#31
I read an NTSB decision that violated a 135 operator for turning a 5
mile final from a right base. If that is considered "approaching to land", then surely the 45 entry must be also. On Wed, 14 Jan 2004 08:45:34 -0500, Todd Pattist wrote: "Steven P. McNicoll" wrote: The regulation does not require turns "in the pattern" to be to the left, it requires the pilot of an airplane approaching to land at an airport without an operating control tower to make all turns to the left. The 45 degree entry to downwind violates the regulation. While I'm inclined to agree with you that you have the better interpretation of that regulation, it's also clear that the FAA recommends a procedure that on its face seems to be illegal. If the FAA's recommendation is legal, then the logical reason must be that making the 45 right turn entry to the pattern occurs before the pilot is "approaching to land." It seems odd, given that the 45 entry is part of the defined pattern for the approach to landing, but I've seen the language in other FAR's strained farther than that. Todd Pattist (Remove DONTSPAMME from address to email reply.) ___ Make a commitment to learn something from every flight. Share what you learn. |
#32
"Orval Fairbairn" wrote in message news
Harry: If that is your attitude, maybe YOU need to adjust YOUR attitude! snip BTW, your reference to "spoiling a formation landing" shows you know nothing about formation flying. They came overhead in the break and, as such, would have been landing individually, with one rolling out as the next touched down. Orval, Your concern is sincerely appreciated but please don't worry, my attitude is fine. I followed the recommended pattern entry at a busy uncontrolled field. I do think, however, your undies may be a little tight. Regarding my misnomer of "formation landing", you're absolutely correct and I apologize. Having now had the privilege to fly (unintentionally) with these fine airmen, slotted in the Number 3 position (original Number 3 became Number 4, or possibly we became Numbers 3a and 3b), we landed in sequence to the adoration of cheering crowds, or maybe it was only a guy walking his dog who didn't even notice the little airplanes land... Regards, Harry |
#33
When I first read 91.126 I thought it was either a poorly-written or extremely loose reg. But since I'm new to the world of FAR/AIM's I figured I'd learn about it when I needed to. But in response to your post I did a little digging, and determined that the problem is that 91.126 is being misinterpreted! If you go back and reread 91.126, you will note that all the relevant part is actually saying is that "left traffic" or a left pattern will be the default standard. The purpose is to state that unless there are indicators indicating that "right traffic" should be flown, you should always fly "left traffic". If you arrive at an airport with no indications of a specified traffic pattern, you should always fly "left traffic". My justification for this interpretation comes from AIM 4-24, Chapter 4-Air Traffic Control, Section 3-Airport Operations. Figure 4-3-2 Provides an illustration of traffic pattern operations. It shows a 45 degree pattern entry with a right turn onto downwind, with all turns inside the pattern being left turns. Obviously all turn directions are reversed for right traffic. This agrees with the information I have received from other sources. If I am somehow incorrect on this please let me know, as I am very much still in the process of learning! "Steven P. McNicoll" wrote in message nk.net... "Bill Denton" wrote in message ... I'm sitting here looking at my handy-dandy little PDQ pattern calculator... For left traffic, it shows a 45 degree entry with a right to downwind, a left to base, and a left to final. (Obviously, for right traffic, everything is reversed). I'm still a wannabe, but everything I have read indicates this is the correct method for flying a pattern. Are there any F.A.R.s that indicate otherwise? Yes. § 91.126 Operating on or in the vicinity of an airport in Class G airspace. (a) General. Unless otherwise authorized or required, each person operating an aircraft on or in the vicinity of an airport in a Class G airspace area must comply with the requirements of this section. (b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace -- (1) Each pilot of an airplane must make all turns of that airplane to the left unless the airport displays approved light signals or visual markings indicating that turns should be made to the right, in which case the pilot must make all turns to the right; and (2) Each pilot of a helicopter must avoid the flow of fixed-wing aircraft. §91.127 Operating on or in the vicinity of an airport in Class E airspace. (a) Unless otherwise required by part 93 of this chapter or unless otherwise authorized or required by the ATC facility having jurisdiction over the Class E airspace area, each person operating an aircraft on or in the vicinity of an airport in a Class E airspace area must comply with the requirements of §91.126. |
#34
Bill Zaleski wrote:
