faith in the fuel delivery infrastructure
Old April 2nd 04, 09:41 PM
John Harlow
"kat" wrote in message
How then would one know if the tanks were filled with the wrong type
of fuel?
checking the fuel receipt is always a good start
Great idea. Sump the fuel, pour it on the possibly incorrect receipt, and
check it
Old April 2nd 04, 10:23 PM
G.R. Patterson III
of fuel?
Most of the fuel receipts I've gotten weren't filled out by the guy on the truck.
Checking them would tell you if the person making out the receipt made a mistake or
if the entire order was messed up, but it won't help if the fuel truck operator
screwed up.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 3rd 04, 01:55 AM
Seth Dillon
Airport fuel farms are a big variable. At any airport with scheduled
service by a 121 carrier you can be pretty sure of the quality of the fuel
and the equipment as the carriers QA Dept. (My job with one of the big 3 US
carriers) will perform scheduled audits of the farm as well as the into
plane delivery system. For the most part, at least in the US, the farms are
held to the ATA Spec 103 standard. The CASE organization has also developed
a standard similiar to 103 and is being accepted by the carriers who are
CASE members. At a smaller airport I would exercise full caution, waiting a
good 15-30 minutes after fueling or aircraft movement to sump the tanks.
For what it is worth 30 minutes min. is the standard at my carrier.
The FAA has no oversight of fuel farms, there are no FARs addressing them
and as they are not "certificated" the FAA has no enforcement power. Any
discrepancy noted in fueling procedures or quality will result in a LOI or
enforcement action against the operator. So when it comes to fuel the
phrase "let the buyer beware" never rrang truer.
Seth
"Chris Hoffmann" wrote in message
"John Harlow" wrote in message
(water). I recently witnessed a situation where the fuel was checked
during preflight, but not after refueling.
How then would one know if the tanks were filled with the wrong type of
fuel?
....Now that's an even better question. Thank you!
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
