C182 Stabilized Approach
Old December 15th 03, 10:10 PM
III
Default C182 Stabilized Approach
I know this question pertains to aircraft and piloting in general, but
I'm wondering what C-182 pilots do.
I'm sold on the benefits of a stabilized approach.
I consider a stabilized approach to mean that power, flaps, and trim
are set right after turning final (assuming a standard pattern) and
then aren't adjusted until starting the roundout and flare. I like to
land with the flaps fully extended. If I turn final in a Skylane and
extend the flaps to 40 degrees, it takes a lot of power to make it to
the threshold (given a 1/2 mile final, which is not unheard of at our
busy airport), so a stabilized approach requires a lot of power to
drag the plane in.
I've taken to turning final with two notches of flaps out, leaving the
power at about 1700 RPM, and then adding more flaps as needed to
follow a path to the threshold and finally adding the remaining flaps
on very-short final. That's not a stabilized approach. It works, but I
know I could be doing better.
I could stabilize the approach using two notches of flaps, but I'd
rather use them all. I could use all the flaps on the entire trip down
final, but I'd rather not drag the plane along.
My CFI uses incremental flaps, my partner advises using two notches
and then maybe kicking them all in at the end (although I don't know
what he does when he's alone), and a more-experienced pilot friend
(but not in 182's) just commented that I should be flying a stabilized
approach.
So, what do other Skylane pilots do?
Thanks.
Old December 15th 03, 10:38 PM
Neil Gould
Hi,
Disclaimer: I'm not a C-182 pilot.
Recently, III posted:
drag the plane in.
My idea of a stabilized approach is one in which you *will* make the
field. So, in your case, I'd either not put 40 degrees of flaps in until
the field is made, or use a steeper AOA if for some reason I *had* to use
full flaps. There's not a lot of value to being stabilized if that puts
you short with any loss of power.
Regards,
Neil
Old December 15th 03, 10:40 PM
Dale
(III) wrote:
Are you talking about an instrument approach or VFR landing?
I think defining a stabilized approach as meaning you can't change flap
settings may be a litte strict.
I would continue to use 10-20 degrees of flaps as you turn final, then
go to full flaps on short final when your landing is assured.
I personally don't fly a stabilized approach VFR. I am constantly
slowing as I get closer to the runway. Can't see any reason to be at a
low energy state way out from the runway.
drag the plane in.
approach.
Thanks.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old December 15th 03, 11:01 PM
In the 182RG I enter the pattern and slow to 130 knots on downwind then
gear, 10 degrees of flaps, and carb heat all come out 1/2 way down the
runway at about 20inches MP, this slows me to 100 knots
across from the numbers prop goes all the way in and reduce to 1500 RPMs
20 degrees of flaps on base now gives me 80knots indicated
turn final and bring flaps down to 30 degrees
hold it to 80 over the fence with touch down at around 65, adding just a
touch of power to arrest the sink if I'm heavy
I go through C.G.U.M.P.S. on each leg.
I rarely use 40 degrees of flaps because of the huge increase in drag with
little increase in lift requiring the increase in power you mention, I'd
rather fly a stabilized approach on the front side of the power curve than
run out of power and altitude both at the same time. Plus having to add
full power for a go around with 40 degrees of flaps hanging out provides for
an instant lesson in torque, P-factor, and asymmetrical thrust all happening
with very little altitude for slow reactions or improper trim settings.
For a short field landing I'll use the full 40 degrees of flaps and come in
carrying a small amount of extra power but I'll wait to put in that last
notch of flaps until on short final. This is a good point to remember your
slow flight training. The 182RG will fly at 37knots with gear and full
flaps out, but you're going to be very nose high, it requires nearly full
power and you'd better be on those rudder pedals. This doesn't leave you
much of an "out" when you're close to the ground.
If I need to loose altitude, I'd rather slip it down to where I need to be
as early as possible rather than throwing in all the flaps and chopping the
power. If you find yourself high after you're stabilized, then you slip to
loose the unwanted altitude once you take out the slip the airplane returns
to it's original stabilized decent.
If I'm dealing with a heavy crosswind component, I'll generally limit my
flaps to 20 degrees and keep the speed up.
The 182 will let you do a lot with it as far as landings go. I think the
most memorable landing I made with it was when advised by tower to keep my
pattern tight and landing short I was able to put in 40 degrees of flaps on
base, cut it to an 1/8 mile final slipping all the way down to 200 ft land
on the numbers and make the first taxi way. Inbound traffic had to ask the
tower where I had disappeared to.
