Crosswind components
Old February 26th 04, 03:28 PM
arcwi
nuke,
I am standing in awe and reading your explanation
I always thought that pilots do not understand this, I mean the nonlenear
relation between the wind and the distance travelled.
I've been wrong.
My hat goes off to you!
"nuke" wrote in message
Common logic fails here, because the the commonsense explanation that the
upwind and downwind differences ought to cancel out only works if the
relationship is linear. If you do the math, the relationship between the
round trip time, round trip distance, TAS and wind speed is nonlinear:
time = distance/speed
round trip time = time out(upwind) + time back(downwind),
= D/(T - W) + D/(T + W), where D = leg distance, T = TAS, W = windspeed
= [D(T + W) + D(T - W)] / [(T - W)(T + W)], using x/y + z/w = (xw + yz)/yw
= (DT + DW + DT - DW) / (T^2 - TW + TW - W^2)
= 2DT / (T^2 - W^2)
2D is the round trip distance, so in words: round trip time = (round trip
distance x TAS) / (TAS^2 - windspeed^2)
[As a check, this reduces to: round trip time = round trip distance /
TAS,
when windspeed = 0]
Hence the relationship is nonlinear with respect to wind speed. That isn't
normally so obvious because usually TAS wind speed. It's more obvious
in
the original post because the poster chose a wind speed much closer to
TAS.
[Work it out for windspeed = 10 kt and the other data in the original
post,
and the upwind and downwind differences do almost cancel out. Then work
it
out for windspeed = 199 kt!]
nuke
"arcwi" wrote in message
Yes, but the common logic suggest that you also spend less time in
tailwind
that in head wind - and if there is no wind the two should cancell each
other... Or should they...
"Stefan" wrote in message
arcwi wrote:
Can someone explain the difference?
You spend more time in headwind than in tailwind.
Stefan
Old February 26th 04, 10:19 PM
nuke
Can't really say what most pilots understand. They certainly don't teach
this in ground school. I'm a low time pilot but a high time engineer :-)
nuke
nuke,
I've been wrong.
yz)/yw
= 2DT / (T^2 - W^2)
trip
TAS,
when windspeed = 0]
isn't
obvious
in
TAS.
post,
it
nuke
tailwind
each
Stefan
Old February 26th 04, 11:54 PM
David CL Francis
On Thu, 26 Feb 2004 at 02:43:58 in message
, Teacherjh
You can't, however, run before the wind faster than the wind (unless you have
one humongus current)
Yes you can. The ability to do so depends on the relative forces between
the water and the second medium. Sand and Ice yachts can readily
demonstrate a course speed downwind faster that the wind. In effect they
are tacking downwind. If you are being very precise then you cannot run
before the wind faster than the wind because running before the wind
depends only on drag and not on lift.
David CL Francis
Old February 27th 04, 01:26 PM
Teacherjh
Straight downwind? So they would be overtaking the wind? Howdeydodat?
In effect they
Oh, then they are not "running" before the wind, they are sidestepping to some
degree.
Jose
(for Email, make the obvious changes in my address)
Old February 27th 04, 05:23 PM
Casey Wilson
"Teacherjh" wrote in message
I suspect he's thinking about the case of holding a course a few
degrees off a direct reach. Laying down with the wind directly over the
stern, well even catching a puff from behind now and then would immediately
luff. Even if you could overcome the miniscule drag of an ice runner, the
sail becomes a HUGE air brake. Been there, done that, threw the Tee-Shirt
away.
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
FS: Slick ignition components (O-540) David Campbell Aviation Marketplace 0 December 24th 03 02:56 AM
