Who's flying out of the higest elev airport?
Old March 8th 04, 03:15 PM
Dudley Henriques
Default Who's flying out of the higest elev airport?
Hey, you mountain types out there :-) I'm doing some research on a safety
issue and need your help . I need a post from someone flying out of Colorado
somewhere, preferably Telluride or a field very close to Telluride. I need
as close to the highest elevation in the U.S. as I can get.
I'm not dealing with this issue in the context of right or wrong as it
pertains to mountain flying. I need to know if the Kollsman window in your
altimeters has a wide enough range to allow you, IF YOU DESIRED TO DO SO, to
set your altimeters to 0 elevation on a consistent basis before take off at
your field instead of a MSL setting. Again, I'm only interested in the
possibility, not the right and wrongs involved with doing this.
Thanks,
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
Old March 8th 04, 04:08 PM
Ron Natalie
"Dudley Henriques" wrote in message nk.net...
Leadville, CO is the highest elevation airport in the US (at least so says the sign
on the FBO building). Been there once.
I can't imagine using QFE in the mountains, not just because of the fact that the
instrument won't handle it. You don't have to go very far from a mountain
strip until you get into radically different terrain heights. Those altitudes are
published in MSL, the relationship to the airport field elevation isn't overly
interesting.
Old March 8th 04, 04:34 PM
Newps
Hey, I live at 3650 and can't set my altimeter to zero.
Thanks,
Dudley Henriques
the z's with e's.
Old March 8th 04, 05:26 PM
Dudley Henriques
"Ron Natalie" wrote in message
nk.net...
safety
Colorado
the sign
that the
mountain
altitudes are
overly
interesting.
I understand . That's why I specified the context as not being in the right
or wrong dept :-)..... (restricted to only the possibility factor). I just
can't remember the Kollsman low pressure side maximum for our GA altimeters
here in the U.S. I think it's 27.5 or 25.5 but I can't remember exactly
which; and I need to have this for a data point.
I'm attempting to come up with an average point above sea level based on a
standard atmosphere where 0 sets can't be made under normal conditions.
Should be easy, but I need that Kollsman range to do it.
Right now, with the information I have, I'm at around 2500 feet ASL for that
maximum, but not remembering that Kollsman window range, I want to be sure.
I just need some verifying data.
Thanks Ron,
Dudley
Old March 8th 04, 05:27 PM
Dudley Henriques
Thanks Newps; that jives with what I have so far anyway. I'm assuming a 27.5
low end on the Kollsman. Does that sound right to you. I'm at home and can't
check it :-)
Dudley
"Newps" wrote in message
news:5g13c.523826$na.1181072@attbi_s04...
safety
Colorado
need
your
SO, to
at
Thanks,
Dudley Henriques
the z's with e's.
Old March 8th 04, 06:50 PM
Newps
I was just at the airport today and I looked at my new overhauled United
altimeter. The lowest setting is 28.10. There is a little travel past
that but you'd have to guess at what the setting really is. The station
pressure here is usually around 26 inches. Looks like the highest
altitude for which you could correct to zero will be about 2000 MSL,
depending of course on the actual altimeter setting.
check it :-)
Dudley
safety
Colorado
need
your
SO, to
at
Thanks,
Dudley Henriques
the z's with e's.
Old March 8th 04, 07:06 PM
G.R. Patterson III
I just
Perhaps this will help.
http://www.ansys.com/industry/aerosp.../whittum1.html
George Patterson
Battle, n; A method of untying with the teeth a political knot that would
not yield to the tongue.
Old March 8th 04, 07:09 PM
Dudley Henriques
I have it at present somewhere between 2500 and 3000 feet ASL as a possible
limit parameter based on averaging out the altimeter settings for the U.S.
It's interesting about the low Kollsman number range. With 28.10, I'm
beginning to see some variables in the low range that I didn't know was
there. I always assumed all the Kollsmans would all be the same. It will be
interesting to see if others have different numbers for their Kollsmans.
D
news:Mf33c.87121$PR3.1225813@attbi_s03...
27.5
can't
check it :-)
Dudley
safety
Colorado
need
your
SO, to
off
at
Thanks,
Dudley Henriques
the z's with e's.
Old March 8th 04, 07:12 PM
Dudley Henriques
This is pretty much what I need George. Thanks much.
Dudley
"G.R. Patterson III" wrote in message
I just
altimeters
George Patterson
would
Old March 8th 04, 08:51 PM
Stan Prevost
Dudley, I found reference to an air data computer which would accept an
altimeter setting of 26.75 to 33.00.
Stan
nk.net...
Colorado
to
at
Thanks,
Dudley Henriques
the z's with e's.
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
Airport Manager position, Fitchburg, MA David Reinhart Piloting 6 August 12th 03 11:46 PM
