Who's flying out of the higest elev airport?
Old March 8th 04, 09:02 PM
Dudley Henriques
Thanks Stan; that's an additional data point for sure.
D
"Stan Prevost" wrote in message
Dudley, I found reference to an air data computer which would accept an
altimeter setting of 26.75 to 33.00.
Stan
nk.net...
Hey, you mountain types out there :-) I'm doing some research on a
safety
issue and need your help . I need a post from someone flying out of
Colorado
somewhere, preferably Telluride or a field very close to Telluride. I
need
as close to the highest elevation in the U.S. as I can get.
I'm not dealing with this issue in the context of right or wrong as it
pertains to mountain flying. I need to know if the Kollsman window in
your
altimeters has a wide enough range to allow you, IF YOU DESIRED TO DO
SO,
to
set your altimeters to 0 elevation on a consistent basis before take off
at
your field instead of a MSL setting. Again, I'm only interested in the
possibility, not the right and wrongs involved with doing this.
Thanks,
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
Old March 8th 04, 09:40 PM
John Galban
"Dudley Henriques" wrote in message ink.net...
I need to know if the Kollsman window in your
altimeters has a wide enough range to allow you, IF YOU DESIRED TO DO SO, to
set your altimeters to 0 elevation on a consistent basis before take off at
I'm not flying out of a high mountain airport (at the moment), but I
can tell you that most of GA aircraft altimeters I've seen only adjust
down to about 28.00. This makes setting a "0" elevation troublesome
above 2500 ft. MSL.
Old March 8th 04, 10:05 PM
Dudley Henriques
That's about what I'm getting also John. Thanks.
What I actually needed to know was the lower range on the Kollsman, which is
turning out to be just about where you have it at 28. I actually have it at
27.5 at this point, but considering averages, this puts the max 0 set about
where you are with it.
D
"John Galban" wrote in message
om...
ink.net...
SO, to
at
above 2500 ft. MSL.
Old March 8th 04, 11:04 PM
Blanche
Dudley:
I fly out of FTG (5500 MSL) in Denver. Having not much else to do
this week, I'll fly down to COS (6200) and see what happens with
the Kollsman. Difficult to get to Leadville right now (altho
it's only about 100 m from COS due to the high winds. Over
the weekend the winds in the mountains were clocked at 125 mph
in some areas. No passes for me right now!
bc
Old March 8th 04, 11:11 PM
Dudley Henriques
"Blanche" wrote in message
Dudley:
bc
Hi Blanche;
Actually, if our data is correct as of this point, at 5500 feet you
shouldn't be able to zero the altimeter at FTG, without having to go all the
way up to COS in all that nasty wind :-)))
Next time you're out at FTG, try it for me will you? I don't think the
Kollsman will let you do it if the low range maximum is 27.5 where I think
it is!
Thanks much,
Dudley
Old March 9th 04, 12:13 AM
C J Campbell
For some reason, Dudley, your query reminds me of the old joke "How thick is
the atmosphere?" The answer, of course, is "100 miles, but don't tell the
pilots -- they think it is only 29,920 feet thick on a standard day."
Old March 9th 04, 03:10 AM
Marty Shapiro
nk.net:
safety issue and need your help . I need a post from someone flying
out of Colorado somewhere, preferably Telluride or a field very close
to Telluride. I need as close to the highest elevation in the U.S. as
I can get. I'm not dealing with this issue in the context of right or
wrong as it pertains to mountain flying. I need to know if the
Kollsman window in your altimeters has a wide enough range to allow
you, IF YOU DESIRED TO DO SO, to set your altimeters to 0 elevation on
a consistent basis before take off at your field instead of a MSL
setting. Again, I'm only interested in the possibility, not the right
and wrongs involved with doing this. Thanks,
Dudley Henriques
the z's with e's.
I don't have any direct experience with the airports in CO, but my pilots
guide shows LXV (Lake County Airport, Leadville, CO) is at 9,927' MSL. TEX
(Telluride Regional Airport) is 9,078' MSL.
The highest airport I've landed at is TVL (South Lake Tahoe, CA). The
alitude there is 6,264' MSL. None of the aircraft I flew to TVL (C172,
C182, RALL) had an altimeter which could have been set to indicate 0' at
that altitude.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old March 9th 04, 03:30 AM
Dudley Henriques
Thanks Marty. Appreciate the input.
D
"Marty Shapiro" wrote in message
nk.net:
Dudley Henriques
the z's with e's.
that altitude.
Marty Shapiro
Silicon Rallye Inc.
Old March 9th 04, 06:19 AM
Newps
You don't have to fly down there. Your altimeter goes down to 28.10.
You know the field elevation is 6200. Altimeter setting right now at
COS is 30.53. Therefore when set to 28.10 your altimeter will read
approx 3770.
Blanche wrote:
Dudley:
bc
Old March 9th 04, 07:39 PM
ShawnD2112
Dudley,
Interesting that the "right or wrongness" of the issue is of such a concern.
Isn't it funny how different cultures view the same problem with different
perspectives? Here in the UK, no motorcycle rider would even think of
getting on a bike without a full set of leathers, helmet, and gloves. In
the States, guys ride in shorts, sneakers, and no helmets where they can.
On the other side of the coin, Brits "filter" through traffic on
motorcycles, riding between lanes just to get through traffic faster,
whether it be in the city or the highway. Most Americans think that's too
dangerous to think about.
Here in the UK, setting the altimeter to field elevation, QFE, before
takeoff is not only allowed, it's taught and expected. Likewise, when
approaching the airfield, you're expected to reset the altimeter to that
airfield's QFE in the pattern. In the States, we would think that would
lead to all kinds of altitude-related accidents.
Different perspectives, but who's to say what's right and wrong?
Shawn
nk.net...
Hey, you mountain types out there :-) I'm doing some research on a safety
Colorado
somewhere, preferably Telluride or a field very close to Telluride. I need
pertains to mountain flying. I need to know if the Kollsman window in your
to
at
Thanks,
Dudley Henriques
the z's with e's.
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
Airport Manager position, Fitchburg, MA David Reinhart Piloting 6 August 12th 03 11:46 PM
