#161
"Gary Mishler" wrote in message news:N3yKb.764106$Fm2.730963@attbi_s04...
"Ron Natalie" wrote in message m... "Gary Mishler" wrote in message news:eBoKb.745162$HS4.5776347@attbi_s01... "running with scissors" wrote in message om... "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances Actually, it depends on the aircraft. Aircraft are certified to certain "differential pressures" which is the difference between in the inside cabin pressure and the outside ambient air pressure. We were talking about transport aircraft. US certificated transport aircraft must keep the cabin altitude below 8000'. Yup, I know. The Lear 60 is a transport category aircraft, certified under Part 25, and it's cabin is normally around +/- 6,500ft. Previous poster said cabin pressure is normally *at* 8,000 and I was just pointing out that it depends on the aircraft. Manufactures of transport category corporate jets seem to take pride in pointing out to potential customers that their jet can maintain a lower cabin altitude at cruise than the competitors, which all depends on the certificated max psid. christ on a bike. i knew this would happen. i stated "normally at 8,000ft", of course there are variations in type, SOP and so on. i really didnt want to spend hours typing out a list types and representative pressurization variations or a list of SOP's for various operators of various types as either way it is going to depend on what is set on the selector. say 8,000ft and someone will say "we fly at 7,500". the answer is in the FAR's. |
#162
message m... "they" dont. cabin pressurization is normally at 8000ft ... I noted: Actually, it depends on the aircraft... Explanation of pressurization certification, that some may find informative, snipped. An anonomyus person calling himself "running with scissors" replied with: christ on a bike. i knew this would happen. i stated "normally at 8,000ft", of course there are variations in type, SOP and so on. i really didnt want to spend hours typing out a list types and representative pressurization variations or a list of SOP's for various operators of various types as either way it is going to depend on what is set on the selector. say 8,000ft and someone will say "we fly at 7,500". the answer is in the FAR's. Whoa big fella, cool your jets there. the answer is in the FAR's. Indeed it is. If someone offering further information for the benefit of others in the NG was going to get your gander up so high, you could have said something like "FAR's state that transport category aircraft must maintain a cabin altitude below 8,000 ft." christ on a bike Indeed. Steve Martin; "Well Excuuuuuuse ME!" Truce already. |
#163
Mish
Do you have enough bleed air with throttles at idle? Thrust curve is not linear with throttle position so some rpm above idle might be required in some birds??? Change in time down to 18K or so would not be much different. I used a figure of 18K as a target alt to get on the safe side in a emergency descent. USAF set 34K (cockpit altitude) as the point to go to pressure breathing. Easy to suck in and fill lungs and hard to breath out (open exhaust valve). This assisted the lungs to get enough oxy. Took a while to accustom to blowing out with each breath against valve but soon became routine. Big John Pilot ROCAF On Mon, 05 Jan 2004 18:38:52 GMT, "Gary Mishler" wrote: "Scott M. Kozel" wrote in message ... How could an SST like the Concorde get from cruising altitude down to 10,000 feet in 3-5 minutes? Easy, it's called an Emergency Descent. Power to idle, spoilers/speedbrakes deployed, maybe gear extended (depends on aircraft), then dive at redline speed. The airplane I fly (Lear 60) it takes an initial deck angle of ~ 20 degrees nose down to obtain redline, then ~ 10-12 degrees to hold it there. We practice it every time we have a simulator check. Never takes more than 3 mins to get from FL450 to 10,000 ft. Mish |
#165
"khobar" wrote in message news:QLDKb.17987$7D3.1116@fed1read02...
