Replace fabric with glass
Old April 15th 04, 08:00 PM
Ernest Christley
Ernest, did you miss this post by Robert Little? See below, it
explains how taught the fabric is.
Corky Scott
Once installed correctly, it has a much stiffer surface than the more
flexible and stretchy dacron. I have seen many pictures on the covers
of
aviation magazines that show the top of the wing with pillows
deforming between the ribs as the fabric stretches under the
aerodynamic load of flight. Properly installed glass fabric does not
stretch and will remain closer to the profile of the ribs than any
other covering short of metal. Many of our customers comment that our
fabric has gained them real increases in airspeed beyond the fact of
being covered with a fresh finish. This also allows your paints to
last longer as the flexing really stresses the surface coatings.
Plus, you don't have the worry of falling through it if you
should mis-step on a low wing. You can walk on it as long as the rib
underneath it can handle the weight.
Robert Little
Guys, either I'm missing something here or I'm just not smart enough to
get my mind wrapped around it.
How is the FG stretched tight enough to make it stiff? Is the butyrate
a hard substance once it dries/cure/whatever-butyrate-does? Is the
following statement correct?
If there is any looseness at all in the fabric, and it is
pulled tight by the dope, then the dope is what will carry
the stress, not the fabric.
If the butyrate is carrying the stress, then would this system be any
stronger that chopped strand composites?
Yes. It is true. I do NOT know what I'm doing. But I will before I'm
done!
Robert, do you sell 'practice kits' like AS and others sell for the
other types of fabric?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
  #32
Old April 15th 04, 08:30 PM
Ernest Christley
Robert Little wrote:
One other thing, though. The use of epoxy or polyester resin combined with
glass again starts the deterioration clock. The glass is permanent, but the
resins are what age so quickly in the presense of UV radiation. Old
fiberglass boats look rough after a few years and will burn like gasoline.
The glass does not age and will be the big mess left after the fire since it
does not burn. Our process doesn't use any resins as one usually assumes
when glass is mentioned. The "temporary cellulose" base dope is used to
fill and tauten only. It can burn off but the glass will remain in place
with little to no loss of strength to the fabric. The late Bill Hale always
used our fabric on his acrobatic aircraft due to the glass acting as a fire
wall to the occupant. Many NASA experimental windmill and wind tunnel
blades have been covered with our glass as well.
Robert, you're starting to sound like a very bad salesman, creating dark
ghost where everyone else sees daylight. Epoxy is not a vampire that
burst into a cloud of dust if the blinds are raised. In fact, the
proper formulation can sit in the sun for years without measurable
effects. I personally plan to take the very unusual step of painting my
airplane to keep it from rotting away in the sun. Where are these
people who don't paint their aiplanes after having paid to get them covered?
Furthermore, if my elevons catch on fire then I will have been burned to
death long before. A quick look at the Delta planform will explain why.
But this begs the question of, "If the FG can take the forces and
stresses of flight without the butyrate without excessive deformation,
then what is the point of the butyrate?" Didn't you say the glass was
glued on with the butyrate? If it's not necessary, why not just tie on
the FG cloth, spray a coat of paint or two, and go flying?
That is not a redundant question or a taunt. I am really trying to
understand the role each of the parts play in your system. I want
enough information to know if I can apply your product, or a variant of
your product, to my situation. I have a firewall already, and I don't
need a windmill or wind tunnel. I need a very light elevon.
On a more serious note, I think I called you Richard in another post.
Do you have practice kits available?
Veeduber
  #33
Old April 15th 04, 09:39 PM
On Thu, 15 Apr 2004 19:00:06 GMT, Ernest Christley
Corky Scott
of
Robert Little
done!
Ernest, it isn't the dope that provides the strength, not with
Razorback fabric or with any fabric. The fabric itself is what gives
the wing it's strength and/or stiffness against the wind. The initial
application of the correct dope, in the case of the Razorback fabric,
or a calibrated heating iron, in the case of the Polyfiber fabric, is
what shrinks it.
The application of paints on top of the fabric serve to protect it
from UV rays, make it waterproof, and look nice, but do not add
strength.
You should participate in one of Ron Alexander's fabric covering
sessions and see for yourself how it's done. They offer hands on
experience and you learn how to properly apply fabric to wings and
control surfaces. You will discover that the fabric is incredibly
taught, once properly shrunk. The skin of a drum comes to mind.
You can shrink the fabric too much and actually crush or bend the
framework beneath it, the fabric has that kind of strength.
Corky Scott
  #34
Old April 16th 04, 04:21 AM
Ernest Christley
what shrinks it.
strength.
Corky Scott
Corky, the polyester fabrics have long chain molecules that 'curl up'
when you heat them. This makes the actual threads shorter, so that
after the actual fabric is shrunk to size.
The butyrate doesn't shrink the fiberglass threads. It just grabs a
couple and pulls them closer together. "Chain is only as strong as its
weakest link" comes to mind. Until a butyrate coated covering stretches
enough to take out the slack that was there when the fabric was first
put on, it is only being held together by the butyrate.
