more about that parachuting aircraft
Old April 12th 04, 10:22 AM
Cub Driver
Default more about that parachuting aircraft
This additional slant from the Aero-News email newsletter this
morning:
"Minutes after departure, I started experiencing instrument
failures, one after another. No warning. No smoke. No clues. Just
gauges going out one after another."
As the first gauge failed, Jeff told Center he wanted to turn
back. Center immediately gave him vectors for the return, but
thereafter the perceived succession of failures made the
turn-around seem fairly iffy.
Ippoliti was stunned. Not only were gauges failing, but they
were failing in systems that didn't appear to be related. In a
matter of seconds, just hundreds of feet from the ground and untold
obstacles obscured by IMC, he really didn't know what to trust.
This couldn't be good.
With an unknown number of hazards looming, he informed ATC
that he was clearly in trouble. And after some initial hope of
heading back, the SR22 pilot realized that turning back to the
airport was something he wasn't sure he could do with his gauges
continuing to fail in "rapid succession."
"I told center I couldn't turn back... that I was going to pull
the chute." Jeff then told ANN that one of the few responses he
remembered from that moment on was center responding, "you're going
to pull what?"
From there, Ippoliti's activities were quick and assured. "I'd
thought about this... but I never expected to have to do it." Jeff
pulled the power back, killed the engine and reached up for the BRS
CAPS handle... and pulled.
Despite all his trepidation, Jeff noted that the pull went well,
"No problem with that, it pulled easily."
BANG!
The chute OPENED. Ippoliti then described feeling a
little 'G' as the plane slowed, swung around a bit, and then things
calmed down remarkably fast.
"From there it was almost a non-event. The ELT went off right
away and prevented me from understanding Center because it was so
loud, and the pilot door came off as the chute fired... but the
ride down lasted only seconds as I came down on some trees and
just... stopped."
Ippoliti was alive and had landed in a local park. The aircraft
was not only intact, but surprisingly suffered limited damage... "a
lot less than what might have been," he noted. He doesn't have much
to say about the landing impact, as the trees apparently absorbed
most of the energy, and turned history's third emergency CAPS
landing into a "relative non-event."
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! blog www.vivabush.org
Old April 12th 04, 11:04 AM
Cub Driver
(When I posted the above, I did not realize that this was *yet
another* deployment! I apologize for any confusion I may have caused
when replying to earlier threads where fuel exhaustion, not instrument
failure, was the supposed issue.)
The Warbird's Forum
Old April 12th 04, 04:35 PM
C J Campbell
"Cub Driver" wrote in message
morning:
Interesting, but again I would not trust ANN too much. They have the news
reporting standards of a supermarket tabloid combined with the business
practices of the Sopranos.
However, supposing the instruments failed "one by one" in unrelated systems,
then I am going to risk a guess that the pilot was badly disoriented.
Probably none of his instruments failed.
Old April 13th 04, 01:22 AM
Dan Luke
to pull the chute."
Taking this with a grain of salt because of the source, I wonder if the
pilot might have been over hasty. Why not ask ATC where the nearest VFR
weather was and go there? If he didn't have the fuel to get there, then
ok, pull the 'chute.
Dan
C172RG at BFM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
