Are sectional paths correct across "long" distances?
Old March 16th 04, 09:38 AM
Dylan Smith
In article , Roy Smith wrote:
You've got to go pretty big distances before GC errors start to become
significant. For example, to go from 38N/77W to 38N/122W (roughly
Washington, DC to San Francisco, CA), the rhumbline is 270 and the GC is
284. 14 degrees on a coast to coast trip.
The error will be less still on an aviation chart, which is a Lambert
Conformal Conic projection rather than Mercator. Over the distances of a
typical sectional chart, the difference between a GC and a line on the
chart is irrelevant.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old March 16th 04, 02:59 PM
Kyler Laird
vincent p. norris writes:
I can't see the red GC line very well except against the dark brown of
the higher elevations; but it seems as if the two lines are only about
a line-width apart. I wouldn't consider that "significant," but of
course that's a personal judgment.
It's personal until you cut across restricted airspace by that much.
Then it gets *really* personal.
My reaction is the opposite of yours: I'm impressed by how well the
straight line follows a Great Circle.
I'm pursuing perfect solutions. As usual, the more I get to know
something, the more I realize how little I knew about it, but I know
how to handle this now.
Can you tell me how many nautical miles separate the two lines, at the
point of widest divergence?
-102.934677557 40.1266731277 5.99724483075
6nm
I don't fly that path non-stop though. With a landing at Centennial,
the max. error is under 2nm on the leg from Indiana, and under 1nm on
the next leg to California.
I have discarded routes because the straight paths clipped some
restricted airspace by only a mile or two. I expect any tool that I
use to be accurate enough to tell me whether or not that's going to
happen.
--kyler
Old March 16th 04, 04:04 PM
Teacherjh
6nm
Can you tell me how much longer the long line is?
Jose
(for Email, make the obvious changes in my address)
Old March 16th 04, 04:26 PM
vincent p. norris
Peter, you saved me the effort of replying further; your replies
stated essentially what I would have said.
One comment: The reason I asked for the greatest distance between a
GC line and a straight line was that it looked to me, on Kyler's
chart, as though it was never more than a few miles. That would
indirectly indicate the difference between the distance to destination
of the two routes could not be more than a few miles.
I can't remember ever planning a flight of more than a couple hundred
miles that did not involve dodging around one or more restricted areas
or MOAs, so the question about the difference between a straight line
and a GC over a long distance is only of academic interest.
vince norris
Old March 16th 04, 04:30 PM
vincent p. norris
284.
I thought a Great Circle is the shortest possible distance between two
points on the earth. Should that read "rhumbline is 284 and GC is
270"?
vince norris
Old March 16th 04, 05:59 PM
Peter Duniho
"Kyler Laird" wrote in message
Huh? The error should be with respect to whether you're really flying the
shortest path between two points. It should not have anything to do with
how you navigate, nor should it affect your spatial orientation, your
knowledge of where you are at any given time.
Even if it did affect your navigation (and it shouldn't), I sure hope you're
not depending on dead reckoning to keep you out of restricted airspace.
6nm
I'm not sure why vince asked that question. The point of widest divergence
isn't something anyone should care about. What's important is how much
extra *length* is added to the trip, as Jose asks.
happen.
If you fly the route plotted, then the route plotted is the one you fly.
Simple, no?
Regardless of whether you fly a true great circle route, a collection of
great circle intervals, or a straight line on a sectional, you need
something else to keep you on the route you've chosen. It's *that* which
will affect whether you fly through restricted airspace, not the method of
chosing the route (assuming you've chosen the route to avoid restricted
airspace, of course).
Pete
Old March 16th 04, 07:59 PM
Kyler Laird
"Peter Duniho" writes:
No, but it does affect planning. I like to plan for "straight"-line paths
that keep me out of restricted airspace. Makes my life a lot easier.
It's something that matters to me. Am I going to have to think about
where I'm going around some airspace/mountain/...? Do I have to explain
my plans to Center?
happen.
Simple, no?
Simple except that it doesn't match the plot on the GPS I use to double-
check my progress.
I'm a horrible person for wanting to simplify flying...blah, blah, blah...
I'll never earn my "aviator balls"...blah, blah, blah...Yeah, I know.
--kyler
Old March 16th 04, 08:52 PM
Ben Jackson
6nm
Since it looks like it just 'bows' the line slightly the worst case would
be 2*6nm, or 12nm, and it's probably not even that.
Ben Jackson
http://www.ben.com/
Old March 16th 04, 08:58 PM
Peter Duniho
That doesn't make any sense to me. Either a straight line between your
origin and destination will keep you out of restricted airspace, or it
won't. The origin, destination, and restricted airspace aren't moving.
It's not like there are multiple "straight line" paths. In reality there's
only one.
However, that's all irrelevant. If you are close enough to restricted
airspace that a Lambert "straight line" versus a great-circle makes the
difference between in or out, you need more than just a plotted route to
ensure you remain clear of the restricted airspace.
I don't know when the last time you flew a perfect straight line is. Maybe
it was yesterday. But I've never managed to do so.
my plans to Center?
That still doesn't explain why you are worried about the difference between
great-circle and a sectional straight line. You never have to explain your
planning to Center, and you always have to think about where you're going
around some airspace or mountain. How you plot the route is irrelevant. If
you have to go around, you have to go around.
Simple, no?
check my progress.
In other words, you wouldn't be flying the route plotted. My statement is
still true.
I don't recall you ever stipulating that you needed a plotted route that
matched your GPS's great-circle calculations. I would agree that if what
you want to fly is a great-circle route, then you need to plot a
great-circle route.
Personally, I'd use the GPS to show restricted airspace and to ensure I'm
WELL clear. If I wanted to navigate using the GPS, and I had found that a
straight line plotted on a sectional kept me clear of the restricted
airspace, I'd simply add a waypoint to the GPS-direct route near the
airspace, on the line I plotted on the sectional. Likewise other obstacles.
If you're that close to stuff like that, you need something more reliable
(such as looking out the window) to ensure you avoid what you're trying to
avoid anyway.
I have no idea what that's all about. IMHO, you are making things more
complicated, not simplifying things. You are falling into the usual trap of
allowing your technology to provide you with false precision, overanalyzing
the flight to the point of distraction.
Maybe you're the best pilot around, and you can actually stay on centerline
when your GPS has a great-circle route for you to fly. Me, I know for a
fact that I'm doing good to keep headings that keep me within a half mile to
a mile of course, even with GPS or Loran.
Using a VOR, my precision goes down even more. I know better than to cut
things close to obstacles and restricted airspace using only my radio
navigation, simply because I can't fly that precisely by radio navigation.
I need outside references to cut things that close, and if I have those,
then I don't need to worry about the difference between a sectional
straight-line course and a true great-circle route.
More power to you if you always remain within a hundred feet or so of your
intended centerline throughout an entire cross-country. I guess if that's
the case, then you shouldn't feel worried at all about trusting your GPS to
guide you just past an obstacle or restricted airspace, and nothing I've
written is relevant to your operations.
Pete
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Are sectional paths correct across "long" distances? vincent p. norris General Aviation 32 March 25th 04 02:32 PM
AVIATIONTOOLBOX: how I convert sectional maps to map chunks Kyler Laird General Aviation 2 December 4th 03 01:09 AM
