Could something like this actually work?
Old March 1st 04, 05:15 PM
Mike Rapoport
Why? The added air has the same density of the outside air.
Mike
MU-2
"G.R. Patterson III" wrote in message
"Louis L. Perley III" wrote:
Saw an article today about an aircraft that would change it's buoyancy,
so
it would float up like a balloon and then change buoyancy and glide
down.
Interesting stuff, although I doubt we'll see it anytime soon. Is
something
like this even practical?
A similar technique that's been around quite a while is an internal air
bladder
for LTA craft that use helium and hydrogen. Pump the bladder full of air,
and
the buoyancy of the craft changes.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way
that
you look forward to the trip.
Old March 1st 04, 06:44 PM
Todd Pattist
"Marc" wrote:
2) Where is the power source? Conservation of energy says that the plane
could not continue to ascend and descend without some input of energy.
A gas balloon can oscillate up and down by harnessing the
temperature differential with altitude. As it rises, it
cools, the gas contracts and the balloon then falls to
lower, warmer, altitudes, where the gas expands and the
cycle repeats. It could in theory have wings that allow it
to glide somewhat during each cycle.
I seriously doubt the practicality of such a craft.
A similar concept, alluded to in the text, is currently used
in extremely low powered ocean monitors that use a phase
change material for buoyancy control. The phase change
material has a larger volume when cold, so it rises when
submerged to a chilled depth. Winglike structures let it
"glide" towards the desired location to be sampled. They're
slow, but effective and can cruise for months. Electronics
are powered by solar energy at the surface during each
cycle.
The
initial ascent would be powered by the energy required to separate helium
from the atmosphere, which is accomplished on the ground, but it should not
be true that the plane would "always land with its tanks fully pressurized",
since theoretically the amount of energy generated by the turbines during
the descent could not be enough to compress the gas used for the ascent.
Esecially if the efficiency of the turbines is 20%.
Agreed.
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old March 1st 04, 08:03 PM
C J Campbell
"Marc" wrote in message
news:tXH0c.9865$ko6.197285@attbi_s02...
1) I wonder why a typical blimp has to use such a large volume (the
ballon)
to provide the lift and a relatively tiny cabin attached underneath,
whereas
this craft seems to use a much smaller volume (the wings). Has the
inventor
calculated this correctly?
Those two big pontoons are also being used for lift. The cargo/passengers
ride in the small section between the wings. Whatever else you can say about
it, this thing is enormous.
It is really just a huge double dirigible with wings. The wings double as
additional helium storage. If it were my design I would replace the wind
turbines with conventional blimp engines and use the wings and rudders for
directional control, folding the props to reduce drag during the glide
portion of the flight. This would give greatly improved range and
controllability during the climb. Right now his aircraft has a claimed range
of only 400 nm, hardly worth the effort given the costs involved.
It is not really a "perpetual motion machine" any more than any other
lighter than air aircraft. The compressed air stored by the turbines is not
used to provide lift. It can provide some thrust, but not enough to keep the
aircraft flying indefinitely, nor does the inventor claim any such thing is
possible. Obviously they are not able to store much air during the descent,
which is why the aircraft has such a short range. When you get right down to
it, I have to wonder why he is bothering with them at all.
Although it is short range and slow, it is expensive. People have been
fooling around with various winged blimp designs for years. Perhaps some day
someone will come up with something workable.
Old March 1st 04, 08:46 PM
G.R. Patterson III
Good question. So I dug my books out. It turns out the internal bags (called
ballonets) are used for trimming and to allow the helium to expand and contract
without changing the shape of the balloon. They don't affect the buoyancy of
the craft.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
Old March 1st 04, 11:52 PM
Dan Thomas
Todd Pattist wrote in message . ..
I understood that as the balloon rises, the decreasing atmospheric
pressure allows the balloon to expand, displacing more air and
increasing lift to compensate. Some guy invented a black balloon some
years ago, really big, that was entirely solar powered. It worked.
Dan
Old March 3rd 04, 04:04 AM
John Roncallo
Louis L. Perley III wrote:
Saw an article today about an aircraft that would change it's buoyancy, so
it would float up like a balloon and then change buoyancy and glide down.
Interesting stuff, although I doubt we'll see it anytime soon. Is something
like this even practical? The article says they take the aircraft up 10
miles to get 400 miles range, I would think ATC wouldn't like the idea of a
free balloon (which is what it would be at that point) up in the flight
levels.
http://www.machinedesign.com/ASP/vie...PACE&catId=379
Louis Perley III
N46000 - KBJC
A blimp pakaged in such an areodynamic package and the 40:1 glide ratio
from something that drives air compressors is a bit tough for me to chew on.
John Roncallo
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 09:45 PM
Best Home Base Work Reynard Owning 0 November 9th 04 04:37 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 10th 04 11:06 PM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
