Block Allocation?
Old February 10th 04, 07:30 PM
Robert M. Gary
Brian Burger wrote in message ria.tc.ca...
On Mon, 9 Feb 2004, A Lieberman wrote:
AES/newspost wrote:
snip
Anyway, I'm assuming that "Jackpot 1243" wanted to move up and down
freely between 39,000 and 41,000 feet seeking smoothest ride and best
fuel economy without having to make repeated requests; and Denver Center
was willing to approve this since nobody else was up that high anyway.
My first instrument lesson in IMC, my instructor and I went to the
practice area and he requested a block altitude of 2000 to 3000 so I
could practice climbs and descents. ATC approved without hesitation.
Likewise for aerobatics; we get 2000 or 3000ft tall blocks (3000-5000 ASL
or 3k-6k usually, and it's not a problem with Terminal.
One weekday when we were out Terminal cleared a floatplane below us (after
sending us up to 4000-5500ft and said to the floatplane: "... there's a
Citabria doing airwork above you, not below 4, and... well, I'm not sure
which way they'll be pointing in a minute..."
A true "block altitude" is usually for IFR or in class C,B airspace. I
don't know how ATC could "authorize" a block elsewhere. They may,
however, enjoy just knowing where you plan to be. However, a "block
altitude' implies that no one else will be assigned to fly into that
area when you are there.
-Robert
Old February 10th 04, 08:09 PM
Newps
Only for IFR.
Old February 10th 04, 08:56 PM
Ron Natalie
"Newps" wrote in message news:KTaWb.45$uV3.1610@attbi_s51...
Only for IFR.
I suppose a VFR could get a block in class B. Certainly got plenty of "at or below"
instructions there.
  #24
Old February 12th 04, 06:58 AM
Brian Burger
AES/newspost wrote:
snip
I'm not sure of the exact terminology & legalese, but by your def'n 'block
alititude' sounds like the right phrase. We're flying aerobatics in Class
C Terminal (Approach, to Americans) airspace, and they'll send other a/c
around/over/under our airwork block rather than through. Which makes
sense, given that they know we're up there doing aero work. Loops &
wingovers must make our radar track look fairly strange...
Uncontrolled airspace over 3000ft around here only starts about 30min
flying time away from home base, so to go high for aerobatic work means
working inside the Class C. Terminal assigns us blocks, and it's usually
pretty painless.
Just distracting when ATC calls you when you're upside down in mid-loop...
Brian.
New "Rhinos" on the block (& farewell to low-viz) [email protected] Naval Aviation 0 November 25th 04 08:24 AM
B-2 question Harley W Daugherty Military Aviation 37 August 27th 04 12:45 AM
Block out someone? (Little Hitler) Jeff Military Aviation 6 April 13th 04 07:03 PM
More Info on Block 52 F-16 robert arndt Military Aviation 0 November 18th 03 03:07 PM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 06:48 PM
