#71
guessing you would need quite soft foam, otherwise it wouldn't deform
The foams they use for helmets are pretty hard. They won't deform until you hit a threshhold. You don't want something that will compress under normal loads. Agreed. I imagine you would want something that would deform around (for the sake of argument) 10-20Gs. One's back probably has 10-20x the surface area of one's foot, so my worry is that if you used a foam that was soft enough to protect your back, it would be easy to put your foot or elbow through it. Another idea was putting a big chunk of foam at the front of the aircraft to slow the deacceleration if you hit something frontways. Say you have to We could be talking about a lot of energy. Might require a lot of foam. airframe may break. Perhaps a cubic foot of harder, crushable foam in the nosecone could reduce peak loads on the airframe and spread them more Where in the nose would you put it? Behind the canard - in my dreams. I was thinking of maybe something behind the instrument panel, maybe attached to the firewall. Speaking of fire....I think I have an old bicycle helmet laying around. Maybe I'll put a match to it. Good point. Anyway, I'm sure there's data available on foams currently in use. I have heard that the racing drivers use alu honeycomb. That sounds like it might be seriously expensive. AC |
#72
![]() "anonymous coward" wrote in message news ![]() I imagine you would want something that would deform around (for the sake of argument) 10-20Gs. Hmm....just shooting from the hip, that sounds like good range. one's foot, so my worry is that if you used a foam that was soft enough to protect your back, it would be easy to put your foot or elbow through it. I'd think you'd put a covering of something rigid over it. Maybe a thin layer of glass or maybe just some epoxy to make the top rigid enough to prevent dinging it under normal use. Behind the canard - in my dreams. Maybe the thing to do is mount the seat to something that will give somewhat under crash loads. Might be hard in something like a Long/Vari-EZ, since (I think, working from memory here) that the EZ seat is mounted directly to some major structural members. Would need some additional stuff to isolate the seat with some energy-absorbing stuff that would let it give a bit (probably don't need more than a couple of inches in a crash). I have heard that the racing drivers use alu honeycomb. That sounds like it might be seriously expensive. There's probably a ton of data on stuff that people have tried for driver protection in the automotive world. Unfortunately, air-bags are out of the question for aviation use (for the pilot at least....probably for everyone). But there must be a ton of other stuff. I'd bet that NASA has sponsored a bunch of research under the GA revitalization thingy that would be applicable. Rather than us spend our time speculating here, maybe some Google time is warranted. There is probably someone at NASA Langley that would serve as a point of contact, too. There might even be some technology transfer programs around that we could take advantage of. Not sure how they would react to helping the average joe home-builder, but I'm sure they make a lot of data available to certified manufacturers. Pete |
#73
"Pete Schaefer" wrote in message
news:xMprc.4694$ny.935185@attbi_s53... . . . Unfortunately, air-bags are out of the question for aviation use (for the pilot at least....probably for everyone). Not. See http://www.avweb.com/news/snf2003/184230-1.html - last article, bottom of page. Rich S. |
#74
Air bags are a factory option on some certified planes, including the
Mooney. The bags are built into the seat belts. Frank "Rich S." wrote in message ... "Pete Schaefer" wrote in message news:xMprc.4694$ny.935185@attbi_s53... . . . Unfortunately, air-bags are out of the question for aviation use (for the pilot at least....probably for everyone). Not. See http://www.avweb.com/news/snf2003/184230-1.html - last article, bottom of page. Rich S. |
#76
The Grumman Ag Cat, among others, was designed with a stronger than required
(for mission or for certification) cockpit section/seat/roll-over protection/restraint system. There are numerous examples of crashes that pilots walked away from. BJC wrote in message ... On 19 May 2004 12:03:24 -0700, (Jim-Ed Browne) wrote: I recall that the P-51's designer, Dutch Kindelberger, designed the cockpit area as the toughest structure, so everything else would crumple around the pilot and provide protection from the sudden impact. Is this somehow no longer feasible? You do? References please. I've studied that fighter for years and this is the first I've ever heard of Kindelberger designing the cockpit like a modern car is designed. Thanks, Corky Scott |
#77
On Fri, 21 May 2004 15:41:04 -0500, frank wrote:
