New Aviation Terminology
Old November 26th 03, 06:51 PM
Peter Duniho
"Teacherjh" wrote in message
... unless you can't take off without an IFR clearance, and there's
incoming.
But I suppose the controller would take care of that when it happened.
Ninety-nine times out of a hundred, sure. Who wants to be the hundredth?
It just seems that the end of the runway is a bad place to be unless
you're
ready to go.
It is. And no controller can make you sit there. They don't fly the plane.
You do.
Pete
  #32
Old November 26th 03, 09:28 PM
David CL Francis
On Tue, 25 Nov 2003 at 21:21:49 in message
, Teacherjh
What were they doing in position for takeoff without an IFR clearance in
hand???
Best that you read an extensive report on this terrible accident. For
easy reading and lots of detail I would commend:
Air Disaster Volume 1 by Macarthur Job Page 164 Chapter 18
Title of chapter "Did he not clear the runway - the Pan American?"
That took place March 27, 1977
ISBN 1 875671 11 0
David CL Francis
  #33
Old November 27th 03, 12:47 AM
David CL Francis
On Wed, 26 Nov 2003 at 12:17:22 in message
, Matthew Waugh
To go back to the original crash - at the time the airport was littered with
large airliners because the weather in Europe was horrible and they'd all
landed there to wait it out. So they were back-taxing aircraft on the active
runway because the taxi-ways were full.
Weather varies considerably across Europe so it is rare for the weather
in Europe to be horrible everywhere. The weather was a vital, but local
factor in that accident. Whether the Canary islands are even part of
Europe is debatable. Unusually there was cloud and fog in Tenerife.
Leaving your generalisation aside the cause of all the congestion was
that a small bomb had gone off in the passenger terminal at Las Palmas.
There had been a 15 minute warning of that but then there was then a
second warning about another bomb. There was little option but to close
the airport while a big search was conducted. The many flights
approaching at that time had to be diverted and they were sent to Los
Rodeos, the other Canary Islands international airport, 50 miles away on
the island of Tenerife. It had a single runway and had neither taxi ways
nor parking to handle double its normal daily traffic. The apron was
fully occupied when the KLM 747 arrived. Then the Pan Am 747 arrived.
That is just the starting point for what happened. I am not going
through all the rest of it - it is well documented but please get the
basics roughly correct.
David CL Francis
  #34
Old November 27th 03, 08:44 AM
Julian Scarfe
Being on the runway without an IFR clearance is not a problem.
incoming.
you're
ready to go.
Not sure why there's such a strong aversion to this. In Europe at least,
the rate-limiting step is often coordination with the facility that will
control after departure. The clearance is not issued until that has been
done, and the window that that facility wants to open up is usually quite
short. Hence it's not unusual at a quiet controlled airport to be given the
IFR clearance while lined up on the runway, and a take-off clearance
immediately afterwards. If the clearance were given at the hold, it could
take minutes to backtrack the runway and get airborne -- it's not unusual to
get such a clearance a couple of minutes before the end of a flow management
slot.
Julian Scarfe
  #35
Old November 27th 03, 07:00 PM
Peter Duniho
"Julian Scarfe" wrote in message
Well, for one, because nearly all fatal collisions between transport
aircraft occurred on a runway.
[...] Hence it's not unusual at a quiet controlled airport to be given
I don't think anyone stipulated the "quiet controlled airport".
"Controlled" is implied, of course. But this "quiet" was never stated. In
the US, "quiet controlled airport" is either an oxymoron by definition, or a
relative term applicable to airports where there's still a fair amount of
traffic.
to
management
slot.
Minutes? I've never seen an airport where an airplane would take more than
ten or fifteen seconds to get lined up and take off. Not saying they don't
exist, of course, but surely it makes more sense to think about the typical
case here when talking about general procedures.
Pete
  #36
Old November 27th 03, 08:52 PM
Julian Scarfe
That's fair enough. I think there have been at least two landing vs
position-and-hold collisions, though I don't think either of them involved
waiting for an IFR clearance -- but I take the point.
In
a
traffic.
Well Tenerife was pretty quiet that day until the collision!
It's difficult to tell as I have limited experience of flying in the US, but
it didn't seem unusual for minutes to go by without the runway being in use.
