Rotax 582 engine problems
Old May 6th 04, 05:59 AM
L. Darte
Default Rotax 582 engine problems
There are two planes hangered at my field with Rotax 582 engines which
are both having the same problem. Each engine has about 30 to 40 hours
on them and suffer from surging and/or power failure during climb-out or
shortly after. Typically, the RPMs will drop from 6000 to around 4800
after about 2 to 5 minutes after take off. The EGTs on both cylinders
remain stable at 1100F during the power loss, but one engine does show a
marked increase in the CHT on one of the cylinders (300+).
The fuel system on both planes has been replaced twice now. The carbs
were disassembled and inspected with no indication of any blockage or
defect. The jugs were pulled on one of the engines with no indication of
seizure or carbon fouling of the rings or pistons. The plugs look
normal. Switching from one mag to the other has little effect during the
power loss.
I'm pretty much out of ideas what could be causing this problem. The
only other thing I can think of is that maybe a crank bearing is failing
and dragging the engine down as a result. But splitting the engine case
is a pain in the butt so I wanted to exhaust the simpler causes first.
Any suggestions out there?
Old May 6th 04, 02:36 PM
Yosimite Sam
I have an acquaintance with a 582 powered kitfox that had this same
problem...It turned out that the prop was very slightly changing pitch....I
remember it took a lot of time before this was found out. There was wear in
the hub area. It was fixed by adding a shim. It seems like (I'm trying to
remember here) the prop hub was slightly distorted where it clamped
together. What type of prop are on the planes? Are they using GSC props?
Yosimite Sam
Old May 6th 04, 04:32 PM
L. Darte
Hmmm... Very interesting. The props on both planes (actually Pegasus
powered parachutes) are 3-blade Powerfins. They are similar to the
WarpDrive props in that they have a CNC machined hub which clamps down
on the end shank of the blade.
I'll try to round up a WarpDrive prop and try that on them and see what
happens. The Powerfins have a lot of twist in the blades so I guess it's
possible that they are flexing and changing the pitch.
Regarding the prop shims, I know that the early (and possibly later)
versions of the ground adjustable Ivoprop had a problem with the tip of
torque rods that rides on the swash plate that varied the pitch would
wear and allow the pitch to wander.
Old May 6th 04, 05:10 PM
Yosimite Sam
If you decide that this might be the problem, I can put you in e-mail
contact with the guy that went through this problem.
Yosimite Sam
Old May 7th 04, 07:40 AM
Mark Hickey
together.
It seems to me that the prop would be much more likely to go to a
flatter pitch and produce MORE RPM if the blade(s) slipped. Am I
missing something?
Mark Hickey
Old May 8th 04, 09:39 PM
L. Darte
together.
missing something?
Mark Hickey
I guess it would depend on the rigidity of the blade and where it wants
to twist. A cambered airfoil should produce a pitching moment in such a
way as to reduce the angle of attack.
BTW: I did try the WarpDrive prop and the problem went away. I then put
the original prop back on to make sure that was indeed the cause, and
was unable to reproduce the problem anymore. So I don't know what's
going on at this point. :P
Old May 9th 04, 02:49 AM
Sully
Something else to check might be the exhaust. I had a friend who
changed his muffler and the inside of it had broken loose (I believe
it was the baffle) and was moving around and would seal off or change
the back pressure and the RPM would die off. We tore the pipe apart
and rewelded everything in place and it works fine now. It was an R&D
pipe that he bought used. Of course he does still have a "flat spot"
around 5400 RPMs it drops off to 4800 RPM. You might also look at
adjusting the piece of the end of the pipe in and out too to change
the pressure build up in the pipe.
power loss.
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 05:56 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 05:46 AM
Using 100LL in a Rotax 912 Engine Yosimite Sam Home Built 3 August 16th 03 05:00 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