That is the mental picture I have. I could be wrong, and I don't even
know if it is good or bad. For starters, I don't know how strong
butyrate dope is. It could be much stronger than polyester, and just
needs the fabric to give it some shape. I'm in unknown territory and
just need a compass and a map, or maybe just a practice kit to play with.
Didn't I read somewhere that butyrate dope can be found in most hardware
stores under a different name?
Veeduber
  #35
Old April 16th 04, 02:07 PM
BllFs6
Reminds of my childhood...
made a few of those gawdawful to make model airplanes made with 10 million
sticks of blasa wood, glue, and tissue paper...
Then there was the process of doping it shrink the tissue paper...
Had a friend.....he didnt use dope on his....he use spray on starch (you know
the kind for ironing your clothes)....seemed to work pretty well....never did
find out if that was some insider secret or not.....asked how he knew and he
said it just seemed like it would work to him!
take care
Blll
PS...no Im NOT saying use spray on starch on a real airplane
  #36
Old April 16th 04, 02:08 PM
Stealth Pilot
On Thu, 15 Apr 2004 16:39:33 -0400,
what shrinks it.
Corky Scott you surprise me cobber. mistakes like the one contained in
the paragraph above are what led to Steve Wittman's death.
in the case of cotton, irish linen, razorback and any of the non
shrink fabrics it IS the dope which causes the fabric to tighten as
the solvents evaporate from the dope.
polyfiber is unique in that the fabric is applied in the grieged state
and ironing it at the appropriate temperature shrinks it to create
it's taughtness. the vinyl finishes applied have solvents in them to
displace the manufacturing lubricants in the fabric. the vinyls simply
fill the weave.
dopes should not be applied to polyester fabrics that still have the
manufacturing lubricants in them. they will simply not adhere. even
on clean fabric the dope does not penetrate the fibers.
my Auster had a section of the turtledeck applied this way and once
cracked the finish peeled off with about the tenacity of a 3m post it
note also there is a ceconite covered piper cub on the local
commercial field that has areas of the underside wing finish held in
place with tape because it has peeled away.
dopes work well with absorbent natural fibers.
polyfiber is different in the way it works.
make the mistake of mixing the two and the headlines will be
"Corky Scott's fatal accident identical to Wittman's, when will they
ever learn?"
end of safety lesson
Ernest if you are an EAA member hunt out the construction articles in
Sport Aviation for an aircraft called "ol' Ironsides".
it is a wood frame single seat wittman tailwind I think. the
construction techniques were quite well described and are epoxy/glass
panels as you have been asking about. the guy used the polished faces
of masonite sheets with release agent to do his layups. the resultant
sheets were then bonded to the framework. afaik it is still flying.
the articles were quite charming - well written. lots of photos. a
good aircraft I think.
(you're forgiven corky. it is THE fatal error with fabric finishes and
it must be understood or people will die. simple as that.)
Stealth Pilot
Australia.
  #37
Old April 16th 04, 04:46 PM
On Fri, 16 Apr 2004 21:08:23 +0800, Stealth Pilot
what shrinks it.
Stealth, what are you smoking? That's what I said.
Here's my sentence:
"The initial
what shrinks it.
Now you say: in the case of cotton, irish linen, razorback and any of
the non shrink fabrics it IS the dope which causes the fabric to
tighten as the solvents evaporate from the dope."
But you are just repeating what I said. Did you read it a bit too
quickly?
Corky Scott
  #38
Old April 16th 04, 09:59 PM
Del Rawlins
In charles.k.scott@
initial application of the correct dope, in the case of the Razorback
fabric, or a calibrated heating iron, in the case of the Polyfiber
fabric, is what shrinks it.
Here's my sentence:
"The initial
what shrinks it.
quickly?
I spoke with my instructor at the A&P school again and he was pretty
adamant that the main shrinking agent with the natural fibers was water.
The tautening effect of the dope is actually a negative if you put it on
too thick.
I did misunderstand him, however, as far as the cause of the sagging
razorback in cold weather. He said it isn't so much caused by the
underlying frame contracting, and didn't think that would be a
noticeable problem with a steel frame. He claims that there is a
definite issue with the stuff in cold weather that can't be explained as
poor application technique.
Mind you, I am just passing this along. I would personally like to see
some testing done, and would be interested in leaving a small test frame
covered with each major process outside in my backyard over the winter.
It often gets down to 20 below or so around here so it would be a valid
test.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Fabric covering processes Jerry Guy Home Built 2 January 29th 04 06:49 PM
Fabric Work Doug Home Built 9 January 26th 04 03:31 AM
fabric and tube by the ocean. Ed Bryant Home Built 5 December 6th 03 07:00 PM
Soliciting Testimonials on Covering Systems Larry Smith Home Built 5 August 18th 03 09:24 AM
Glass Goose Dr Bach Home Built 1 August 3rd 03 05:51 AM
