#71
******Didn't your mama ever say "If everybody jumped off the bridge, would
you do so too?" Just because everybody else is doing it, doesn't make it safe. The fact that they are too lame to turn the pattern around to land upwind, or they patterns wide enough for a 747 isn't compelling reason to follow along.******* Maybe you should change newsreaders, Ron. Since you can't seem to be able to follow a thread. Or maybe it's just too much ego and not enough smarts. If you follow the tread you'll see that I was not recommending everyone follow the same pattern, rather, just the opposite. When you build up enough time in the bush to be able to get a real job I'll start respecting your point of view. Till then you're just a low time loudmouth. Karl |
#72
![]() "C J Campbell" wrote in message ... "Tom Sixkiller" wrote in message ... | | May 19, 2000 | | Pelican's Perch #30: | The 45-Degree Zealots | | http://www.avweb.com/news/columns/182100-1.html Good article, but I see nowhere that he says a 45 degree entry is illegal. Why would he...he believes otherwise. From the intro: "There's not a syllable in the FARs about 45-degree traffic pattern entries. Nor does the AIM require them. There exists, however, a small-but-vocal cadre of pilots — and even some FAA inspectors — who consider any other type of pattern entry (straight-in, crosswind, etc.) to be a felony." Contrariwise, he feels that the entry into the pattern is not part of the pattern. |
#73
![]() "C J Campbell" wrote in message ... "Steven P. McNicoll" wrote in message nk.net... | | "C J Campbell" wrote in message | ... | | Good article, but I see nowhere that he says a 45 degree entry is illegal. | | | In about the middle of the article Deakin writes: | | "In fact, I can make a very good case that the classic 45-degree entry is | itself a violation of the FARs, since it is ALWAYS in the opposite direction | to the established flow of traffic. Since it is the final turn onto the | downwind leg, it must certainly be in the "vicinity" of the airport, and | therefore covered by the above regs!" Then in that case I have to disagree with him on that point. He says it in the context of "playing on words". It might be interesting to get a couple of FSDO interpretations. |
#74
Actually, the AIM doesn't require anything. It is simply a collection of
best practices to help pilot fulfill their regulatory responsibilities. That said, as I have previously noted, the AIM provides an illustration of the traffic pattern, and it utilizes 45 degree entries. As the FAA says the AIM presents their recommended practices and methods, and the AIM recommendation contains 45 degree pattern entries, it would appear that the FAA wants 45 degree entries to be used. "Tom Sixkiller" wrote in message ... "C J Campbell" wrote in message ... "Tom Sixkiller" wrote in message ... | | May 19, 2000 | | Pelican's Perch #30: | The 45-Degree Zealots | | http://www.avweb.com/news/columns/182100-1.html Good article, but I see nowhere that he says a 45 degree entry is illegal. Why would he...he believes otherwise. From the intro: "There's not a syllable in the FARs about 45-degree traffic pattern entries. Nor does the AIM require them. There exists, however, a small-but-vocal cadre of pilots — and even some FAA inspectors — who consider any other type of pattern entry (straight-in, crosswind, etc.) to be a felony." Contrariwise, he feels that the entry into the pattern is not part of the pattern. |
#75
"Chris Nielsen" wrote in message
news ![]() Here's how we do it.... When we do an overhead join, we start 500 feet above circuit altitude, and when ready, descend on the non-traffic side, i.e. the upwind side - the other side of the circuit from downwind, then when we're down to circuit altitude, we turn and fly the crosswind leg, then, while looking for traffic we turn downwind and fly the rest normally... I trust this doesn't come under the category of descending on you? I've asked this before, but doesn't the dead side descending entry used in UK (and, presumably from the above, New Zealand) mean that there is always traffic noise on both sides of the runway? Many of the single runways in my area have the pattern on one geographical side (e.g. LP 10, RP 28), thus removing noise from, in this example, the south side. It also reduces the fall-out-of-the-sky fear factor from people on the ground when there are buildings on the unused side. Or does the fact that the planes on the dead side are descending from TPA+500 mean the noise is less intrusive? -- David Brooks |
#76
I sent a request to the Chicago O'Hare requesting a clarification of these
