#31
On Tue, 6 Apr 2004 17:12:07 -0500, "Highfllyer" wrote:
I have been to China several times. I would encourage something that you could maintain easily in China. I would suggest you look for one of the Piper clones in a homebuilt. Look for pipe and rag construction. Find a WWII observer project with no engine. L2, L3, or L4. Maybe even L5. I dunno, HF...you're recommending he try to ship a warbird from the US to the PRC. I can think of all sorts of agencies that might have heartburn over that one... :-) Ron "Fox two" Wanttaja |
#32
That's right. I don't really want to smuggle millitary equipment. And
I'm nore sure those warbirds (a warbird is a warbird) are cheaper. I thought they are quire desirable especially the ones in good conditions. Jizhong On Wed, 07 Apr 2004 01:34:58 GMT, Ron Wanttaja wrote: On Tue, 6 Apr 2004 17:12:07 -0500, "Highfllyer" wrote: I have been to China several times. I would encourage something that you could maintain easily in China. I would suggest you look for one of the Piper clones in a homebuilt. Look for pipe and rag construction. Find a WWII observer project with no engine. L2, L3, or L4. Maybe even L5. I dunno, HF...you're recommending he try to ship a warbird from the US to the PRC. I can think of all sorts of agencies that might have heartburn over that one... :-) Ron "Fox two" Wanttaja |
#33
Yes,
I actually looked up the Taylorcraft as they are very close to a cub. It looks like it's relatively easy to get a 65hp project. I might consider that. Thanks. Jizhong On Mon, 05 Apr 2004 20:52:16 -0500, Carl Ellis wrote: Check out the Taylorcraft. A 100hp F-19 gets off the ground in about 350' and will climb at 1000' per minute on a cool day. I've seen mine climb around 700 fpm at 70 degrees with two of us on board. There are lots of them on floats. The 65 and 85 hp models perform very well too. The factory is spinning up to make new birds: www.taylorcraft.com. They will be available with engines from the O-235 to O-360. |
#34
What's the pro and con between a metal and fabric model.
Metal: more ruggered but difficult to repair, qieter(?),heavy Fabric: easy to repair, noisier(?), light more... Jizhong |
#35
Can a BC12D take an o-200 or o-235 easily?
#36
jczhonghe
Think Dwayne (?) Cole flew a clipped wing T-craft in air shows for years and walked away in one piece and died in his bed with his boots on ![]() You might check and see what he got approved as mods to this bird and if they would apply to one you bought (not clipped wing for acro)? Maybe someone can point you where to go to check that bird out and how it was modified. You mentioned noise. Any A/C of that era will be noisy and you will need some type of ear protection (or loose your hearing like I have from aircraft noise) .. Fly safe and be lucky. Big John `````````````````````````````````````````````````` `````````````````````````````````````````````````` ``````````` On Tue, 06 Apr 2004 23:25:53 -0700, wrote: Can a BC12D take an o-200 or o-235 easily? Jizhong On Mon, 05 Apr 2004 20:52:16 -0500, Carl Ellis wrote: Check out the Taylorcraft. A 100hp F-19 gets off the ground in about 350' and will climb at 1000' per minute on a cool day. I've seen mine climb around 700 fpm at 70 degrees with two of us on board. There are lots of them on floats. The 65 and 85 hp models perform very well too. The factory is spinning up to make new birds: www.taylorcraft.com. They will be available with engines from the O-235 to O-360. |
Curtiss Pusher Model D | Home Built | 12 | February 22nd 18 10:50 PM | |
Engine Questions | Bill A. | Home Built | 28 | January 22nd 04 04:27 AM |
3.8 liter V6 Ford PSRU model year compatibility | James W Brackett | Home Built | 2 | October 30th 03 06:20 AM |
Scripps model 302 V12 engine | butch burton | Home Built | 3 | October 1st 03 02:56 PM |
Aerocat at Oshkosh | randall g | Home Built | 5 | August 6th 03 07:02 PM |
