Block Allocation?
Old February 10th 04, 01:39 AM
Gene Seibel
Military aircraft in MOA's are often given blocks of altitude.
Gene Seibel
Hangar 131 - http://pad39a.com/gene/plane.html
Because I fly, I envy no one.
AES/newspost wrote in message ...
Listening to channel nine on UA 1225 Denver-Reno yesterday, I heard
something like:
"Denver Center, Jackpot 123, can we request a block allocation
for 39 to 41?"
and then
"Jackpot 123, Denver Center, block allocation 39 to 41 approved."
["Jackpot 123" is made-up name since I don't remember actual name; maybe
it was "block assignment" instead of "allocation"; and I don't recall if
the wording was "Flight levels 39 to 41" or just the numbers.]
Anyway, I'm assuming that "Jackpot 1243" wanted to move up and down
freely between 39,000 and 41,000 feet seeking smoothest ride and best
fuel economy without having to make repeated requests; and Denver Center
was willing to approve this since nobody else was up that high anyway.
Is that likely the case?
Old February 10th 04, 01:56 AM
A Lieberman
AES/newspost wrote:
snip
My first instrument lesson in IMC, my instructor and I went to the
practice area and he requested a block altitude of 2000 to 3000 so I
could practice climbs and descents. ATC approved without hesitation.
Allen
Old February 10th 04, 01:58 AM
Max T, CFI
Us little guys request blocking altitudes for turbulence, but often the big
guys are asking for it because they can slowly drift upward to higher altitudes
as they burn fuel and get lighter. I think they're doing this because it's more efficient to
fly at higher altitudes, but they cannot get there until their weight decrease.
Max T, MCFI
When a pilot requests a narrow block, it's usually because the ride is
unavoidably rough and he wants to be able to just hold a pitch
attitude rather than continually changing pitch and airspeed to
maintain altitude. It's easier on the airframe, easier on the
passengers, allows you to maintain a relatively constant airspeed so
it might be slightly more fuel efficient, and generally easier on the
pilot as well if he is hand-flying. I routinely ask for this when I
fly in convective weather, and so far I've always gotten it. Like
this pilot, I also generally ask for a 2000 ft block.
Michael
Old February 10th 04, 02:36 AM
Peter Duniho
"Gary Drescher" wrote in message
news:OgSVb.265595$na.420059@attbi_s04...
According to the AIM P/CG, a cruise clearance permits flight from a single
specified altitude down to the minimum applicable IFR altitude; the
phraseology is e.g. "Cruise eight thousand". A block clearance, with an
explicit lower bound, is slightly different.
Exactly right. Guess I'm the one who's been using the wrong phraseology
with ATC. Oh well...I guess they knew what I meant when I asked for a
cruise clearance between two altitudes. They've never corrected me, in all
my flights over the mountains when I've asked.
In any case, the basic idea is still the same. A block altitude gives the
pilot the ability to ride altitude changes without fighting them, which
results in a smoother ride, better fuel economy, and less work on the
pilot's part.
Pete
Dave S
Continental Express conducts some training within 150 miles of my area,
and at night, I have heard them request and recieve blocks of airspace
(big pie wedges) that are thousands of feet deep for airborne
maneuvering. Im presuming that they are required to operate under IFR by
company or Fed/Op Spec guidelines, so to conduct these maneuvers in IFR
requires the chunk of airspace, hence the "block"
Dave
something like:
for 39 to 41?"
and then
Old February 10th 04, 03:34 AM
Brian Burger
On Mon, 9 Feb 2004, A Lieberman wrote:
AES/newspost wrote:
snip
Likewise for aerobatics; we get 2000 or 3000ft tall blocks (3000-5000 ASL
or 3k-6k usually, and it's not a problem with Terminal.
One weekday when we were out Terminal cleared a floatplane below us (after
sending us up to 4000-5500ft and said to the floatplane: "... there's a
Citabria doing airwork above you, not below 4, and... well, I'm not sure
which way they'll be pointing in a minute..."
That was amusing, even at the top of a loop...
Brian.
Old February 10th 04, 02:17 PM
Todd Pattist
When flying a glider in Class A airspace pursuant to an LOA,
I call to open what we colloquially refer to as a "wave
window." The phone at ATC is always answered "Military
Desk" which I presume is the desk responsible for
controlling "blocks" of airspace that are defined by
geographical limits (set in the LOA). ATC will ask for the
name of the block (also defined in the LOA), the requested
altitude block (typically from the bottom of Class A to
FL250 to start) check it in the computer and then advise
if/when it can be opened. These "blocks" opened by the
military desk are geographically defined blocks as well as
altitude blocks, and we're free to roam within the altitude
and geographic limits of the block while it's open.
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old February 10th 04, 02:50 PM
Newps
That's different. Once in the MOA they are not IFR.
Old February 10th 04, 03:45 PM
Mike Rapoport
Often air to air refueling flights will request and get block altitudes but
generally they are around 30K' not 40K'.
Mike
MU-2
"AES/newspost" wrote in message
something like:
for 39 to 41?"
and then
Old February 10th 04, 07:27 PM
Robert M. Gary
"Peter Duniho" wrote in message ...
Sounds like a "cruise clearance". Not sure why those words weren't used in
the request.
No, this is a block request. I ask for them a lot when flying over
mountains looking for a smooth ride. A cruise clearance is something
very different and you are probably not too likely to get it unless
you are out in the middle of nowhere.
-Robert
New "Rhinos" on the block (& farewell to low-viz) [email protected] Naval Aviation 0 November 25th 04 08:24 AM
B-2 question Harley W Daugherty Military Aviation 37 August 27th 04 12:45 AM
Block out someone? (Little Hitler) Jeff Military Aviation 6 April 13th 04 07:03 PM
More Info on Block 52 F-16 robert arndt Military Aviation 0 November 18th 03 03:07 PM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 06:48 PM
