Looks like I've got an oil leak in my 550 hr SFNEW IO-360-A3B6
Lycoming engine. My mechanic says I should clean the engine and see where its coming from. I feel strange cleaning the engine. He said to use an automotive engine cleaner and then wash it off right away. I guess its not different than flying through a level 5 rain shower but I can't see spraying my mags down with a hose. How do most of you do it? |
I use CRC Lectra Clean. It's great. About $6 a can, but it dries almost
instantly, leaves no residue and according to the label has no flash point, though I wouldn't use it on a hot engine. Goes a long ways, too. I bought 3 cans when my engine was real greasy and only used 2, but it was spotless. There's enough pressure and one of those little straw type inserts to reall get it where you want it. If you have a compressor, get a cleaner nozzle (the kind with a bottle or pickup tube) and use paint thinner. Also works great. My A&P suggested cleaning the engine with one of these and then powdering the engine around the suspected leak area, fly it for a while adn look for the leak in the powder. I didn't need to do this to find my leak, but it sounds good. mike regish "Robert M. Gary" wrote in message om... Looks like I've got an oil leak in my 550 hr SFNEW IO-360-A3B6 Lycoming engine. My mechanic says I should clean the engine and see where its coming from. I feel strange cleaning the engine. He said to use an automotive engine cleaner and then wash it off right away. I guess its not different than flying through a level 5 rain shower but I can't see spraying my mags down with a hose. How do most of you do it? |
om... [...] He said to use an automotive engine cleaner and then wash it off right away. I guess its not different than flying through a level 5 rain shower but I can't see spraying my mags down with a hose. How do most of you do it? To expand on the existing replies: please make sure you are washing the engine at a properly designed wash area, where the run-off is contained and disposed of properly. If you're worried about water getting into various components, you might consider using duct tape and possibly some plastic bags/wrap/whatever to seal things up. Make sure you log where you closed something up, and when you're done, double-check and triple-check to make sure you removed all of the coverings you added before washing. Just be gentle with the water (with engine cleaner, it shouldn't take a lot of pressure to actually rinse things off), careful where you point the hose, and you should be fine. Pete |
There are nonflamable solvent availible that evaporate completely and you
can get a air fitting that draws small amounts of the solvent and sprays it with a lot of air. It gets things clean quickly and doesn't make much mess. The mechanics where I get my maitenance done use rubbing alchohol in a spray bottle. It cuts oil well and drys quickly. Mike MU-2 "Robert M. Gary" wrote in message om... Looks like I've got an oil leak in my 550 hr SFNEW IO-360-A3B6 Lycoming engine. My mechanic says I should clean the engine and see where its coming from. I feel strange cleaning the engine. He said to use an automotive engine cleaner and then wash it off right away. I guess its not different than flying through a level 5 rain shower but I can't see spraying my mags down with a hose. How do most of you do it? |
Thanks! That sounds like the way to go!
-Robert "mike regish" wrote in message news:GQQwb.226134$mZ5.1711551@attbi_s54... I use CRC Lectra Clean. It's great. About $6 a can, but it dries almost instantly, leaves no residue and according to the label has no flash point, though I wouldn't use it on a hot engine. Goes a long ways, too. I bought 3 cans when my engine was real greasy and only used 2, but it was spotless. There's enough pressure and one of those little straw type inserts to reall get it where you want it. If you have a compressor, get a cleaner nozzle (the kind with a bottle or pickup tube) and use paint thinner. Also works great. |
"Robert M. Gary" wrote in message om... Looks like I've got an oil leak in my 550 hr SFNEW IO-360-A3B6 Lycoming engine. My mechanic says I should clean the engine and see where its coming from. I feel strange cleaning the engine. He said to use an automotive engine cleaner and then wash it off right away. I guess its not different than flying through a level 5 rain shower but I can't see spraying my mags down with a hose. How do most of you do it? I don't think paint thinner is appropriate to use. It is highly flammable and will damage paint, obviously dependent on the type of thinner used. Dry cleaning solvent or white spirit is an approved Mil spec cleaner and won't damage paint, and it's relatively cheap. Put it in an atomiser bottle on jet setting and have an old paint brush ready for stubborn areas, then hose off. Scet. |
"Scet" wrote in message ... "Robert M. Gary" wrote in message om... Looks like I've got an oil leak in my 550 hr SFNEW IO-360-A3B6 Lycoming engine. My mechanic says I should clean the engine and see where its coming from. I feel strange cleaning the engine. He said to use an automotive engine cleaner and then wash it off right away. I guess its not different than flying through a level 5 rain shower but I can't see spraying my mags down with a hose. How do most of you do it? I don't think paint thinner is appropriate to use. It is highly flammable and will damage paint, obviously dependent on the type of thinner used. Scet. Paint thinner (mineral spirits) will NOT damage paint. It is flamable, but unless atomized, it is not highly flamable. -- Jim in NC |
Scet wrote: I don't think paint thinner is appropriate to use. It is highly flammable and will damage paint, obviously dependent on the type of thinner used. Paint thinner in the U.S. is also called "mineral spirits". It's no more flamable than kerosene (which you call "white spirit"), is less oily, and will definitely NOT harm any paint that's likely to be on an aircraft. George Patterson Some people think they hear a call to the priesthood when what they really hear is a tiny voice whispering "It's indoor work with no heavy lifting". |
"Scet" wrote in message ... "Robert M. Gary" wrote in message om... Looks like I've got an oil leak in my 550 hr SFNEW IO-360-A3B6 Lycoming engine. My mechanic says I should clean the engine and see where its coming from. I feel strange cleaning the engine. He said to use an automotive engine cleaner and then wash it off right away. I guess its not different than flying through a level 5 rain shower but I can't see spraying my mags down with a hose. How do most of you do it? I don't think paint thinner is appropriate to use. It is highly flammable and will damage paint, obviously dependent on the type of thinner used. Paint thinner is mineral spirits and is nearly if not the same as Stoddard solvent. It WILL NOT damage paint. Flammability is not an issue unless you spray it into an open flame. It is a very good low cost solvent available almost anywhere. Dry cleaning solvent or white spirit is an approved Mil spec cleaner and won't damage paint, and it's relatively cheap. Put it in an atomiser bottle on jet setting and have an old paint brush ready for stubborn areas, then hose off. Scet. |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 04:03 PM |
| Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 05:09 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
