I am planning on a flight to a ski resort.
This will be the first time I adventure flying to the mountains and temperatures below freezing. I have 170 hrs TT and will be flying VFR only. What should I be considering? I currently use aeroshell 100W I believe I should change it? How to clean the plane from ice and snow the day we plan to leave? Any other thing to consider? Thanks for your help. |
"Victor" wrote in message om... What should I be considering? I currently use aeroshell 100W I believe I should change it? Put in 15W50. Even the Shell 80 is thicker than what most engines recommend for cold weather ops. |
Which resort are you going to? For instance, here in Western Pennsylvania,
the Seven Springs resort has a private landing strip very close to the main lodge. There are a number of things to think of before you use it, though. Since it's private, you may need to call for permission to use it. Also, they don't make much revenue from the airstrip, since most people drive in. When it snows (and it snows there alot), the roads and parking lots are cleared first. The airstrip is not as big a priority. So it may pay to call ahead. |
where are you flying too? quite a few ski resorts around. i live in colorado
and eagle county EGE is most centrally located to Vail and all Summit County resorts. It's in a decent size valley and much easier than Aspen. And you may see Kobe in the FBO. Get a colorado aeronautical chart to see various passes and mountains. If weather's bad you can fly to centennial or jeffco in denver and drive up for an hour and if you're going to southwestern colorado use durango, DRO - another easy big valley aiport have fun and watch out for fast moving cold fronts and storms. |
Which ski area?
Are you allowed to park the aircraft there? Have you had any mountain flying training? What type of aircraft are you using? |
Will be flying to Ruidoso,NM I have flown mostly in flat south Texas.
And will be flying to Ruidoso later continuing to Las Vegas. |
"Blanche" wrote in message ... Which ski area? Are you allowed to park the aircraft there? Have you had any mountain flying training? What type of aircraft are you using? Around here you can fly to Garrett County (Wisp). You can't fly to 7 Springs. While there is an airport there, it's not available when the snow is on the ground (the ski slope cuts right across it). |
Victor wrote:
Will be flying to Ruidoso,NM I have flown mostly in flat south Texas. And will be flying to Ruidoso later continuing to Las Vegas. Well, Sierra Blanca Airport (SRR) is the public airport at Ruidoso. But as Blanche pointed out you get into mountain flying area with all the joy (some of it I learned the hard way ;*), such as leaning, strong up/down drafts, waves and rotors, ... Ice shouldn't be too much of a factor if you fly VFR. Typically the NM air is rather dry (with exceptions, of course). Also, before departing, if you remove potential snow from the plane and put the plane in the sun, the ice will often just disappear (sublimate) rather quickly. Also the MOAs above Ruidoso shouldn't be a factor if you stay below 12500ft MSL (except for the TALON LOW MOA southwest of Ruidoso which starts at 300AGL). Call ahead to check for snow on the rundway and have your survival gear ready - there is awful lot of space in the Land of Enchantment ;*). Chris |
.... wrote:
Victor wrote: Will be flying to Ruidoso,NM I have flown mostly in flat south Texas. And will be flying to Ruidoso later continuing to Las Vegas. Well, Sierra Blanca Airport (SRR) is the public airport at Ruidoso. But as Blanche pointed out you get into mountain flying area with all the joy (some of it I learned the hard way ;*), such as leaning, strong up/down drafts, waves and rotors, ... Ice shouldn't be too much of a factor if you fly VFR. Typically the NM air is rather dry (with exceptions, of course). Also, before departing, if you remove potential snow from the plane and put the plane in the sun, the ice will often just disappear (sublimate) rather quickly. Also the MOAs above Ruidoso shouldn't be a factor if you stay below 12500ft MSL (except for the TALON LOW MOA southwest of Ruidoso which ^^^^^^^^^ make that southeast - Chris starts at 300AGL). Call ahead to check for snow on the rundway and have your survival gear ready - there is awful lot of space in the Land of Enchantment ;*). Chris |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 27th 04 12:24 AM |
| Progress on Flying Car | Steve Dufour | General Aviation | 5 | December 19th 03 04:48 PM |
| FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 01:07 AM |
| the thrill of flying interview is here! | Dudley Henriques | Piloting | 0 | October 21st 03 08:41 PM |