My last flight in the US involved an unscheduled stop at PAE after a door
came open in flight. We landed on the runway and instead of asking us to
vacate we got to stop, fix the door and then backtrack on the runway to the
end. Does Paine Field count as quiet?
unusual
to get such a clearance a couple of minutes before the end of a flow
management slot.
than
don't
typical
Again I can only think of specific cases -- I guess concrete is cheaper in
the US. :-) At my home base of Cambridge in the UK, the last paved taxiway
to/from the apron is about 2/3 of the way down the 6500 ft runway 05. Thus
the 747s that come in for maintenance end up taxying more than 4000 ft on
the runway, and they don't like doing that very quickly. It's more common
than not for them (and the rest of us for that matter) to get a clearance
while backtracking.
Julian Scarfe
  #37
Old November 27th 03, 09:14 PM
Peter Duniho
but
use.
I'm based at Paine. It does have its quiet moments, but I wouldn't want to
sit on the runway for any extended period of time, not as a general rule.
You don't say what kind of airplane you were in, or what the nature of the
flight was. I assume that since you say you backtracked on the runway, the
airplane must've been pretty small. I personally would not have accepted
the offer to backtrack on the runway, not at Paine. Your experience is a
good example of a scenario that may or may not be entirely safe.
(That said, I'm a bit surprised you needed to backtrack on the runway
anyway. Assuming you landed on the long runway, there should have been
plenty of room for a stop-and-go. If you landed on one of the shorter ones,
the taxiway exits are close enough together that it's hardly a more
significant effort to taxi back on an actual taxiway. There's no
operational reason that justifies the reduction in safety to backtaxi on any
runway at Paine).
The bottom line IMHO is that as the pilot, it's hard to know for sure
whether current circumstances allow one to safely remain on the runway for
extended periods of time, and controllers are falliable. Aviation safety is
predicated on the idea that one makes every effort to avoid potentially
serious situations, even if those situations rarely result in a problem.
In any case, I would certainly never say that one should never wait on the
runway, but one ought to only do so when one has VERY good information with
respect to what aircraft are actually in the area, a reasonable idea of how
long the wait will be, and a good escape plan in case the wait goes longer
than expected. And one should do it only when there's a really good reason
for doing so (i.e. some benefit that justifies the risk).
Furthermore (and more relevant to your original comment) I can *easily* see
why there's such a strong aversion to this sort of thing. It's rarely an
operational necessity, and when it is, it should still only be undertaken
with the same (presumably high degree of) caution used in other areas of
flight. The aversion is quite understandable IMHO.
Pete
  #38
Old November 28th 03, 08:34 AM
Julian Scarfe
to
ones,
any
runway at Paine).
It was a Seneca II. A collision would have required:
a) that a landing aircraft failed to obtain a clearance to land, and
b) that we failed to see a landing aircraft while backtracking, and
c) that the controller failed to see a landing aircraft, and
d) that the landing aircraft failed to see us, and
e) that we tried to occupy the same part of a 9000 x 150 ft runway at the
same time.
It seemed like a good bet.
is
Given the uncertainties in estimating risks, I usually hesitate to argue
relative safety. But I have to say that if you think it's safer to give up
3000 ft of a 9000 ft runway in a light twin than to backtrack on a runway
with the controller's authorization, you either have negligible faith in the
abilities of ATC or remarkable faith in the workmanship of TCM.
with
how
reason
see
Isn't the next logical step to outlaw position-and-hold? Why would you ever
occupy the runway without a clearance to take off?
Julian Scarfe
  #39
Old November 28th 03, 09:13 AM
Peter Duniho
No. That's the whole point. A controller may well clear an airplane to
land right on top of you. You just don't know.
Not hard if the airplane is behind you. Bi-directional operations at Paine
are not uncommon.
Not hard if the controller is distracted dealing with an issue elsewhere at
the airport. That said, the controller needs only to fail to see ONE of the
aircraft, either the landing one or the sitting-duck one.
Oddly enough, runway collisions happen. Obviously pilots of other aircraft
DO in fact find themselves not being able to see other airplanes on the
runway in time to avoid them.
same time.
Funny thing about coincidences. They do exist.