issues. I'll post an answer if they send me one! "Tom Sixkiller" wrote in message ... "C J Campbell" wrote in message ... "Tom Sixkiller" wrote in message ... | | May 19, 2000 | | Pelican's Perch #30: | The 45-Degree Zealots | | http://www.avweb.com/news/columns/182100-1.html Good article, but I see nowhere that he says a 45 degree entry is illegal. Why would he...he believes otherwise. From the intro: "There's not a syllable in the FARs about 45-degree traffic pattern entries. Nor does the AIM require them. There exists, however, a small-but-vocal cadre of pilots — and even some FAA inspectors — who consider any other type of pattern entry (straight-in, crosswind, etc.) to be a felony." Contrariwise, he feels that the entry into the pattern is not part of the pattern. |
#77
Chris Nielsen wrote: Cub Driver wrote: Just a question - what is this 45 degree entry to downwind we keep hearing about? I'm from the other side of the world and that's not something I was taught - instead, like the guys from the UK, I do an overhead join at an uncontrolled field, It is part of the recommended approach in the U.S., and is so commonly used that alternative entries are upsetting to many pilots. It really doesn't matter how you approach an airport, but it sure helps if everyone does it the same way. Since I fly a high-wing airplane, however, I would prefer that people not descend upon me while I'm in the pattern. As an alternative to the 45, I would choose a mid-field crossover to the downwind, but not if there's a NORDO aircraft in the pattern. He's expecting traffic to enter from his right, not his left. OK, just another dumb question.. When you talk about people descending on you in the circuit, I take it you mean they are descending while on downwind? That sounds extremely unwise!!! I'm surprised that what we do isn't also practised, or maybe it is but you call it something else... I also can't bring myself to call it a pattern - sorry, I'm so used to referring to it as a circuit, pattern sounds foreign to me :-) Here's how we do it.... When we do an overhead join, we start 500 feet above circuit altitude, and when ready, descend on the non-traffic side, i.e. the upwind side - the other side of the circuit from downwind, then when we're down to circuit altitude, we turn and fly the crosswind leg, then, while looking for traffic we turn downwind and fly the rest normally... I trust this doesn't come under the category of descending on you? No doubt this is normal, but called something else... See ya Chris Here at Spruce Creek, we do initial at or below pattern altitude and perform either a level turn break or a "popup" break, to shed speed, followed by a tight pattern. Both approaches give lead a better assessment of incoming and pattern traffic than a descending break. Also, the descending break makes it really hard to reduce speed to gear and flap speed (mine is only 100 mph, while I may be flying aintial at 160 +). It is incumbent on lead to assure that his flight does NOT break into other traffic. |
#78
![]() "Bill Denton" wrote in message ... I sent a request to the Chicago O'Hare requesting a clarification of these issues. I'll post an answer if they send me one! What is "the Chicago O'Hare"? |
#79
![]() Finally, someone who thinks like I do! It would help if you guys would post what airport you are based at, so I can avoid them. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#80
![]() OK, just another dumb question.. When you talk about people descending on you in the circuit, I take it you mean they are descending while on downwind? That sounds extremely unwise!!! Yes, that's what I understood the original poster to have meant. Here's how we do it.... When we do an overhead join, we start 500 feet above circuit altitude, and when ready, descend on the non-traffic side, i.e. the upwind side That sounds a whole lot safer. What's really important is that everyone do it the same way at a given airfield. The guy who asked why this was safer left me shaking my head and wondering if it was a good idea to take up this hobby. It's all very well to smirk and say the NORDO pilot (indeed, the pilot with radio) should have his head on a swivel, but the fact is that student pilots have a lot of cognitive dissonance cluttering up the old brain pan. They do well to see the aircraft in front of them, never mind the one charging in from the side or descending from overhead. the other side of the circuit from downwind, then when we're down to circuit altitude, we turn and fly the crosswind leg, then, while looking for traffic we turn downwind and fly the rest normally... I trust this doesn't come under the category of descending on you? No, it doesn't. Thanks for the clarification. (All of this said, I ought to add that I have descended to the downwind occasionally, on simulated engine-out landings. But never when there was another aircraft in the pattern or moving anywhere on the field.) all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Front louvers for Cherokee/Archer overhead vents? | Bob Chilcoat | Owning | 10 | February 3rd 04 10:19 PM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
