LED tail strobe
Old April 12th 04, 02:42 AM
Jeff Peterson
Default LED tail strobe
I am building an LED tail light for my Lancair 360. It uses 6 ea 5
watt luxeon LEDs. I can strobe 1 amp through each of these which
should give enough light to satisfy the FAA regs. Runs surprisingly
cool. I have posted photos he
http://w1.lancair.net/pix/album01\
Its not quite finished, but I thought you might like to see my
progress.
cheers,
Jeff
N273CK stilll building.
ps thanks to Eric Jones for his posts on the Lancair Mail List, his
web pages on the subject and many emails and phone calls.
Old April 13th 04, 03:09 AM
Jeff Peterson
here is a more specific url...
http://w1.lancair.net/pix/led-strobe
-Jeff
(Jeff Peterson) wrote in message . com...
progress.
cheers,
Jeff
Old April 13th 04, 03:26 AM
Dean Head
Jeff,
Would you consider sharing your design for the driver electonics?
Dean
Cozy MK4
BKV FL
"Jeff Peterson" wrote in message
om...
progress.
cheers,
Jeff
Old April 14th 04, 06:15 AM
Robert Loer
Neither link will work for me????
"Dean Head" wrote in message
Jeff,
Dean
Cozy MK4
BKV FL
om...
progress.
cheers,
Jeff
Old April 14th 04, 01:41 PM
Blueskies
try: http://www1.lancair.net/pix/led-strobe
Dan D.
"Jeff Peterson" wrote in message om...
-Jeff
progress.
cheers,
Jeff
Old April 14th 04, 09:44 PM
Jeff Peterson
sure...I haven't designed that yet, but when I do I will post it...Jeff
"Dean Head" wrote in message .. .
Jeff,
Dean
Cozy MK4
BKV FL
Old April 17th 04, 06:15 AM
Jay
You can find examples on how to power the LEDs on the manufacturer web
site.
Having said that...
What is typically done is the LEDs are just put in series with a
current limiting resistor. This forms a circuit akin to a kind of
voltage regulator called a "zener regulator". LEDs have a fixed
forward voltage for the recommended drive current, say for example its
2.8 volts for a green LED. Divide the power supply (e.g. 12V) by the
forward voltage of the LEDs and drop any fraction (12/2.8=4.3 make
that 4 even) Put those in series with a current limiting resistor that
will drop the fraction (.3V). So lets say the recommended current for
the LED is 20mA. Ohms law is R=E/I, so that gives you a resistor
value of .3V/.02A=15 ohms. Check power to make sure it won't over
heat (P=IV) so thats .3V*.02A=.006W so a typicial 1/4 watt resistor is
fine. You must of course have some kind of resistor in series to limit
the current. If you math works out that you need no resistor, put one
less LED in series and then recalculate the limiting resistor. Put
the LEDs and resistor in series (in any sequence) observing the proper
polarity of the LEDS. If you hook up your entire string backwards, no
harm will be done, but if you happen to solder one LED backwards, it
will likely be toasted on power up.
Need more than 4 LEDS? Replicate this circuit in parallel as many
times as you need to get the luminous flux you need.
Of course the numbers (Vf, If) used here are for the older style
single chip LEDS. The parts that are getting everybody excited these
days are the multi-chip variety whose forward voltage and current will
vary alot from my example.
Jeff,
Dean
Cozy MK4
BKV FL
om...
progress.
cheers,
Jeff
Old April 17th 04, 07:00 AM
Jim Weir
Before everybody in the Western Hemisphere blows a bucket full of light emitting
diodes, would you care to calculate the resistor one more time? And perhaps
post a retraction?
(Jay)
-You can find examples on how to power the LEDs on the manufacturer web
-site.
-Having said that...
-the LED is 20mA. Ohms law is R=E/I, so that gives you a resistor
-value of .3V/.02A=15 ohms.
Um, no. Suppose the diode has a forward voltage drop of 2.8 volts (that's not a
common value, but I'll give it to you for argument.
Now the power supply (battery) is a 12 volt supply, but 14.2 volts at full
charge with the alternator going, so the drop across the series resistor is
going to be
14.2 minus 2.8 equals 11.4 volts, which is the voltage across the resistor.
This current limiting resistor is going to have 20 mA flowing through it, so Ohm
tells us that resistance equals voltage divided by current. In this case, 11.4
volts divided by 20 mA gives us a resistor of 570 ohms (560 is the nearest
standard value).
You put your calculated 15 ohm resistor in series with this diode and I
guarantee you that the SNAP you hear is the gallium aluminum arsenide
semiconductor of the diode being sacrificed on Ohm's altar.
I'm serious. You owe the newsgroup a correction before somebody takes your
error and blows up a whole bunch of LEDs.
http://www.rst-engr.com
Old April 17th 04, 11:38 AM
Blueskies
Jim, he put 4 LEDs in series, each with it's '2.8' volt drop, and had only the remaining voltage to drop across. It does
look incorrect, however, in the voltage to drop across. 4 x 2.8 is 11.2. While-running voltage in 12 volt system is 14.2
(to use your number) leaves 3 volts to drop across....
Dan D.
"Jim Weir" wrote in message ...
post a retraction?
(Jay)
-site.
going to be
standard value).
Old April 17th 04, 01:34 PM
GeorgeB
Your concept is reasonable, but there are some significant problems.
The forward voltage varies with temperature, and the power supply
LIKELY varies over time. As you have it, if the fwd voltage dropped
0.1v, and the supply did not change, you would have 0.7 vs 0.3 across
the resistor, for over 2x the current ... maybe a real problem.
Now, let's have the alternator charging the battery, and have it at
15.5V or so ... now I have 3.8 volts across that current determining
resistor ... 12 times the "design". OUCH.
Now let's have the alternator fail, the battery voltage drop to 10.5V.
Your series string will draw no current and give no light ... and you
are in an emerency situation that is exactly when someone needs to see
you.
What is the solution ...
There are "constant current" devices. I have used them, and they
work allowing operating this string with probably 3 LEDs over the
range at visually constant brightness.
You can put 2 in a string allowing the current determining resistor to
allow a power range varying over about 2:1, 10V to 15V.
You can put 3 in a string like above, power will vary over about 4:1.
You can design a pulse system turning the LED on for (maybe) 0.1ms
then off for maybe 5ms and PROBALBY not overdrive (into damage) the
LED and put "as many" as you want in parallel. The driver will likely
be a FET.
I was taught to allow about half the voltage for the resistor, half
for the LED string unless I had current control. In the "old days",
for current control we used an emitter resistor in a common emitter
circuit, 2 or 3 diodes to set bias (single vs darlington), and the
LEDs between collector and V+. There are other (better) ways, but
everyone understood this one.
I disagree that there will be damage with any in backwards. The
reverse voltage will almost certainly be higher than the forward
voltage, so there won't be any current drawn. If there is, you still
would have less than correctly wired.
Jeff,
Dean
Cozy MK4
BKV FL
om...
progress.
cheers,
Jeff
FS: RV-8 Tail Kit Mike Woodall Home Built 0 January 4th 04 02:38 AM
twin tail questions Kevin Horton Home Built 12 January 2nd 04 03:21 PM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 10:48 PM
LEDs with Strobe lights pekka1510 Home Built 11 August 31st 03 11:36 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Home Built 4 July 26th 03 11:34 AM
