Question about epoxy resin chemistry..
Old April 13th 04, 05:52 PM
Ernest Christley
Richard Lamb wrote:
Blueskies wrote:
Yes, I guess that would be a big piece of glass (don't take anything out of context here!). Do the plans/instructions
have any other suggested way to lay up the panels?
As far as bending the finished panels, a two layer lay-up will be quite flexible, even fully cured, and as long as you
don't have to wrap around the LE I'm sure you will not have any problems with cracking. Have you looked at the
http://www.westsystem.com/ site? Good stuff...
Dan D.
I've been told that West does indeed make a laminating resin,
but this isn't it.
West 105/205 is absolute best stuff I've ever used - on wood.
It will probably be great on wood/foam structures.
But it's not what I ever use (again) for laminating glass fabrics.
I used to use Dow 330 / 147(?) but my source quit carrying it
(because I was the only one buying it?)
My impression is that resins like 330 that don't use MDA (Methyl
Diethel Amines???) share a common "problem". At low temperatures
they tend to "separate out". The resin has an odd lumpy look on
the surface and there will be a lump of soft rock candy in the center.
It is real simple to correct by immersing the resin container in hot
water for a while. When the soup is clear again, it's ready to use.
But if the resin is at all "crystallized", it won't completely set -
ever.
It even says so in the directions!
For those who read such things...
Got AeroPoxy(?) last resupply to make a new cowling for Leo's
Super Zodiac. I've used it before, no complaints (other than the
MDA toxicity?).
So, what is it that you are building?
Richard
Dyke Delta JD-2. http://www.ernest.isa-geek.org for the whole story.
The skins, turtleback and cowling are all fiberglass. Some builders
have also glassed the belly, tailfin and control surfaces (plans call
for fabric there).
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old April 13th 04, 06:07 PM
Ernest Christley
The directions say to lay it up on a couple pieces of MDF laid
side-to-side, with a piece of tape down the center. I have to cut forms
for the stainless steel ribs, so I thought an improvement on this
technique might be to use the forms to shape the MDF so that the
resulting layup is nearly the correct shape already. Very little
bending==very little built up stress.
The biggest improvement would be not to have to make the skins at all.
I've looked at G-10 and FR4, and have found several manufactures with
lots of data sheets. Reading them, I keep hearing that eerie refrain,
"You are in a maze of rooms, all slightly different..."
Looked there. Good stuff...IF you're building a boat, or a trailer, or
a chair. Goes back to what I said before. Every manufacturers claim
that what they have is good for whatever you're doing. While that just
may be true, but I don't trust it to be, and it is so much unfamiliar
territory that I just keep getting lost. What I need is a map to help
seperate the hype from the information.
Veeduber
Old April 14th 04, 01:14 AM
Richard Lamb
Dan D.
but this isn't it.
ever.
MDA toxicity?).
Richard
for fabric there).
Veeduber
I remember now, Earnie. Sorry.
What you really need is a store window that you can make up some
flat glass panel stock on.
I've never done one that size before, but I've laid up light flat
stock on the glass patio door...
Advice? CLEAN it first! Sterile is good.
Then spray a coat of PVA, and slap it up there.
I used a 5 mill plastic cover over the wet fiberglass,
and a piece of plywood for a pressure plate
Vacuum would work better, of course, but I couldn't hook
the TV up to the glass door (TV sucks, doesn't it!)
So what did Dyke recommend?
Richard
Old April 14th 04, 04:30 AM
Ernest Christley
Richard
He's at Sun'n'Fun. Waiting for him to check back in to our email list.
I do like the store glass window idea, though. I have an uncle who
'collects' that sort of thing. Time to investigate.
Veeduber
Old April 14th 04, 01:44 PM
Blueskies
Big piece of glass...again!
Dan D.
"Ernest Christley" wrote in message . ..
Richard
Veeduber
Old April 14th 04, 06:43 PM
Ernest Christley
Just to pass on a nugget I found....here's some excellent information on
what all of those strange words surround epoxy means. I only had a
couple semesters of college chemistry and I understood most of it (I
think), so you guys shouldn't have any problem.
http://www.epoxyproducts.com/25points4u.html
Veeduber
Old April 15th 04, 12:55 AM
Richard Lamb
Veeduber
Nice on, Earnest.
There is a lot more too...
http://www.epoxyproducts.com/map.html
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Vacuum Baggin vs. Resin Infusion Steve Home Built 0 August 21st 03 05:25 AM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 06:10 PM
question: differences between epoxy layup and plaster Morgans Home Built 3 August 6th 03 04:46 AM
