John,
Gotta agree! I have only seen one picture of the panel; it looked intelligent and utilitarian (unless we get into an arguement regarding overhead switches). I liked the picture so much I added it to my Webshots screensaver (grin). Now you have me curious...argument over overhead switches? I guess I wasn't aware there was one, back in the '60s the crashworthiness folks found out that overhead panels killed pilots in crashes; the switches penetrated the skull, so the word went out to avoid them if at all possible. As the nose buried itself in the quick stop, and if there were any vertical loads on impact, the pilot either went forward into the overhead as it snapped down or simply smacked into the switches and sharp edges as the nose buried and the pilot hit the roof. Nasty things, overhead switches. Then, in the '70s, the CRM and human factors types figured out that pilots keep flying after they hit 40 and need bifocals, and they can't read the overhead panels with bifocals. I guess, perhaps, the word hasn't gotten to everyone (it is the one big drawback to the Airvan...you get young engineers and they don't always know the history of the subjects of aircraft design) so they have to make the same mistakes over again. Unfortunately, that could be expensive for Gippsland if they have a slow impact fatal and the front seat occupants buy it due to the overhead panel. I'm looking at your comment and wondering whether there are those who think overhead panels are attractive or cool and therefore use them because they don't know about the research that was done nearly 40 years ago. Now, I'm curious as to why designers/engineers would put in an overhead panel on an otherwise simple airplane. It can't be for panel space problems, I've flown far more complex airplanes, with the same size panel, in which the designers were able to put everything in front of the pilot. Any thoughts on the subject? All the best, Rick |
John,
Good points, especially about the instruments being installed in holes made with a shotgun...I think that is how the Piper Apache panel was designed. All the best, Rick (John Pelchat) wrote in message . com... (Rick Durden) wrote in message m... John, Gotta agree! I have only seen one picture of the panel; it looked intelligent and utilitarian (unless we get into an arguement regarding overhead switches). I liked the picture so much I added it to my Webshots screensaver (grin). Now you have me curious...argument over overhead switches? I guess I wasn't aware there was one, back in the '60s the crashworthiness folks found out that overhead panels killed pilots in crashes; the switches penetrated the skull, so the word went out to avoid them if at all possible. As the nose buried itself in the quick stop, and if there were any vertical loads on impact, the pilot either went forward into the overhead as it snapped down or simply smacked into the switches and sharp edges as the nose buried and the pilot hit the roof. Nasty things, overhead switches. Then, in the '70s, the CRM and human factors types figured out that pilots keep flying after they hit 40 and need bifocals, and they can't read the overhead panels with bifocals. I guess, perhaps, the word hasn't gotten to everyone (it is the one big drawback to the Airvan...you get young engineers and they don't always know the history of the subjects of aircraft design) so they have to make the same mistakes over again. Unfortunately, that could be expensive for Gippsland if they have a slow impact fatal and the front seat occupants buy it due to the overhead panel. I'm looking at your comment and wondering whether there are those who think overhead panels are attractive or cool and therefore use them because they don't know about the research that was done nearly 40 years ago. Now, I'm curious as to why designers/engineers would put in an overhead panel on an otherwise simple airplane. It can't be for panel space problems, I've flown far more complex airplanes, with the same size panel, in which the designers were able to put everything in front of the pilot. Any thoughts on the subject? All the best, Rick Rick, I'll open with that I offered the comment regarding overhead panels 90% in jest. I have heard the arguments regarding the difficulty of bifocal wearers properly seeing things and that has made sense. I have never heard the survivability aspect of the argument. It sounds a lot like the arguments for shoulder harnesses that cite the dents created by panel controls in the foreheads of deceased pilots. As you noted, many may not know about this issue due to their age (I offer no similar excuse). My acceptance of overhead panels is based on some of the other horrible panel arrangements of I have seen. It seems some aircraft had their switches, controls, and instruments installed with a 12-gauge shotgun. I agree that it never really seemed to be about space. Chances are that the designers were not being perverse but rather they were thinking about other things like ease of manufacture. I just never liked reaching all the way to the other side of the panel and thought putting things there was a poor idea. My experience with overhead controls was a long time ago and limited to trim using a crank that made (to me) absolutely no sense. The people building the big iron continue using overhead switch panels despite the amazing amount of real estate on the front panel being freed up on newer aircraft with multi-function displays. Part of the argument I have heard is that you put stuff up there that is not used very often. On the other hand, the extent that some of these panels go back seems to be an ergonomic and chiropractic nightmare. I wonder how much this was a factor for the Swissair crew in the MD-11 with the electrical fire off the Canada coast a few years back. The thought of trying to reach way back to isolate an electrical problem on a dark night does not appeal to me. This ends my humble $.02 and thanks for a great discussion. Best John |
John,
Why do I wonder whether the overhead in the Piper's was motivated by marketing folks who thought they looked cool and didn't have the faintest inkling of the research that had been done that concluded they were not a good thing to put in an airplane..... All the best, Rick (John Galban) wrote in message . com... (Rick Durden) wrote in message m... Now you have me curious...argument over overhead switches? I guess I wasn't aware there was one, back in the '60s the crashworthiness folks found out that overhead panels killed pilots in crashes; the switches penetrated the skull, so the word went out to avoid them if at all possible. snip I'm looking at your comment and wondering whether there are those who think overhead panels are attractive or cool and therefore use them because they don't know about the research that was done nearly 40 years ago. Now, I'm curious as to why designers/engineers would put in an overhead panel on an otherwise simple airplane. It can't be for panel space problems, I've flown far more complex airplanes, with the same size panel, in which the designers were able to put everything in front of the pilot. If you've got any contacts a Piper, you might want to ask them. I flew one of their new Archer IIIs last year and was really put off by their new overhead switch arrangement. The switches were located at the top of the pilots side windshield and blocked the view up. I can't see any reason why they would do this, as the previous location for these switches on the panel was quite good (and remained unchanged for a couple of decades). John Galban=====N4BQ (PA28-180) |
Hey, wait a minute, I resemble that remark...
