Airshares SR-20
Old December 2nd 03, 11:28 PM
ArtP
On Tue, 02 Dec 2003 21:33:44 GMT, "Jay Honeck"
As for flying it. The first year we flew 168 hours (25 hours of that
was flying to the authorized service center), the 2nd year we only
flew 60 hours. It is just to unreliable for anything but spur of the
moment flying (I gave up on Angel Flight since I don't have enough
faith in the plane to make a commitment).
That is truly sad. You must be terribly disappointed.
I am, and as a first time owner and low hour pilot (IFR, commercial,
but only 420 hours) it is beginning to sour me on flying.
Old December 3rd 03, 12:06 AM
Montblack
("Andrew Gideon" wrote)
But, just to be mean to myself, what are they planning to charge for their
-20s?
Price g
[2002]
In April, at Sun 'n Fun in Lakeland, Florida, Cirrus announced:
The new SR20 ver 2.0, an all-electric aircraft, will be available in 2003
http://www.cirrusdesign.com/aboutus/timeline/index.html
[2002] Sun 'n Fun announcement link (above)
Have the 20s gone all electric yet? Is it an option? Is it still to come?
I haven't kept up ...
Where are they at with diesel plans? HP? 20-D? 22-D?
Montblack
http://lumma.de/mt/archives/bart.gif
Old December 3rd 03, 12:52 AM
On 1-Dec-2003, ArtP wrote:
When it [SR-20] works, it is a roomy, automated, and slightly faster, and
much
more expensive 172. I get 130 knots at 9 gph. It carries 540 lbs with
full fuel and will fly for 5 hours with reserves.
According to the Cirrus website, the SR-20 cruises at 156 kts at 75% power.
We all know that "book" speeds are sometimes a tad optimistic, but 26
kts???. I get better than 130 kts on 9 gph in my Arrow, with a lot more
useful load.
If I bought an SR-20 and it only gave me 130 kts at best cruise performance,
I'd demand my money back!
-Elliott Drucker
Old December 3rd 03, 01:11 AM
Peter Duniho
power.
What's the fuel flow at 75% power? For a 200 hp engine, my guess is that
it's significantly more than 9 gph. Or conversely, it seems likely that the
9 gph isn't 75% cruise.
performance,
Art didn't say 130 knots was his "best cruise performance". He said that's
what he gets at 9 gph. I assume he used that figure because that's close to
the fuel flow in a Cessna at normal cruise settings (with a 160 hp engine),
and so gives a rough apples-to-apples comparison between the airplanes.
Pete
Old December 3rd 03, 02:02 AM
the 9 gph isn't 75% cruise.
that's what he gets at 9 gph. I assume he used that figure because that's
close
to the fuel flow in a Cessna at normal cruise settings (with a 160 hp
engine), and so gives a rough apples-to-apples comparison between the
airplanes.
In my Arrow, which like the SR-20 has a normally aspirated 200 hp engine, I
can true 135 kts at 65% with a fuel flow of around 9.4 gph. 9 gph would
probably be about 60%, give or take a little. Since for a given airframe
airspeed varies as the cube root of applied power, assuming equal propeller
efficiency (and that's a good assumption with a constant speed prop) 130 kts
at 60% would correspond to 140 kts at 75%, which, not surprisingly, is
almost exactly what I get in the Arrow. (141 kts to be precise.) That is
still a far cry from the 156 kt "book" 75% cruise speed for the SR-20.
-Elliott Drucker
Old December 3rd 03, 02:35 AM
Jeff
My fuel flow, at 65% power, for my 200 HP T-Arrow is about 12 gph , but at 65%
power I cruise at 150 KTAS (or better - I plan for 150 tho) and can fly non-stop
for 700 NM - But this is also flying at 8000-13000 ft.
Jeff
http://www.turboarrow3.com
performance,
Pete
Old December 3rd 03, 07:13 AM
Peter Duniho
[...] 130 kts
That's a number that a) is a lot closer to the published value than the one
you were originally complaining about, and b) is extrapolated by you, not an
actual reported value. You'll notice another SR20 owner reported nearly 150
knots on 10.6 gph. A variety of other differences could easily account for
the rest of the airspeed variability.
Pete
Old December 3rd 03, 07:17 AM
Peter Duniho
"Jeff" wrote in message
65%
non-stop
First of all, 12 gph for 130 hp sounds to me like a lot of gas. I can get
the fuel flow on my 270 hp engine down to 12 gph at around the same power
setting (60-65%). You might want to double-check your engine gauges.
Secondly, turbocharging isn't a fair comparison (you as much said this),
since you get to enjoy full power operations at the higher altitudes where
true airspeed increases.
Pete
Old December 3rd 03, 08:09 AM
Jeff
I have a shadin fuel flow monitor, it is pretty consistant with the airplanes
fuel flow gauge. I can lean it out more but that is best power setting. since I
only fly at 65% power, I dont want to lose what I have by skimping on the fuel
mixture. Plus this is a power setting, its not 65% due to altitude or fuel flow,
I set power (2400 RPM / 30" MP) for 65% then lean for best power.
the engine in the t-arrow is a cont. 6 cylinder, fuel injected, the normally
aspirated one is a 4 cylinder lycoming. why piper stopped making the T-arrow I
dont know, I think its alot better the the normally aspirated one (I have fown
both). But if it came down to buying a new airplane, An arrow or a SR20, the
arrow new is 271k (standard listing) - I think the sr20 would win out. Piper is
going to have to do something or cirrus is going to put alot of hurt on them and
other companies.
65%
non-stop
Pete
Old December 3rd 03, 10:00 AM
Thomas Borchert
Dan,
That seems awfully slow. Is that TAS? What altitude?
See the latest issue of Aviation Consumer for a comparison of the DA40
and the SR20. Average speed seems to be 145 to 150 knots TAS, at around
10 gph.
ArtP is quite well known here for not liking (his) SR20.
Thomas Borchert (EDDH)
Airshares SR-20 Guy Elden Jr. Owning 17 December 4th 03 04:07 AM