Ok, now that I've opened up the whole slipping with flaps debate, read and
follow your POH, nothing in the 182RG's prohibiting it nor recommending
against it.
That's just the way I generally do it, or attempt to do it. YMMV.
Jim Burns III
Remove "nospam" to reply
Old December 15th 03, 11:26 PM
Tony Cox
III" wrote in message
om...
Good idea. Then if you have a heart attack on final, you're
pretty much guaranteed to touch down in one piece.
It's safer to remove power rather than add flaps to follow the
glidepath. That way, if you loose power through an engine failure,
you'll be in better shape. Also, if you need to go around, flaps
are already set and you don't need to mess with them.
You can put in full flaps without power (so you're not dragging it).
I find that it startles many passengers because the approach angle
is very steep and the descent rate is alarming, so I tend not to do it.
On downwind, flaps 10, trim for 80knts, prop high rpm
On base, flaps 20, trim for 70, 1700rpm.
On final with crosswind and/or nervous passenger and/or
long runway
....keep flaps 20, trim for 65, power idle.
On final, no x-wind, more than 2000' runway
....flaps 40 over fence, trim 65, power idle.
On final, less than 2000' runway
.... flaps 40, trim 60, power to control glideslope & descent rate.
Dr. Tony Cox
Citrus Controls Inc.
e-mail:
http://CitrusControls.com/
Old December 15th 03, 11:30 PM
Michael 182
I have a TR-182 and I fly it almost exactly the same way, although a little
slower on the downwind leg. Good description, Jim.
Michael
"Jim" wrote in message
gear, ...
Old December 16th 03, 12:41 AM
Magic Fingers
I am a CFII and I own a C-182Q (fixed gear). I teach, and fly, as follows:
1) slow and trim to 90 knots abeam the numbers (about 15 inches/prop
forward).
2) 1 "notch" of flaps will slow you to 80 with little, if any, trimming.
3) Turning base and adding another "notch" will slow you to 70 knots, again,
4) Turn final and add the 3rd "notch" to slow you to 60-65 knots...again,
will little, if any trimming.
The book says "normal approach" is 60-70 KIAS, so this works quite
well....consistently. Of course, you will be gradually throttling back and
making small trim corrections (if necessary).
I stress CONSISTENCY. Do the same thing, the same way, EVERY TIME (making
minor corrections/adjustments as necessary for wind, turbulence, etc.) and
you'll likely get consistently good landings.
Here's a tip: Add just a teensy bit of power on the round out to help raise
that heavy 182 nose and you'll grease it on.
PB
following this procedure"Tom Fleischman"
rthlink.net...
In article , III
drag the plane in.
approach.
I don't fly a Skylane very often, but I do fly a 180HP Arrow and a
Beech Debonair on a regular basis.
In the Arrow I use 1 notch of flaps when I drop the gear abeam the
numbers, then 2nd notch after turning final. Prop goes full and trim
for 100 MPH and adjust throttle for a 450FPM descent, keeping 2 notches
of flaps all the way, milk the power out over the fence and land. I
hardly ever use the 3rd notch unless its a very short field. This
normally results in a well stabilized approach all the way down.
In the Deb I drop the gear on downwind with approach flaps of about 15
degrees. The MP goes to 15-17" on final, prop full, trim 90 kts, and
flaps don't go full until short final. With flaps full the power comes
out and then flare. The approach is stabilized until the configuration
change and then it's time to begin the flare.
Here's a good article by John Deakin on Stabilized approaches:
http://www.avweb.com/news/columns/182047-1.html
Old December 16th 03, 12:54 AM
Ronald Gardner
I use 2 notches 90% of the time. The only time I go to full flaps is when
landing on a strip that is short, Say 2,200 FT or less. I find it is much
easier on the power and I like to be able to make the runway without
power. 1/2 mile out and some sort of engine problem leaves little time to
plan at 5 or 800 FT.
Ron
drag the plane in.
approach.
Thanks.
Old December 16th 03, 01:54 AM
john smith
For VFR circuit patterns, I fly the same as PB and Tony.
I think Jim is a little fast, causing him to float down the runway
before touching down.
For IFR ILS... at the outer marker, needles centered... 10 degrees
flaps, 15-16 inches manifold pressure, rpm takes care of itself since
you are below governor oil pressure. This will give you 90 knots and
match the glideslope.
Old December 16th 03, 02:37 AM
john smith
I need to correct myself, because Jim's aircraft is an RG, it is heavier
and therefore my require more speed.
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
