"Jawbreaker" Lost at Sun N Fun
Old April 26th 04, 05:39 AM
Roger Halstead
On Sun, 25 Apr 2004 10:31:57 -0400, Tedstriker
Gee, now I kind of wonder _why_ it stalled on takeoff.
Obviously not a lack of power.
Anybody want to take a wild guess at the wing loading?
There's no wonder in that, it got too slow. And as heavy as that plane
is, the stall speed is higher. It weighs in 500lbs heavier than a
stock Glasair 3. That would definitely raise the stall speed. A stock
Glasair 3 should wiegh in the neighborhood of 1,600lbs empty. The
articals I read about Jawbreaker listed it's empty weight at 2100lbs.
Book empty weight is 1550#, Wing area is 81.3 ft^2 for the standard
wing and 91.5 ft ^ 2 with the factory extensions and stall is just shy
of 80 mph. Wing loading is just shy of 30# per ft^2 and 27.3 with the
factory wing tip extensions.
Add 500# more for 6.1# ft^2 and that makes 36# per ft^2 wing loading.
The stock 30# per ft^2 can make for an interesting rate of descent.
:-)) That would be 33.4 # fit^2 with the tip extensions.
Whether a plane stalls at 50 mph or a 100 is no real biggie if you
expect it. If it was,no one would be flying twins and jets.
As to more HP? At very slow speeds, or high angles of attack, HP is
not always your friend unless you have the control surfaces and
handeling characteristics to ... well, handle it.
www.rogerhalstead.com
Deltahawk lost their website x Home Built 22 March 31st 04 05:48 PM
Zzzz Campbell's Second Lawsuit Against Sun-N-Fun Zzzz Ron Wanttaja Home Built 23 October 6th 03 02:09 PM
I'm lost. Which compass? Greg Burkhart Home Built 1 August 12th 03 03:49 AM
Hughes Racer Replica Lost Wayne Sagar Home Built 9 August 10th 03 01:45 PM
