Dave,
This is an interesting topic. I don't fly out of your home airport but I have landed there many times. I live close so I spend a lot of my liesure time watching the traffic there. You are correct that they typically fly a fairly large pattern but it is not only the students. I can sit there and predict where the base to final turn will be and it is very consistent through the entire cross-section of pilots. I don't know if it's a new method training but I do think it is an unintended byproduct of the training. Students tend to think of each leg of the pattern as an event in and of itself. As such, they have the understandable need to stabilize each leg and go through the mental work of setting up the next leg. Many pilots retain this method of landing because it is what they learned and they are comfortable with it. And there is nothing wrong with that. That being said, there is a lot to be said for a tighter pattern. It sounds like something that the CFIs might want to present at their BFRs. You know, something like "Your landing pattern is fine, but now that you have xxx hours you may want to consider tightening the pattern up a little", followed by a demonstration. By the way, I have observed (strictly anecdotally) that taildraggers tend to fly a tighter pattern than us trike guys. ![]() Rich Russell On Wed, 14 Jan 2004 10:26:33 -0500, dave wrote: I was wondering the same thing. I own a Citabria and fly a tight pattern. When I trained in PA28-161's we flew tight patterns. I was taught to fly a pattern that will allow me to land if I lose the engine while in the pattern. The students at my home field train in new 172's. They fly, to my eye, very wide patterns. Maybe it's a newer training method? Dave Anyone else here like to fly a tight (or tighter than normal) pattern? The field we're based at (Falcon Field, FFC) has a pretty good-sized training operation, and there are a lot of students out practicing landings, especially on good days. What annoys me, though, is that some of these students fly huge patterns--like 2-mile finals, downwinds 1-2 miles out from the runway, etc. Sometimes, I'll end up behind somebody in the pattern, only to realize that, by the time he turns final, I could have done another touch and go and ended up behind him. IMHO, there's no reason to go flying a jet/heavy twin pattern in a Cessna. I've always tried to fly mine 4 white on the PAPI, with basically a continuous turn from downwind to final (leveling out for a second just to check traffic). |
"Wdtabor" wrote:
The point being that we fly a standard pattern for a reason, What's a "standard pattern?" -- Dan C172RG at BFM (remove pants to reply by email) |
![]() I don't think he ever got to 800 feet, and probably turned crosswing before he was even to the end of the runway, and flew such a tight pattern that he overtook and passed me. Add a low wing over a high wing, a NORDO aircraft flying a non-standard pattern, and you've got a midair waiting to happen. Don, you have to understand that what may be a "normal" or "standard" pattern for metal spam cans is too high for a light, rag and tube taildragger. The lighter weight and lower descent speeds would reek havoc with your spam can descents and airspeeds in your "normal" pattern. In my 7AC, I can fly inside you and below and either land and be clear before you turn final or, I can do a 360 between downwind and final and land behind you if you are on final. There is no comparison between the performance of aircraft. My approach speed is 55 MILES per hour. How far behind me are you going to have to fly and how big a pattern are you going to fly to stay behind me? At my landing speed, 45 MILES per hour, I may only roll 100-200 feet. If I land at the approach threshold, that means I have to taxi on the runway to get to the taxiway, which may be 1000 or 1500 feet down the runway. My taxi speed is 25 - 30 MILES per hour. If I fly your "normal" pattern, you are in a world of hurt. Plus, if your engine burps, you are going to make an off airport landing. By flying inside and below you, the taildragger pilot allows you to be where you want to be. Additionally, because I can land slower and shorter, I may turn my downwind to final before I reach the approach end of the runway to alleviate the long taxi. I will pick my landing spot down the runway at a point where I can touch down, roll out and make the turn off. |
In article et, Dave S
writes: His not being where you expect him to be... has nothing to do with your (and his) mutual obligation to see and avoid each other. There is no requirement to even USE a pattern. You cant depend on other traffic having a radio at the uncontrolled fields I use. However is inside pattern and failure to reach the published pattern altitude created a positioning that made it impossible for either of us to see or avoid the other. Had I not been nervous about NOT being able to see him and not knowing, since he was NORDO, if he had remained in the pattern or flown straight out, he would have had landing gear poking down through his wings in just a few more seconds. It may be true that folks aren't required to fly a standard pattern, at the published altitude, but I am saying it is good practice to do so, and unnecssarily risky to not. And that flying predictably when NORDO is even more important. Not law, just good sense. Don -- Wm. Donald (Don) Tabor Jr., DDS PP-ASEL Chesapeake, VA - CPK, PVG |
In article , EDR
writes: Don, you have to understand that what may be a "normal" or "standard" pattern for metal spam cans is too high for a light, rag and tube taildragger. The lighter weight and lower descent speeds would reek havoc with your spam can descents and airspeeds in your "normal" pattern. In my 7AC, I can fly inside you and below and either land and be clear before you turn final or, I can do a 360 between downwind and final and land behind you if you are on final. There is no comparison between the performance of aircraft. You can, if you see me. But I am going to be high and behind you from the moment you turn crosswind. Do you have one of those clear wings? In the scenario I described, the Husky came from under and behind me as he passed and cut me off in the pattern, he was obscurred by the wing and fuselage of the Katana from the moment I lost sight of him on downwind. If you fly that kind of pattern, I have no way to know you are even there until I hear the thump. Don -- Wm. Donald (Don) Tabor Jr., DDS PP-ASEL Chesapeake, VA - CPK, PVG |
