Handheld Tranceiver Recommendation
Old March 30th 04, 03:46 AM
Al Gilson
(snip)
What do you want to do with it? I'd humbly suggest there are quite some
things a student pilot might want to spend 250 $ on before getting a
handheld radio.
As a student pilot on my dual cross country, both radios in my
instructor's plane failed on approach to the Lewiston, Idaho airport. He
whipped out his handheld, dialed in the tower frequency, and we were back
in business.
I purchased a Yaesu VX 120 Pro II the following day. I used it as a
student to listen to the ground, tower and approach chatter, and get the
ATIS while driving to the airport. Finally, when I purchased an aircraft
with only one nav/com, I used it as a second radio in the cockpit to
listen to the ATIS while keeping my my radio on the communications
frequency.
Even after I upgraded to two radios in the plane, I never leave the ground
without it...remembering that one flight when everything went toast.
Al Gilson
1964 Skyhawk
Spokane, WA USA
Al Gilson
Spokane, WA USA
1970 VW Convertible
1964 Cessna Skyhawk
Old March 30th 04, 06:55 AM
Ross Oliver
Paul Tomblin wrote:
No, but I can categorically state that you must not, under any
circumstances, buy the Sporty's one. It's a horrible piece of crap. The
display is almost unreadable under most lighting conditions, it loses all
its memory when you change the batteries, and the range is laughable. Oh,
unless you want to buy mine used, in which case they're great.
I must respectfully disagree with Paul. I actually returned an
Icom A23 in favor of the Sporty's SP-200 for the following reasons:
- A23 would not transmit across my living room on alkaline batteries;
the SP-200 reaches the tower 5x5 out to 5-6 miles on alkalines, with
no external antenna (although my aircraft is composite, not metal).
- SP-200 displays a CDI for localizers, A23 does not (only VORs).
- Although the SP-200 display is more sensitive to viewing angle,
the CDI portion is much larger than that of the A23. I tried both
in the cockpit in flight, and I found the A23's tiny CDI display
very difficult to view while flying the aircraft.
- I actually prefer the SP-200's larger size, and the SP-200 with 8 photo
lithium AAs weighs about the same as the A23 with 6 alkalines.
Whatever your favorite, I highly recommend that you TRY before you BUY.
Find someone who owns the model you're considering and try it out.
Happy landings,
Ross Oliver
Old March 30th 04, 07:12 AM
BTIZ
I have the ICOM A-22, I do not use alkaline batteries.. they only last one
day in glider operations.. I have had my A-22 for 6 years and only had to
replace the battery once, I went from the factory 1000mAhr NiCD to a
1500mAhr NiMH and that was four years ago.
I use the radio all day every weekend, I charge it after every second
weekend. I do carry the AA battery pack in my flight bag for when I forget
to charge, does not happen often. When I did have to use the AA pack, it
only lasted about 5 hours.
When on the ground, I find the A-22 able to reach aircraft about 9-10nm
distant. From the air, I have used the A-22 to talk with approach control
25nm away from a composite glider.
I always use the "rubber ducky" antenna, and I prefer the "at extra expense"
Speaker/Mic to clip to my parachute harness while flying.
I know other pilots who have abandoned the Sporty's model (failure), and
also had problems with the Yeasue (small radios, small battery packs) not
many options.
BT
"nospamPlease" wrote in message
I am thinking of purchasing a hand held radio (tranceiver).
Can anyone recommend one ? I am a student pilot.
Please reply to this newsgroup and not via email.
Old March 30th 04, 11:40 AM
Cub Driver
On Mon, 29 Mar 2004 17:33:39 -0500, Cub Driver
I would buy a Vertex 5 watt radio with any nav feature. I
Arggh! Fingers turned to thumbs! That should be: WITHOUT any nav
feature. When I had it on my Sporty's, I used it once, to see if it
worked (it did). I think I would rather scud-run than bother with
that.
all the best -- Dan Ford
email: -- put Cubdriver in subject line!
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old March 30th 04, 11:41 AM
Cub Driver
I can't think of any other reason why a student pilot
would need a transceiver.
Because he will be flying solo?
Old March 30th 04, 05:05 PM
Thomas Borchert
Cub,
That requires a handheld now? Hmm, must have missed that in the regs.
Thomas Borchert (EDDH)
Old March 30th 04, 07:24 PM
Andrew Sarangan
Cub Driver wrote in message . ..
Are you talking about an aircraft which has no radio? In that case you
are correct. Perhaps I misunderstood the original post.
Old March 30th 04, 10:58 PM
Cub Driver
You will find it in the same regulation that requires you to carry a
backup handheld as a certificated pilot, or indeed the regulation that
requires you to have a radio of any kind.
Control K!
Old March 30th 04, 11:36 PM
Malcolm Teas
nospamPlease wrote in message ...
I bought the Yaseu/Vertex VXA-700 (The company changed it's name).
It's got the LiON battery with a nice long battery life, it was the
only handheld with a LiON battery when I bought it roughly a year ago.
It's small enough and light enough that I don't hesitate to carry it
- which is the point in a back up radio.
It receives VOR and COMM frequencies, weather radio in the US, and FM
commercial band as well as VHF 2 meter band. (So, if you're in CAP,
it can get their freqs too.)
I bought it when the DC ADIZ was set up, and used it when on a student
cross country with radio problems. Neither comm would work. Pretty
much a serious situation here. I plugged my headset into the handheld
(with the adapter I'd bought with the radio for that purpose) and was
able to re-enter the ADIZ and get back to home base.
(With the wisdom of more hours now, I should have landed outside and
phoned home. But having the extra radio is a good thing these days in
any case.)
Note that any handheld won't work as effectively as the plane's radio
since the antenna's not as good. Altitude helps of course, as does a
relay. I've seen people with their own plane put in an extra antenna
that can be plugged into the handheld too. But, you need your own
plane first... grin
-Malcolm Teas
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Terrain-Aware Handheld vs. IFR GPS? C Kingsbury Instrument Flight Rules 7 November 14th 04 05:33 AM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Download GPS Track from Bendix/King handheld Andreas Medlhammer General Aviation 0 August 11th 03 02:50 PM
