Horsepower required for level flight question...
Old March 25th 04, 05:20 PM
BllFs6
Default Horsepower required for level flight question...
Hi all...
Was reading about a glider the other day....
It has something like a sink rate of 125 feet per minute at a 400 pound total
wieght when its going about 35 mph...
Now given that 1foot pound/sec = .00182 HP and the glider is being powered by
gravity....
125 * 400 / 60 = 833
833 * 0.00182 = 1.5
So, are those calcs right and it would only take 1.5 horsepower to keep that
glider going in level flight at 35 mph?
If thats the case..it makes me wanna get a glider, a weed wacker with a prop on
it and do some CHEAP, long, slow flights
take care
Blll
Old March 25th 04, 06:24 PM
Bill Daniels
Good observation.
Take my Nimbus 2C glider for example. The flying weight, less water
ballast, is about 1000 pounds. The Lift over Drag is 47:1 at 51 knots. (At
1440 pounds with water ballast, the L/D rises to 49:1 at 59 knots)
Divide 1000 by 47 and get 21.3 pounds of thrust needed for 51 Knot level
flight. Your weedwhacker engine would easily do that.
Gliders with small "sustainer" engines are widely available from Europe.
They call them "turbo" gliders as opposed to the "self launcher" gliders
with bigger engines. The engine can be retracted into the fuselage behind
the wing. If needed, the engine can be extended and air started with just
airflow through the tiny prop.
However, with 49:1 glide ratio, if well flown, you won't NEED the little
engine.
Bill Daniels
"BllFs6" wrote in message
Hi all...
total
by
gravity....
833 * 0.00182 = 1.5
that
prop on
take care
Blll
Old March 25th 04, 08:33 PM
Veeduber
Sounds about right but... (you KNEW there was a but, right?) :-)
You want thrust, not horsepower. Reality tends to differ from the
conversion-factor solutions due to velocity and prop losses. (Remember the NSU
'Prinz'? Ever see the little ducted-fan power pod that used the tiny Wankle?
Something like 6hp and TINY. With even a whiff of green air it could keep you
up all day after a winch launch.)
And of course the weght is no longer 400 but something more (ie, engine,
controls, fuel, mounting, etc).
But you're on the right track: Lift vs Weight, Thrust vs Drag (Notice that
horsepower is not mentioned :-) Once airborne, it doesn't take much to keep a
high-lift, light weight, aerodynamically efficient airframe flying. The tricky
bit is getting airborne to begin with :-)
(Then comes those horrible inverse equations dealing with drag (square it) and
power (cube it) any time you want to get there in a hurry.)
You did good, Bill. Your logic mirrors that of the Wright brothers which puts
you head & shoulders above 99% of the crowd.
-R.S.Hoover
Old March 25th 04, 09:04 PM
BllFs6
puts
-R.S.Hoover
Well...
I think you just insulted the Wright brothers
take care
Blll
Old March 27th 04, 03:41 PM
BllFs6
Hi Guys
Thanks for the replies Bill and Vee Duber!
Given that gliders are sooo darn efficient fuel wise and that it would take a
pretty minimal engine for one to self launch (20hp is my WAG for a single
seater).....why do we not see more airplanes that a cross between a glider and
a conventional plane?
Glider pilots hate engines? Powered pilots want barrel rolls and roaring
engines? Never the twain shall meet?
Seems to me if cost and the amount of time airborne are your primary desire
drivers then a "overpowered" glider would be the ticket...
Am I right in the main disadvantage of a powered glider is long take off rolls
and lack of fancy aerobatics? Other considerations I am missing?
And another question just popped into my head...anyone ever seen a canard
glider?
take care
Blll
Old March 27th 04, 03:45 PM
Boelkowj
Long wing spans are harder to land in a cross wind.
Larry
Old March 27th 04, 05:34 PM
Bill Daniels
"Boelkowj" wrote in message
Larry
Oh, I dunno, I have landed a glider in 20+ knots x-wind. My old Archer only
had a 17 knot demonstrated x-wind. Then again, with a 35 knot touchdown
speed less 20 knot headwind, just ignore the runway and land into the
wind. - only takes about 50 feet.
Bill Daniels
Old March 27th 04, 05:59 PM
Bill Daniels
Hi Guys
take a
seater).....
More like 50 - 60 HP to get a decent ROC.
We do, they are called "Touring Motorgliders" and are widely available.
See Grob 109 or the Super Ximango. They use Rotax 912's.
Aerobatic gliders are very common. Engines make aerobatics less capable
because of the weight and reduced load factors. Silent aerobatics in a
glider are a wonder to behold.
OTOH, Bob Carlson of Albuquerque has an ultralight sailplane with two model
airplane turbojets on it - goes like a scalded cat. We call it the "Dog
Whistle" behind his back. Bob has an airshow act doing aerobatics in it.
Self launch gliders are getting more popular all the time. In Europe, over
half the new gliders sold have self launch capability.
desire
If you want air time and low cost, go for a pure sailplane. Most of my
buddies are out on 300 mile, 6 hour flights every weekend. 6 hours from a
$20 tow is less than $4 an hour. Pure gliders stay in the air so long they
have to be plumbed for relief tubes.
BTW, I always thought of an X-15 or the Space Shuttle as an overpowered
glider.....
rolls
The disadvantage is cost, maintenance and complexity. The number of bells
and whistles in a motorglider darn near equals a twin.
glider?
Yup, Burt Rutan's "Solitare". Probably his worst design which is why you
haven't heard of it. Canards are very inefficient at low speeds and high
AOA - they make lousy gliders.
Bill Daniels
Old March 27th 04, 06:49 PM
Darrel Toepfer
4 to 6 seat capacity comes to my mind (needs/wants)...
Old March 27th 04, 08:34 PM
Tim Ward
"Bill Daniels" wrote in message
Larry
only
Bill Daniels
"That's sure a short runway".
"Yeah, but look at how _wide_ that sucker is!"
Tim Ward
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
