Catastrophic Decompression; Small Place Solo
Old January 6th 04, 07:34 PM
running with scissors
"Gary Mishler" wrote in message news:N3yKb.764106$Fm2.730963@attbi_s04...
m...
news:eBoKb.745162$HS4.5776347@attbi_s01...
"running with scissors" wrote
in
message om...
"they" dont. cabin pressurization is normally at 8000ft though crew
may elect to use different cabin pressures under certain circumstances
Actually, it depends on the aircraft. Aircraft are certified to certain
"differential pressures" which is the difference between in the inside
cabin
pressure and the outside ambient air pressure.
We were talking about transport aircraft. US certificated transport
aircraft
must keep the cabin altitude below 8000'.
Yup, I know. The Lear 60 is a transport category aircraft, certified under
Part 25, and it's cabin is normally around +/- 6,500ft. Previous poster
said cabin pressure is normally *at* 8,000 and I was just pointing out that
Manufactures of transport category corporate jets seem to take pride in
pointing out to potential customers that their jet can maintain a lower
cabin altitude at cruise than the competitors, which all depends on the
certificated max psid.
christ on a bike. i knew this would happen.
i stated "normally at 8,000ft", of course there are variations in
type, SOP and so on. i really didnt want to spend hours typing out a
list types and representative pressurization variations or a list of
SOP's for various operators of various types as either way it is going
to depend on what is set on the selector. say 8,000ft and someone will
say "we fly at 7,500".
the answer is in the FAR's.
  #162
Old January 6th 04, 08:29 PM
Gary Mishler
"running with scissors" wrote in
message m...
"they" dont. cabin pressurization is normally at 8000ft ...
I noted:
Actually, it depends on the aircraft...
Explanation of pressurization certification, that some may find
informative, snipped.
An anonomyus person calling himself "running with scissors" replied with:
Whoa big fella, cool your jets there.
Indeed it is. If someone offering further information for the benefit of
others in the NG was going to get your gander up so high, you could have
said something like "FAR's state that transport category aircraft must
maintain a cabin altitude below 8,000 ft."
christ on a bike
Indeed. Steve Martin; "Well Excuuuuuuse ME!"
Truce already.
  #163
Old January 6th 04, 10:37 PM
Big John
Mish
Do you have enough bleed air with throttles at idle?
Thrust curve is not linear with throttle position so some rpm above
idle might be required in some birds???
Change in time down to 18K or so would not be much different. I used a
figure of 18K as a target alt to get on the safe side in a emergency
descent.
USAF set 34K (cockpit altitude) as the point to go to pressure
breathing. Easy to suck in and fill lungs and hard to breath out (open
exhaust valve). This assisted the lungs to get enough oxy. Took a
while to accustom to blowing out with each breath against valve but
soon became routine.
Big John
Pilot ROCAF
On Mon, 05 Jan 2004 18:38:52 GMT, "Gary Mishler"
"Scott M. Kozel" wrote in message
How could an SST like the Concorde get from cruising altitude down to
10,000 feet in 3-5 minutes?
Easy, it's called an Emergency Descent. Power to idle, spoilers/speedbrakes
deployed, maybe gear extended (depends on aircraft), then dive at redline
speed. The airplane I fly (Lear 60) it takes an initial deck angle of ~ 20
degrees nose down to obtain redline, then ~ 10-12 degrees to hold it there.
We practice it every time we have a simulator check. Never takes more than
3 mins to get from FL450 to 10,000 ft.
Mish
  #165
Old January 7th 04, 12:05 AM
"khobar" wrote in message news:QLDKb.17987$7D3.1116@fed1read02...
running with scissors wrote in
message om...
news:W_qKb.17919$7D3.14891@fed1read02...
in
message om...
"John Gilmer" wrote in message
"Bob Gardner" wrote in message
news:QODIb.85072$VB2.187788@attbi_s51...
No way. You start off at sea level, of course, and they pump the
chamber
pressure down to 25000 feet with masks on...then they do some
experiments
with a few of the pilots taking their masks off, just to show how
severely
their abilities are affected. Then comes the explosive
decompression,
which
takes the chamber from 25K back down to sea level in a second or
two.
SIlly question but ...
Why would "they" pressurize the aircraft to sea level? Why not
some
compromise "pressure" like that equivalent to, say, 6,000 or 8,000
feet?
EMWTK
(eg medevac operations where pressurization is a factor)
Sec. 25.1 Applicability.
(a) This part prescribes airworthiness standards for the issue of type
certificates, and changes to those certificates, for transport category
airplanes.
http://www.astech-engineering.com/sy...apart25d.html#
Pressurization
Sec. 25.841 Pressurized cabins.
"(a) Pressurized cabins and compartments to be occupied must be equipped
to
provide a cabin pressure altitude of not more than 8,000 feet at the
maximum
operating altitude of the airplane under normal operating conditions."
Transport category:
* All jets with 10 or more seats or greater than 12,500lb Maximum
Takeoff Weight.
* All propeller driven airplanes with greater than 19 seats or
greater
than 19,000lb Maximum Takeoff Weight.
Obviously the rule would not normlly apply to Medivac operations.
HTH,
Paul Nixon
medevac ops are not exempt. though under certain medical conditions
the cabin my not be pressurized or pressurized to a lower altitude.
nitrogen narcosis is one condition that springs to mind.
I was thinking about medivac helicopters. Dunno why since medivac goes
beyond helicopter operations. Oh well...
Paul Nixon
pressurized heli ?
  #166
Old January 7th 04, 12:29 AM
khobar
message om...
Paul Nixon
pressurized heli ?
Just a minor short in the headset. I had helicopters on my mind when posting
the applicability part.
Paul Nixon
  #167
Old January 7th 04, 01:04 AM
Rich Ahrens
Christ didn't ride no bike. I've had enough of you. You are abusive, and
now profane. I'll not hang around for strike three.
Plonk
Oh dear. That had to hurt something awful...
  #168
Old January 7th 04, 01:59 AM
Morgans
Plonk
Jim in NC
  #169
Old January 7th 04, 02:43 AM
"Gary Mishler" wrote in message news:6VEKb.750520$HS4.5879879@attbi_s01...
message m...
I noted:
christ on a bike
Truce already.
big fella ? oh you flatter me !
uh huh, ron natalie did state that in an earlier post. no probs on the
truce, pulse and blood pressure still in the green arc.
  #170
Old January 7th 04, 02:45 AM
"Morgans" wrote in message ...
Plonk
moped then?
care to show where i have been abusive in this thread ?? and as for
profanity in the wording "christ on a bike" ? oh grow up.
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! Small Blue Planet Toys Aviation Marketplace 0 October 15th 03 05:26 PM
Invest small Earn Large ($20 000+) promethean General Aviation 0 October 3rd 03 06:08 AM
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble Small Blue Planet Toys Aviation Marketplace 0 July 11th 03 04:00 PM