I read an NTSB decision that violated a 135 operator for turning a 5 mile final from a right base. If that is considered "approaching to land", then surely the 45 entry must be also. I read it too. It was his base to final turn. We're talking about a 45 entry turn that is 2 turns before the base to final turn. You tell me - is distance or number of turns more important? How about time? There must be some transition between "not yet approaching to land" and "approaching to land," but I don't think we can say that it's always illegal to make right hand turns within 5 miles of the airport you want to land at. Todd Pattist (Remove DONTSPAMME from address to email reply.) ___ Make a commitment to learn something from every flight. Share what you learn. |
#35
"Bill Denton" wrote in message ... | | When I first read 91.126 I thought it was either a poorly-written or | extremely loose reg. But since I'm new to the world of FAR/AIM's I figured | I'd learn about it when I needed to. | | But in response to your post I did a little digging, and determined that the | problem is that 91.126 is being misinterpreted! | Steve, bless his heart, just likes being a little bit obtuse from time to time. I love his posts. He is conveniently ignoring the "unless otherwise authorized" clause in the reg. The 45 degree entry is "otherwise authorized." The AIM specifically states that pilots following the recommendations in it provide a safe harbor against violation of the regulations and that all procedures in it are approved by the Administrator. The AIM is also signed by the Administrator saying that the procedures in it are authorized. |
#36
"Steven P. McNicoll" wrote in message nk.net... | | "Mike O'Malley" wrote in message | ... | | Please explain to me how it is possible to "enter on a 45 to the downwind" | AND "make all turns to the left in the traffic pattern" (that is | paraphrased | from memory). | | | It isn't. The 45 degree entry to the downwind is illegal. No, it is not. The regulation says "unless otherwise authorized," and the 45 degree entry is specifically authorized as a legal maneuver in a document signed by the Administrator (the AIM). The AIM may not be regulatory, but following the procedures in the AIM provides a safe harbor and use of those procedures is to be presumed by the FAA to be in compliance with all federal regulations. |
#37
"Harry Shin" wrote: "Orval Fairbairn" wrote in message news
Harry: If that is your attitude, maybe YOU need to adjust YOUR attitude! snip BTW, your reference to "spoiling a formation landing" shows you know nothing about formation flying. They came overhead in the break and, as such, would have been landing individually, with one rolling out as the next touched down. Orval, Your concern is sincerely appreciated but please don't worry, my attitude is fine. I followed the recommended pattern entry at a busy uncontrolled field. I do think, however, your undies may be a little tight. Regarding my misnomer of "formation landing", you're absolutely correct and I apologize. Having now had the privilege to fly (unintentionally) with these fine airmen, slotted in the Number 3 position (original Number 3 became Number 4, or possibly we became Numbers 3a and 3b), we landed in sequence to the adoration of cheering crowds, or maybe it was only a guy walking his dog who didn't even notice the little airplanes land... Regards, Harry Harry: It appears that your real complaint is that the three were flying formation and did an overhead approach -- both of which, if properly done, are safe, legal and efficient. In my original post, I conceded that it appears that the flight leader screwed up in breaking ahead of you. What else do you want? Are you jealous that others have practiced and enjoy flying formation? Is it "airplane envy"? Your second paragraph indicates an attitude problem. |
#38
Sounds like the real story here is a guy got cut off in the pattern and was
rightfully ****ed about it, but PO'd another guy by making a blanket statement about formation flyers. C'mon guys.. Lighten up. Both of you sound reasonable (but annoyed), just let it go... KB |
#39
"Orval Fairbairn" wrote in message news ![]() Are you jealous that others have practiced and enjoy flying formation? Is it "airplane envy"? Your second paragraph indicates an attitude problem. Orval, Hmmm. By your own analysis, these "others have practiced and enjoy flying formation" did a lousy job, so I'm certainly not jealous of them. As far as "airplane envy" and my so-called "attitude problem", I guess I should feel honored that these guys chose to create an un-necessary situation, with my father and I trying desperately to see where they were going, and trying to make sure the two in the low wing planes didn't nail us. With respect to my "attitude problem", I suppose it's just a case where it seems some people take themselves Way Too Seriously. "White flight", ten second landing intervals, "break now!"; you guys should join the Boy Scouts so you can practice marching in step (turns can be very difficult). I've also heard it's fun to wear camoflauge to play paintball... (oops, there's that damn attitude thing again! sorry...) Roger Out!, Harry |
#40
"Steven P. McNicoll" wrote: The regulation does not require turns "in the pattern" to be to the left, it requires the pilot of an airplane approaching to land at an airport without an operating control tower to make all turns to the left. The "approach to landing" IS the pattern. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Front louvers for Cherokee/Archer overhead vents? | Bob Chilcoat | Owning | 10 | February 3rd 04 11:19 PM |
| Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 10:40 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
