he doesn't actually know. Pete |
In a previous article, "Peter Duniho" said:
nor does a "passenger" design necessarily make a bad water bomber. In fact, most large passenger aircraft (airliners) were derived to at least some degree from existing military designs, just due to the coincidence of how I'm sure the designers of the DC-10 and 747 would be extremely surprised to hear that. -- Paul Tomblin http://xcski.com/blogs/pt/ "The day Microsoft makes something that doesn't suck is probably the day they start making vacuum cleaners" - Ernst Jan Plugge |
#24
![]() "Newps" wrote in message news:jdBrb.156759$Tr4.420869@attbi_s03... Never happen. Costs too much to operate and too limited on where they can land. Doesn't do you any good when you are 100+ miles away from the fire, no matter how much you can carry. Landing isn't a problem, taking off with all that water aboard will be :-) |
#25
On Sun, 9 Nov 2003 22:55:10 -0800, "Peter Duniho"
wrote: "Martin X. Moleski, SJ" wrote in message .. . "Firefighting certainly wasn't what Glenn L. Martin had in mind for the design of the Martin Mars. Originally conceived as a bomber for long range missions and patrols, the production aircraft were redesigned and classified for long-range general transport because of the demonstrated heavy-lift capability of the prototype." http://www.martinmars.com/mars.html Key word: "redesigned". Right. Indicating a change in design. All that the other guy said was that the Mars was intended originally to be a bomber. Not a water bomber. A military bomber. When the Navy changed its mind, the innards got redesigned so that they could be used for other things. The prototype was never used as a water bomber. Neither the original poster nor I claimed that it was. The airplanes in use as water bombers (and not of the same design as the prototype) were never intended for use as a bomber. Claiming that they were doesn't make it so. You said we should read the histories. I went out on the net and read enough to make me quite sure that the original poster's point was accurate. Now you want to change the terms of the debate. You may have the last word. Marty |
#26
"Peter Duniho" wrote in message ...
"Martin X. Moleski, SJ" wrote in message ... "Firefighting certainly wasn't what Glenn L. Martin had in mind for the design of the Martin Mars. Originally conceived as a bomber for long range missions and patrols, the production aircraft were redesigned and classified for long-range general transport because of the demonstrated heavy-lift capability of the prototype." http://www.martinmars.com/mars.html Key word: "redesigned". The prototype was never used as a water bomber. The airplanes in use as water bombers (and not of the same design as the prototype) were never intended for use as a bomber. Claiming that they were doesn't make it so. Sorry Peter. You said in an earlier post: "Martin Mars (originally designed as a military troop transport, now used *only* for fire fighting)" and "It was not. I already told you, it [the Mars] was originally designed as a military troop transport. You don't need to take my word for it. Just read up on the history of the Martin Mars." Clearly *you* were wrong here. You didin't say 'Originally designed as a bomber, then redesigned as a troop transport'. You said 'Originally designed as a troop transport'. It was clearly designed as a bomber, and the 'repurposing' as a transport didn't involved structural redesign of the wing or structural components of the fuselage. It consisted of "All the turrets and guns, bomb bays, and armor plate were removed, cargo-loading hatches and cargo-loading equipment were installed, and the decking was reinforced. The modified aircraft was designated XPB2M-1R. " So essentially the Mars in use today is the same *design* originally designed as a bomber, which you incorrectly stated as being 'originally designed' as a troop transport. Yes it was repurposed, but don't you think it's rather ironic that you chimed in on this thread to chastise the poster for being wrong about the original purpose of the aircraft, and the being provably incorrect about it *yourself*? Cheers, Cap |
#27
![]() "Captain Wubba" wrote in message So essentially the Mars in use today is the same *design* originally designed as a bomber, which you incorrectly stated as being 'originally designed' as a troop transport. Looks like a medium, uniform shade of gray to me. I've done no research other than read the cited site above, but that refers to the Mars being "conceived" as a bomber, but delivered as a transport. "Re-design" apparently occurred *during* the design phase, which could arguably be taken as no redesign at all. I didn't get the impression that there was ever any Mars delivered to an end user as a bomber. How gray do you want to get? JG |
#28
om... [...] So essentially the Mars in use today is the same *design* originally designed as a bomber, which you incorrectly stated as being 'originally designed' as a troop transport. I was speaking of the airplanes actually *flying* as water bombers. They *were* originally designed as transport aircraft, not bombers. As I already pointed out, many (most) aircraft are not from-scratch designs. They are generally redesigns to some extent of previous aircraft. When I write "originally designed" I do not mean the very first aircraft in the lineage, but rather the originally intended purpose of the specific aircraft in question. You might as well say that the 747 was originally designed as a bomber. You are also losing track of the point he all of the discussion regarding the actual "design" is moot unless the person claiming only bombers make suitable water bombers can explain what it is about the design of a bomber that is unique. Obviously since bomber designs have been converted to passenger designs, they really aren't all that different. There is no a priori evidence that a passenger design cannot be used in a bomber role, even if it's as a water bomber. Pete |
#29
"Paul Tomblin" wrote in message
... I'm sure the designers of the DC-10 and 747 would be extremely surprised to hear that. I doubt that they would. I can't speak directly to the DC-10, but my history book on Boeing tracks the lineage of all of the Boeing aircraft, and at each step along the way, each new aircraft borrows heavily from the previously built aircraft. In many cases, the passenger aircraft projects started as military contracts. Pete |
#30
You are also losing track of the point he all of the discussion regarding the actual "design" is moot unless the person claiming only bombers make suitable water bombers can explain what it is about the design of a bomber that is unique. Obviously since bomber designs have been converted to passenger designs, they really aren't all that different. There is no a Bombers are built stronger. Bombers converted to passenger planes have never been all that successful, especially not if there is a commercial competitor, because the extra structure they need to take military G loads is extra weight that their competitors are carrying in passengers instead of structure. They are also designed to take some battle damage. I don't know of any non-military aircraft where the spec said "must be able to take a 23mm cannon shell hole in the main spar and keep flying", but I remember the design spec for what became the UH-60 helicopter did have that provision (ok, I don't remember seeing that in the spec for other military aircraft, but the UH-60 and the AH-63 and AH-64 were the only ones that I read in detail, and they all specified exactly what sort of battle damage they must be able to take). To be successful as a water bomber, an aircraft has to be able to maneuver in tight quarters, take high Gs, and maybe deal with "battle damage" from hitting tree tops or other sources. -- Paul Tomblin http://xcski.com/blogs/pt/ ....if you squeeze a MS product into a small enough memory footprint there may not be sufficient space for it to fall over, thus giving the impression it's reliable. -- Geoff Lane |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
water bombers | Stew Hicks | Home Built | 2 | September 8th 03 11:55 PM |
water bombers | Stew Hicks | Home Built | 0 | September 7th 03 04:27 PM |