Fat Albert the Apache "Rick Durden" wrote in message m... John, Good points, especially about the instruments being installed in holes made with a shotgun...I think that is how the Piper Apache panel was designed. All the best, Rick (John Pelchat) wrote in message . com... (Rick Durden) wrote in message m... John, Gotta agree! I have only seen one picture of the panel; it looked intelligent and utilitarian (unless we get into an arguement regarding overhead switches). I liked the picture so much I added it to my Webshots screensaver (grin). Now you have me curious...argument over overhead switches? I guess I wasn't aware there was one, back in the '60s the crashworthiness folks found out that overhead panels killed pilots in crashes; the switches penetrated the skull, so the word went out to avoid them if at all possible. As the nose buried itself in the quick stop, and if there were any vertical loads on impact, the pilot either went forward into the overhead as it snapped down or simply smacked into the switches and sharp edges as the nose buried and the pilot hit the roof. Nasty things, overhead switches. Then, in the '70s, the CRM and human factors types figured out that pilots keep flying after they hit 40 and need bifocals, and they can't read the overhead panels with bifocals. I guess, perhaps, the word hasn't gotten to everyone (it is the one big drawback to the Airvan...you get young engineers and they don't always know the history of the subjects of aircraft design) so they have to make the same mistakes over again. Unfortunately, that could be expensive for Gippsland if they have a slow impact fatal and the front seat occupants buy it due to the overhead panel. I'm looking at your comment and wondering whether there are those who think overhead panels are attractive or cool and therefore use them because they don't know about the research that was done nearly 40 years ago. Now, I'm curious as to why designers/engineers would put in an overhead panel on an otherwise simple airplane. It can't be for panel space problems, I've flown far more complex airplanes, with the same size panel, in which the designers were able to put everything in front of the pilot. Any thoughts on the subject? All the best, Rick Rick, I'll open with that I offered the comment regarding overhead panels 90% in jest. I have heard the arguments regarding the difficulty of bifocal wearers properly seeing things and that has made sense. I have never heard the survivability aspect of the argument. It sounds a lot like the arguments for shoulder harnesses that cite the dents created by panel controls in the foreheads of deceased pilots. As you noted, many may not know about this issue due to their age (I offer no similar excuse). My acceptance of overhead panels is based on some of the other horrible panel arrangements of I have seen. It seems some aircraft had their switches, controls, and instruments installed with a 12-gauge shotgun. I agree that it never really seemed to be about space. Chances are that the designers were not being perverse but rather they were thinking about other things like ease of manufacture. I just never liked reaching all the way to the other side of the panel and thought putting things there was a poor idea. My experience with overhead controls was a long time ago and limited to trim using a crank that made (to me) absolutely no sense. The people building the big iron continue using overhead switch panels despite the amazing amount of real estate on the front panel being freed up on newer aircraft with multi-function displays. Part of the argument I have heard is that you put stuff up there that is not used very often. On the other hand, the extent that some of these panels go back seems to be an ergonomic and chiropractic nightmare. I wonder how much this was a factor for the Swissair crew in the MD-11 with the electrical fire off the Canada coast a few years back. The thought of trying to reach way back to isolate an electrical problem on a dark night does not appeal to me. This ends my humble $.02 and thanks for a great discussion. Best John |
![]() "Kevin" wrote in message news:7mQDb.410999$ao4.1343213@attbi_s51... John Pelchat wrote: (John Galban) wrote in message . com... John, I have not sat in any of the New Pipers, but no one I know has said anything nice about the overhead switches on them. IMHO, the switches were very well placed when they were located in the center of the panel. I never cared for the side wall placement I have seen on Lances and some other Cherokee models. However, if someone were to offer me a cherry Cherokee with the side switches, it would not be an automatic no. Best John There are some more photos of the Airvan flight deck at this website. It shows detail for the overhead panel. /www.njwg.cap.gov/Operations/Gippsland/ This one seems a lot more efficient in a refurbished Rockwell JetProp 1000 (but it's an "eyebrow panel" not specifically an "overhead" panel. http://www.eagle-creek.com/magic_pop...s/cockpit3.jpg |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