running with scissors wrote in message om... "khobar" wrote in message news:W_qKb.17919$7D3.14891@fed1read02... running with scissors wrote in message om... "John Gilmer" wrote in message ... "Bob Gardner" wrote in message news:QODIb.85072$VB2.187788@attbi_s51... No way. You start off at sea level, of course, and they pump the chamber pressure down to 25000 feet with masks on...then they do some experiments with a few of the pilots taking their masks off, just to show how severely their abilities are affected. Then comes the explosive decompression, which takes the chamber from 25K back down to sea level in a second or two. SIlly question but ... Why would "they" pressurize the aircraft to sea level? Why not some compromise "pressure" like that equivalent to, say, 6,000 or 8,000 feet? EMWTK "they" dont. cabin pressurization is normally at 8000ft though crew may elect to use different cabin pressures under certain circumstances (eg medevac operations where pressurization is a factor) Sec. 25.1 Applicability. (a) This part prescribes airworthiness standards for the issue of type certificates, and changes to those certificates, for transport category airplanes. http://www.astech-engineering.com/sy...apart25d.html# Pressurization Sec. 25.841 Pressurized cabins. "(a) Pressurized cabins and compartments to be occupied must be equipped to provide a cabin pressure altitude of not more than 8,000 feet at the maximum operating altitude of the airplane under normal operating conditions." Transport category: * All jets with 10 or more seats or greater than 12,500lb Maximum Takeoff Weight. * All propeller driven airplanes with greater than 19 seats or greater than 19,000lb Maximum Takeoff Weight. Obviously the rule would not normlly apply to Medivac operations. HTH, Paul Nixon medevac ops are not exempt. though under certain medical conditions the cabin my not be pressurized or pressurized to a lower altitude. nitrogen narcosis is one condition that springs to mind. I was thinking about medivac helicopters. Dunno why since medivac goes beyond helicopter operations. Oh well... Paul Nixon pressurized heli ? |
#166
message om... "khobar" wrote in message news:QLDKb.17987$7D3.1116@fed1read02... I was thinking about medivac helicopters. Dunno why since medivac goes beyond helicopter operations. Oh well... Paul Nixon pressurized heli ? Just a minor short in the headset. I had helicopters on my mind when posting the applicability part. Paul Nixon |
#167
Morgans wrote:
"running with scissors" wrote christ on a bike. i knew this would happen. Christ didn't ride no bike. I've had enough of you. You are abusive, and now profane. I'll not hang around for strike three. Plonk Oh dear. That had to hurt something awful... |
#168
![]() "running with scissors" wrote christ on a bike. i knew this would happen. Christ didn't ride no bike. I've had enough of you. You are abusive, and now profane. I'll not hang around for strike three. Plonk -- Jim in NC |
#169
"Gary Mishler" wrote in message news:6VEKb.750520$HS4.5879879@attbi_s01...
"running with scissors" wrote in message m... "they" dont. cabin pressurization is normally at 8000ft ... I noted: Actually, it depends on the aircraft... Explanation of pressurization certification, that some may find informative, snipped. An anonomyus person calling himself "running with scissors" replied with: christ on a bike. i knew this would happen. i stated "normally at 8,000ft", of course there are variations in type, SOP and so on. i really didnt want to spend hours typing out a list types and representative pressurization variations or a list of SOP's for various operators of various types as either way it is going to depend on what is set on the selector. say 8,000ft and someone will say "we fly at 7,500". the answer is in the FAR's. Whoa big fella, cool your jets there. the answer is in the FAR's. Indeed it is. If someone offering further information for the benefit of others in the NG was going to get your gander up so high, you could have said something like "FAR's state that transport category aircraft must maintain a cabin altitude below 8,000 ft." christ on a bike Indeed. Steve Martin; "Well Excuuuuuuse ME!" Truce already. big fella ? oh you flatter me ! uh huh, ron natalie did state that in an earlier post. no probs on the truce, pulse and blood pressure still in the green arc. |
#170
"Morgans" wrote in message ...
"running with scissors" wrote christ on a bike. i knew this would happen. Christ didn't ride no bike. I've had enough of you. You are abusive, and now profane. I'll not hang around for strike three. Plonk moped then? care to show where i have been abusive in this thread ?? and as for profanity in the wording "christ on a bike" ? oh grow up. |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 05:26 PM |
Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 06:08 AM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
