Question: "Overhead Entry to Downwind?"
Old January 13th 04, 10:10 PM
Jay Honeck
Descending into a leg of the pattern is generally considered to be less
than safe
due to the risk of a collision. It's a little less dangerous when the
descending
aircraft is a high-wing, but it's still frowned upon.
While what you say is true, I have tried the "overhead break" on occasion,
and found it to be a very good way to see the entire pattern before entry.
It's also a lot of fun.
On the other hand, it's always the one you *don't* see that kills you, and
ground clutter can make spotting traffic difficult, so descending into the
pattern can be dangerous. To reduce this risk, I've tried entering the
pattern for this kind of an "overhead break" just 100 or so feet above
"normal" pattern altitude. This seemed to be a good compromise, minimized
the amount of time spent descending into a possible conflict, while still
allowing for a good scan of the whole pattern.
Is it still dangerous? I would rate it as mildly more risky than the more
standard "entering on a 45," and slightly less risky than a long
straight-in. Therefore, I don't use this approach when I know there is
other traffic in the pattern.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 13th 04, 10:23 PM
Robert Moore
I didn't know that there was any other entry for the first
18 months of my flying life. :-)
Bob Moore
Old January 14th 04, 03:22 AM
Mike O'Malley
news
"C J Campbell" wrote in message
You are allowed to enter the traffic pattern any way you like.
Well, not just any way, there is a restriction on the direction of turns.
Please explain to me how it is possible to "enter on a 45 to the downwind"
AND "make all turns to the left in the traffic pattern" (that is paraphrased
from memory). In fact, if one were to only make left turns in the traffic
pattern, an overhead approach would be one of the ONLY ways to enter the
pattern. Of course, one very few people are looking for. :-)
Mike
Old January 14th 04, 03:36 AM
Orval Fairbairn
"Harry Shin" wrote:
"Orval Fairbairn" wrote in message
news
Now, Harry, did YOU announce YOUR entry into the pattern? I realize that
it is not required, but it IS good practice.
Orval,
First sentence (!), "My father and I were returning to Petaluma (O69),
called in on the 45 to downwind..." (and all other legs as well, FWIW)
You formation guys need to pay more attention...
Harry
Harry:
If that is your attitude, maybe YOU need to adjust YOUR attitude!
If you called the 45, you were NOT in the traffic pattern! Did you pay
attention to the frequency? Did the formation call "initial"?
I have seen so-called "pattern operations" flying extra wide downwinds
and two mile finals -- enough to land several flights of four.
Generally, our formation flights keep it in tight and have about ten
seconds spacing on landing.
BTW, your reference to "spoiling a formation landing" shows you know
nothing about formation flying. They came overhead in the break and, as
such, would have been landing individually, with one rolling out as the
next touched down.
Old January 14th 04, 03:51 AM
Icebound
Am I misreading something, or do the Canadians frown on the "45 to
downwind" approach at uncontrolled airports, (unless traffic advisory is
available)???
http://www.tc.gc.ca/civilaviation/an...new197.htm#MF2
quote:
Basically, when airport and traffic advisory information is not
available, regardless of whether MF procedures are in effect or not,
aircraft should not join 45% to the downwind leg, straight-in to the
base or final leg of the circuit. The correct entry procedure to be
used, therefore, depends on whether airport and traffic advisory is
available or not."
Old January 14th 04, 04:49 AM
Steven P. McNicoll
"Mike O'Malley" wrote in message
paraphrased
from memory).
It isn't. The 45 degree entry to the downwind is illegal.
Old January 14th 04, 04:53 AM
Robert M. Gary
For those arriving on the non-pattern side of the runway its the best
way to do it. Its also important to do if the winds are unknown
(because you can see the sock). The maneuver should be done above
pattern altitude, with a long right turn (assuming left traffic) into
the 45. The overhead entry "should" always drop you into the 45.
"Harry Shin" wrote in message ...
Hi Guys,
My father and I were returning to Petaluma (O69), called in on the 45 to
downwind and were just about to turn downwind when a flight of three
experimentals called in that they were set up for their "overhead entry".
They were flying above pattern altitude on the runway heading, proceeded to
make a diving 180 turn to downwind, inside our line.
Two of them jumped ahead of us, while the third resigned himself to
following our Citabria. I guess we really messed up their spectacular
approach and possible formation landing... (yawn)
So, I'm wondering if their overhead approach to an un-controlled field is
"approved"? Petaluma can get pretty busy on weekends, and I feel their
grandstanding lead to some concern and un-necessary avoidance manuevering...
Harry Shin
Citabria N5064K, Sonerai I 'a building
Old January 14th 04, 04:55 AM
Dave Stadt
m...
That's not the typical overhead entry. The overhead entry is an upwind leg
with a 180 degree left turn (assuming left hand traffic) to the downwind
leg.
Hi Guys,
entry".
to
is
manuevering...
Harry Shin
Steven P. McNicoll
"G.R. Patterson III" wrote in message
The 45 entry to downwind is not "in the pattern". It is the entry to the
pattern
and does nopt have to be a left turn.
The regulation does not require turns "in the pattern" to be to the left, it
requires the pilot of an airplane approaching to land at an airport without
an operating control tower to make all turns to the left. The 45 degree
entry to downwind violates the regulation.
Old January 14th 04, 07:44 AM
G.R. Patterson III
from memory).
The 45 entry to downwind is not "in the pattern". It is the entry to the pattern
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Front louvers for Cherokee/Archer overhead vents? Bob Chilcoat Owning 10 February 3rd 04 10:19 PM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
