Ramp checked at AVP today
Old April 14th 04, 07:48 AM
Roger Halstead
On Tue, 13 Apr 2004 16:15:11 -0700, "PJ Hunt"
I wonder how many pilots know where the port side or the starboard side is?
Why would any one care?
www.rogerhalstead.com
Are we flying airplanes or boats?
PJ
"Cub Driver" wrote in message
That's pretty funny. I wonder how many DEA guys know that the pilot's
side in a J-3 is the port side?
  #62
Old April 14th 04, 11:02 AM
Cub Driver
Well, evidently *I* didn't know, for a mad minute there.
Port and starboard are as useful on planes as on boats. Otherwise you
have to say: on the right, as seen from the pilot's seat, or some such
locution.
PJ
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! blog www.vivabush.org
  #63
Old April 14th 04, 11:04 AM
Cub Driver
On Wed, 14 Apr 2004 06:48:35 GMT, Roger Halstead
Because port remains the same, whereas "left" changes depending on
whether you're inside the plane (and if inside, whether you're facing
fore or aft) or outside propping it, for example.
How many times have you noted that the prop turns left (as seen from
the pilot's seat)? The prop turns to port. (Unless you;re British, of
course
The Warbird's Forum
  #65
Old April 14th 04, 01:12 PM
tony
locution.
otoh - when logging the repair to the left main gear on my airplane
there was no "as seen from the pilot's seat, facing forward" stuff.
All of which is why ATC is likely to say "at your nine o'clock position'.
But it seems to me I've also heard them say "Immediate left turn".
  #66
Old April 14th 04, 02:54 PM
Teacherjh
Well, the top of the prop maybe. The bottom goes the other way.
g,d,r
Jose
(for Email, make the obvious changes in my address)
  #67
Old April 14th 04, 03:30 PM
G.R. Patterson III
Not to me, it doesn't. The left side of the plane is always the same side.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
  #68
Old April 16th 04, 05:39 AM
Dave Buckles
David Brooks wrote:
Easy way to remember. Take the three pairs of words:
left, right
port, starboard
red, green
The shorter words go together, and the longer words go together. You could
probably add:
pilot, passenger (or pilot, instructor)
Alternatively:
"Red" and "Right" both start with the same letter. It would sort of
make sense for them to be the same side. Since we're dealing with the
FAA, we can't have *that* sort of logic running around, so switch 'em.
Ditto with the cruising altitudes: "east" and "even" thousands...same
letter...nah, can't be. Swap 'em.
There are a few more that can be worked out that way, but I don't
remember them offhand. Just remember: if it makes sense, it's probably
*not* done by the FAA.
--Dave
Dave Buckles
http://www.flight-instruction.com
  #69
Old April 16th 04, 06:38 AM
Peter Duniho
"Dave Buckles" wrote in message
news:AsJfc.7906$55.1601@lakeread02...
Alternatively:
The FAA didn't decide on navigation lights. The red light is on the left,
because the vessel (aircraft, in this case) to the right has the right of
way. The red light shows the other vessel, to the left, that they don't
have the right of way.
Not that starting the words with the same letter is in any way a sensible
way to decide things like this anyway. Navigation lights are used on
aircraft all over the world, and probably for every language in which the
color starts with the same letter as the side, there's another language in
which the other color starts with the same letter as the side.
If blaming it on the FAA helps you to remember, I suppose that's fine. Not
all mnemonics are logical, just memorable. But don't make the mistake of
believing that it's actually the FAA's fault.
I'm not sure where the cruising altitudes came from, but again, making
decisions based on coincidences of language seems wrong-headed to me.
Remembering that it's the opposite is a great way to remember which is
which, but blaming the FAA for assigned the altitudes in a way that doesn't
make sense is again illogical.
I guess they aren't actually good mnemonics then, since the point of a
mnemonic is to help you remember something.
IMHO, most things the FAA does DO make sense, once you find out the true
motiviation behind the things that they do. They aren't perfect, but
neither do they deserve the rampant disdain that saying things like "if it
makes sense, it's probably *not* done by the FAA" promotes. Also IMHO, it's
only made worse when a flight instructor says stuff like that. I wonder if
you instill the same disrespect for the FAA in your students. That sort of
thing is what leads to the "anti-authority" attitude.
Pete
  #70
Old April 16th 04, 01:57 PM
Dave Stadt
left, right
port, starboard
red, green
could
probably add:
Alternatively:
"Red", "right", "returning" works. It refers to keeping the red bouys on
the right when returning to a harbor. (simplified explanation) Doesn't do
much good in an airplane but the boat people did use some logic.
I'M GOING TO DIE TODAY. ArtKramr Military Aviation 0 February 4th 04 09:44 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 07:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 07:31 PM
The Yankee Lady Flew Today Tom Huxton Piloting 0 July 11th 03 11:57 PM