Air bags are a factory option on some certified planes, including the Mooney. The bags are built into the seat belts. Frank How are these things controlled? Where is the g-switch that triggers them? Do they need electrical power to run the system? I wonder what sort of electrical failures could cause them to fire when they shouldn't? There have been incidents and accidents where debris in wiring bundles has shorted a live wire to another wire, thus sending voltage where it wasn't meant to go. This could potentially cause one of those air bags to fire when it shouldn't. I wonder if the air bag would push forward on the yoke if it fired in flight? If this happened at low altitude, or a high enough airspeed, could it cause an accident? If so, could installing one of these air bags actually reduce the level of safety? Of is the perception of safety more important than actual safety? Just wondering. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
#78
![]() "Kevin Horton" wrote in message news ![]() On Fri, 21 May 2004 15:41:04 -0500, frank wrote: I wonder if the air bag would push forward on the yoke if it fired in flight? If this happened at low altitude, or a high enough airspeed, could it cause an accident? If so, could installing one of these air bags actually reduce the level of safety? Of is the perception of safety more important than actual safety? There are many "safety" devices, including airbags, safety belts, helmets etc. that can occasionally backfire in a way to cause a death that might otherwise not happen. The important thing is that after all is said and done, the pile of people killed by the device must be much smaller than the pile of people that would otherwise be dead without the device. Vaughn |
#79
![]() "Pete Schaefer" wrote in message news:xMprc.4694$ny.935185@attbi_s53... "anonymous coward" wrote in message news ![]() I imagine you would want something that would deform around (for the sake of argument) 10-20Gs. Hmm....just shooting from the hip, that sounds like good range. one's foot, so my worry is that if you used a foam that was soft enough to protect your back, it would be easy to put your foot or elbow through it. I'd think you'd put a covering of something rigid over it. Maybe a thin layer of glass or maybe just some epoxy to make the top rigid enough to prevent dinging it under normal use. Behind the canard - in my dreams. Maybe the thing to do is mount the seat to something that will give somewhat under crash loads. Might be hard in something like a Long/Vari-EZ, since (I think, working from memory here) that the EZ seat is mounted directly to some major structural members. Would need some additional stuff to isolate the seat with some energy-absorbing stuff that would let it give a bit (probably don't need more than a couple of inches in a crash). I have heard that the racing drivers use alu honeycomb. That sounds like it might be seriously expensive. There's probably a ton of data on stuff that people have tried for driver protection in the automotive world. Unfortunately, air-bags are out of the question for aviation use (for the pilot at least....probably for everyone). But there must be a ton of other stuff. I'd bet that NASA has sponsored a bunch of research under the GA revitalization thingy that would be applicable. Rather than us spend our time speculating here, maybe some Google time is warranted. There is probably someone at NASA Langley that would serve as a point of contact, too. There might even be some technology transfer programs around that we could take advantage of. Not sure how they would react to helping the average joe home-builder, but I'm sure they make a lot of data available to certified manufacturers. Pete It would be interesting to build a seat supported by empty aluminum soda cans. A two-high stack would give a fair amount of deceleration space. Calibrate for the load by the number of cans you use in parallel. My experience crunching them for recycling has been that, undented, they're very consistent in how they crush. A poor man's honeycomb? Tim Ward |
#80
On Fri, 21 May 2004 19:04:45 -0700, "Tim Ward"
wrote: : :It would be interesting to build a seat supported by empty aluminum soda :cans. A two-high stack would give a fair amount of deceleration space. :Calibrate for the load by the number of cans you use in parallel. :My experience crunching them for recycling has been that, undented, they're :very consistent in how they crush. :A poor man's honeycomb? I know one of the missionary flying groups makes seat supports out of columns of rolled up corrugated cardboard - great energy absorbtion. Low density urethane foam works nicely too - crushes and doesn't rebound. When I was in high school in the 70's in physics class we made a 10 mph bumper for a car out of full soda cans - the energy went into the soda spraying sideways. Very messy, but lots of fun. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
