wanted: hangar door tips
Old April 15th 04, 07:29 PM
Musky
Rollers, folders.... all asking for trouble. Why not a garage-door
style door, single piece and folding upward with help from low-tech
springs? That's what we recommend for county hangars. Very low
maintenance, can be automated, and don't flop around in the wind.
My opinion only, of course.
Old April 15th 04, 10:55 PM
Jean-Paul Roy
How can you get a 40 ft garage style door to work properly. Can you imagine
one track holding each end. Wouldn't the midlle colapse when in the up
position?
J.P.
"Musky" wrote in message
Old April 15th 04, 11:24 PM
Musky
http://www.dpindustries.com/onepiece...nterweight.htm
more on doors:
http://www.hangartrader.com/aircraft_hangar_doors.htm
position?
Old April 16th 04, 12:28 AM
Jean-Paul Roy
thank you very much, Very informative.
regards
Jean-Paul
more on doors:
imagine
position?
Old April 16th 04, 02:25 AM
G.R. Patterson III
Cub Driver wrote:
I'm not
sure what would happen in a severe winter--would the bottom track get
frozen up?
Similar doors have frozen up at other airports in New Jersey. Sometimes an aircraft
can be locked in for months.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 16th 04, 05:35 AM
pacplyer
"Jean-Paul Roy" wrote in message m...
position?
J.P.
Mine is a single piece 50 ft "garage-type" steel door with a
residential door and six residential windows in it. It is suspended
on cables and guided by two parabolic curved tubes. Every time
there's an earthquake slight alignment problems delvelop and the side
rollers take huge stresses and snap apart the sides of the building.
The side rollers attract dust and are high mtc. But it allows me to
have windows and a man-door which is nice. But for dependability I'd
have gone with an electric bi-fold if I had to do it over again.
pac
Old April 16th 04, 11:51 AM
Ron Rosenfeld
On 14 Apr 2004 10:17:59 -0700, (Joa) wrote:
Our EAA chapter had a 40' hangar door that split in the middle and
folded sideways (each half). The ends were hinged and the center had
a single roller that ran in a track above. The bottom was not
attached in any way and just hung. It was held closed and open with
large steel pins that dropped into holes in the concrete/asphalt.
The door worked OK but sometimes the bottom would scrape (seasonal)
and be hard to close and the door also "racked" if you pushed it wrong
(it would "rock" back and forth and cause it to open sort of "jumpy").
The trick is that this door was about as inexpensive a design as them
come so I want to use a similar design on a hangar I'm building.
What I'm needing are ideas for making this style of door operate
smoother (not rack) and prevent catching along the bottom with changes
in weather.
Any tips from those of you that have built or used this style of door?
Thanks folks.
J oa
Well, I built a hangar at my home airport about four years ago. I
purchased a kit from a steel company (Miracle Steel or Miracle Truss --
sounds like a hernia aid g) and had it erected by local folk.
It came with an electric bifold door.
In spite of winter ice and snow, the door has never given any trouble
whatsoever. No tracks in the ground to freeze up or buckle. The only time
I couldn't open the door was when the airport had a power failure.
I would do it again.
Old April 16th 04, 05:33 PM
Mike Rapoport
Why couldn't they use salt to melt the ice?
Mike
MU-2
"G.R. Patterson III" wrote in message
Cub Driver wrote:
I'm not
frozen up?
aircraft
George Patterson
to
home
Old April 16th 04, 09:23 PM
Craig
Ron Rosenfeld wrote in message . ..
Biggest problem with a bifold is tail height. For my aircraft, it
makes the door framing a heck of a lot bigger than I really want. For
a tail height of 15' on one of mine, it makes the bifold opening a
minimum of 20' tall. When you couple that with a required span of 60',
it makes for a very expensive door that has to be power operated,
along with some significant structural needs. For my purposes, a
biflod would end up costing nearly as much as the rest of the hangar
itself.
Craig C.
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Instrument Flight Rules 10 April 19th 04 12:37 AM
wanted: hangar door tips Joa Home Built 35 April 18th 04 02:19 PM
wanted: hangar door tips Joa Owning 36 April 18th 04 02:19 PM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Piloting 1 April 6th 04 02:39 PM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Owning 0 April 6th 04 12:58 AM