A common generalization made about accidents is that they usually involve a
relatively long chain of events or decisions. Alter just one, and the
entire accident never happened. Even if your chain of events is as unlikely
to occur as you think it is (and I don't agree that it is), the point is
that the chain of events CAN certainly occur.
The one element you have control over is whether you actually get onto the
runway and wait for an extended period of time. Why miss that great
opportunity to break the chain of events? It's the only one you have.
I'm sure the sequence of events leading up to a great many accidents
(aircraft and otherwise) seemed like a good bet at the time.
up
With respect to my opinion of ATC: I simply don't see the point in trusting
them when there's no real need to. I have faith in their abilities, but I
prefer to deal in things that I *know* for sure rather than trusting someone
else to do them. Too often, a person I trust lets me down. Rarely, my life
is at stake, but that is the case here.
As far as giving up 3000' of a 9000' runway: a) that's not the only
alternative to backtaxiing -- at Paine, all you have to do is get off the
runway and taxi back on the parallel taxiway; and b) frankly, AFAIK 6000' is
*plenty* of runway from which to launch a Seneca II.
I would pick option a) -- using the taxiway -- but if you are really trying
to save time and are willing to reduce your safety factor to do it, the
stop-and-go is the right solution. Backtaxiing on the runway saves you
negligible time compared to taxiing back on the taxiway, while the
stop-and-go saves you serious time.
ever
As I mentioned, there are times in which it's an appropriate solution. At
Paine, the most common reason that clearance is used is when the controller
is trying to get as many departures out before the next landing. Allowing
an airplane to proceed onto the runway as the preceding airplane is taking
off helps this goal. Because the takeoff is expected immediately and the
"position and holding" aircraft can see where the landing traffic is, they
can evaluate the reasonableness of the clearance. Things are happening fast
enough that ANY delay is cause for concern and the pilot can get back off
the runway.
The problem that started this discussion is one of the length of time an
aircraft is expected to sit on a runway. Five, ten, maybe even fifteen
seconds to wait for an IFR clearance seems perfectly reasonable. But
several minutes? No, not to me it doesn't.
Like I said, I'm not going to take so extreme a position as to claim that
position-and-hold is NEVER appropriate. But I certainly feel that its use
should be restricted to very narrow situations where the hazard has been
reduced to the greatest extent possible, and especially to where the pilot
doing the position and hold has first-hand knowledge regarding the safety of
the operation (as opposed to trusting ATC to take care of everything).
Finally, let me remind you that the comment to which I took issue was the
"not sure why there's such a strong aversion to this." The bottom line here
is that the reason for the aversion is clear. There are definitely safety
issues, regardless of how significant you think they are. You might as well
say "not sure why there's such a strong aversion to spiders". After all,
all but a handful of spiders are safe. Yet, no one should be surprised when
they come across another person who has a strong aversion to spiders. It's
only natural. Your apparent argument to the contrary is a bit puzzling to
me, to say the least.
Pete
  #40
Old November 28th 03, 07:18 PM
Julian Scarfe
I think we've passed the 80:20 point on this debate so I'll let it rest.
Needless to say I don't agree with all you say, but you've raised some point
of which awareness can only be a positive thing for me and other readers.
No that wasn't what I intended, though I can see why you interpreted it that
way. I said it could be minutes between an aircraft receiving an IFR
clearance at the hold and being in a position to take off. In most cases I
would expect a clearance to come during the backtrack and to be available on
turnaround, within seconds. I don't think ATC would leave an aircraft
sitting there for minutes unless they anticipated a clearance from another
facility that didn't come.
here
well
when
It's
I think you do yourself no favours with that argument as fear of spiders
tends to be an irrational fear. You've eloquently outlined the hazards that
give rise to your aversion to sitting on the runway for longer than
necessary. They are quite rational, even if we disagree about the magnitude
of the risk.
Julian Scarfe
Associate Publisher Wanted - Aviation & Business Journals Mergatroide Aviation Marketplace 1 January 13th 04 08:26 PM
Associate Publisher Wanted - Aviation & Business Journals Mergatroide General Aviation 1 January 13th 04 08:26 PM
MSNBC Reporting on GA Security Threat Scott Schluer Piloting 44 November 23rd 03 02:50 AM