Bob,
The field we're based at (Falcon Field, FFC) has a pretty good-sized training operation, and there are a lot of students out practicing landings, especially on good days. What annoys me, though, is that some of these students fly huge patterns--like 2-mile finals, downwinds 1-2 miles out from the runway, etc. Sometimes, I'll end up behind somebody in the pattern, only to realize that, by the time he turns final, I could have done another touch and go and ended up behind him. You've discovered one of the real shortcomings of ab initio flight training where they teach students how to become commuter airline pilots rather than how to fly. Thus the giant sized patterns. It's a true pain in the whatsis. At controlled fields when I'm stuck behind some yahoo flying downwind a mile from the field, I'll ask for a right pattern the next time around, fly it tight and get in front of the slow motion stuff. Tower usually understands and will cooperate. Sometimes a visit to the tower to discuss it results in an understanding and they'll help you out. At uncontrolled fields, if it is just one airplane that is the problem when I'm shooting landings, I'll simply fly a close in downwind and ask the pilot of the offending airplane if he minds me flying a tight pattern inside him one time. I've never had anyone refuse. A polite inquiry has always worked for me. All the best, Rick |
Well, you shouldn't fly a tight pattern any more than you should fly a
wide pattern. Maintaining correct pattern altitude is a good ideal, too. This stuff is all spelled out in the AIM. Best regards, Steve Robertson N4732J 1967 Beechcraft A23-24 Musketeer Bob Martin wrote: Anyone else here like to fly a tight (or tighter than normal) pattern? The field we're based at (Falcon Field, FFC) has a pretty good-sized training operation, and there are a lot of students out practicing landings, especially on good days. What annoys me, though, is that some of these students fly huge patterns--like 2-mile finals, downwinds 1-2 miles out from the runway, etc. Sometimes, I'll end up behind somebody in the pattern, only to realize that, by the time he turns final, I could have done another touch and go and ended up behind him. IMHO, there's no reason to go flying a jet/heavy twin pattern in a Cessna. I've always tried to fly mine 4 white on the PAPI, with basically a continuous turn from downwind to final (leveling out for a second just to check traffic). |
Richard Russell wrote: Dave, This is an interesting topic. I don't fly out of your home airport but I have landed there many times. I live close so I spend a lot of my liesure time watching the traffic there. You are correct that they typically fly a fairly large pattern but it is not only the students. I can sit there and predict where the base to final turn will be and it is very consistent through the entire cross-section of pilots. I don't know if it's a new method training but I do think it is an unintended byproduct of the training. Students tend to think of each leg of the pattern as an event in and of itself. As such, they have the understandable need to stabilize each leg and go through the mental work of setting up the next leg. Many pilots retain this method of landing because it is what they learned and they are comfortable with it. And there is nothing wrong with that. That being said, there is a lot to be said for a tighter pattern. It sounds like something that the CFIs might want to present at their BFRs. You know, something like "Your landing pattern is fine, but now that you have xxx hours you may want to consider tightening the pattern up a little", followed by a demonstration. By the way, I have observed (strictly anecdotally) that taildraggers tend to fly a tighter pattern than us trike guys. ![]() Rich Russell The instructor who soloed me in the C150 wanted me a mile out on final at 300 feet agl. Directly over an unlandable area of tall pines. I did as she asked when she was in the plane. When she got out of the plane to solo me, I flew the pattern the way I wanted to. I would keep the runway, or other landable area under my wing, usually pretty close to the end of the wing strut. Never out of gliding range of a safe landing site.With the 40 degree flaps and power off, the descent from a high, short final was pretty much like parachuting. Maybe I was being paranoid about an engine failure but the C150 I was flying had a very noticeable repair on the wing where it had once hit a car while landing on the road following an engine failure. The CFI's I've flown with since are older tailwheel types who teach high tight patterns. I had the good fortune to get checked out in a J3 Cub recently. After flying it for two days, with and without the instructor, I realized that I could not remember looking at the altimeter once. Everything was about reference to the ground and horizon and using landmarks on the aircaft, such as the jury struts, etc. judge correct heights and distances. This is as it should be for VFR in light (slow) single engine airplanes. If the engine is not on fire, I'm pretty happy. If it's actually making power, I count that as a bonus. |
Auto engine bolt patterns | Ron Webb | Home Built | 12 | October 20th 04 01:35 PM |
Fly tight for tight bomb patterns on the ground. | ArtKramr | Military Aviation | 120 | August 30th 04 08:42 AM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | ArtKramr | Military Aviation | 2 | August 27th 03 11:06 AM |
Aircraft bomb frag patterns | Mike D | Military Aviation | 6 | August 24th 03 05:16 AM |
