#41
![]() "Bill Denton" wrote in message ... Unfortunately, you are buying into exactly the reasons for the Cirrus' poor history. First, the chute is not an option, it is a necessity. When the airplane reaches a particular state or meets a certain set of parameters, your only possible course of action is to deploy the BRS. When you reach a particular state, if you are in an Archer or a 172, you can recover. But if you are in a Cirrus, you absolutely must deploy the BRS; there is no recovery. Second, you made the statement: "THEN we can start discussing when to pull it (the chute)." Unfortunately, it is not a matter that can be discussed. Again, when the airplane reaches a particular state or meets a certain set of parameters, your only possible course of action is to deploy the BRS. There is no room for discussion. Now let me give you an example that is in no way indicative of the operation of the Cirrus. You go out to fly a new airplane. On the panel is a placard reading: "Nose-up angles greater than 30 degrees will render this aircraft uncontrollable and control cannot be regained. The BRS must be deployed immediately or it will not be effective". So, you're flying along and exceed a 30 degree nose-up attitude, and you get a warning horn. A panel scan tells you that you have exceeded the allowed angle. So what do you do? I would leave before anyone has a chance to reach for the start switch. |
#42
![]() Bill Denton wrote: There's really not a problem with the Cirrus, the problem is with pilots who either didn't educate themselves about the airplane, or who think they know more than the people who designed and built the plane. Maybe, but the time-honored solution to that type of problem is to quit building or buying planes like that. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
#43
Unfortunately, if we followed your solution, everyone would still be lying
down on the wing to pilot a fabric-covered canard that needed a rail to take off. Almost every technological advance requires additional training, resulting in an upgrade in skills and mindset. Consider the transition from props to jets. I doubt if many pilots (other than the test pilots) made the transition without additional training. The Cirrus is not necessarily a dangerous airplane; it is a different airplane, that looks a lot like many other GA airplanes. Which it isn't. Too many pilots think they can just skim the POH and go. I read an article last night that indicated that by offering additional training, Cirrus has been able to make major inroads in it's accident problems. Now, the inevitable analogy: When antilock brake systems for automobiles first began achieving widespread market penetration, the number of accidents involving police cars increased dramatically. There were three primary reasons for this: Exposure - Police officers drive a lot, and much of it is stop and go driving. Conditions - Police officers frequently drive at high speeds, which require "hard stops". And they frequently drive on roads in less than optimal conditions (maintenance, weather, etc.). Training - Police officers were trained to "pump" the brakes, a technique that causes ABS to work with even less efficiency than conventional brakes. So, police departments implemented re-training programs that taught the officers both to apply steady pressure to the brake pedal, and helped them break their old pattern of pumping the brakes. The accident rate returned to close to previous levels. And this is analogous to the Cirrus situation. It requires retraining, but given the proper training it's not an especially dangerous aircraft... "G.R. Patterson III" wrote in message ... Bill Denton wrote: There's really not a problem with the Cirrus, the problem is with pilots who either didn't educate themselves about the airplane, or who think they know more than the people who designed and built the plane. Maybe, but the time-honored solution to that type of problem is to quit building or buying planes like that. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
#44
"Bill Denton" wrote
Now, the inevitable analogy: When antilock brake systems for automobiles first began achieving widespread market penetration, the number of accidents involving police cars increased dramatically. There were three primary reasons for this: Exposure - Police officers drive a lot, and much of it is stop and go driving. Conditions - Police officers frequently drive at high speeds, which require "hard stops". And they frequently drive on roads in less than optimal conditions (maintenance, weather, etc.). Training - Police officers were trained to "pump" the brakes, a technique that causes ABS to work with even less efficiency than conventional brakes. So, police departments implemented re-training programs that taught the officers both to apply steady pressure to the brake pedal, and helped them break their old pattern of pumping the brakes. The accident rate returned to close to previous levels. Yes, it's a great analogy. A supposed safety advance was introduced into the cars. After retraining, the result was almost as safe (not safer) as what it replaced, and more expensive to boot. Without retraining, it was a lot more dangerous. What was the advantage again? And this is analogous to the Cirrus situation. It requires retraining, but given the proper training it's not an especially dangerous aircraft... But it's supposed to be a safer aircraft than what we fly. It was supposedly designed for safety. Now we think that maybe with sufficient retraining it won't be especially dangerous. Michael |
#45
![]() " "Bill Denton" wrote And this is analogous to the Cirrus situation. It requires retraining, but given the proper training it's not an especially dangerous aircraft... The Cirrus was touted to be safer than all the other airplanes. Now we find out it is 300% more lethal than the Cessna 182S. |
#47
Greg, if you are the type pilot who relies upon such a system instead
of proper flight planning and judgment to avoid potentially fatal situations, I have no desire to ever fly in an aircraft with you as PIC. Of course these comments may or may not apply to these cases. I am merely raising points to consider and a few of you are going postal misinterpreting my comments. Makes me wonder of you are dealers. Ron Lee Greg Copeland wrote: On Mon, 19 Apr 2004 14:37:27 +0000, Michael Houghton wrote: Howdy! In article , Ron Lee wrote: (Rick Durden) wrote: Ron, It's interesting to read of your anti-safety perspective...the approach that if a pilot errs, he is sentenced to death. Rick, you completely missed my point. I am hardly "anti-safety." I am opposed to potential crutches that allow poor flight decisions to be rectified by "pulling the handle." It is very difficult to reconcile those two sentences, and you fail to do so. You use pejorative terms to describe the use of the safety system for the things it was designed specifically for (and delivered on). You harp on the pilot's culpability. To suggest that any error means death is unsupportable and a gross mischaracterization of reality. We don't know that either of these two events would have been fatal and certainly we do not know that a series of mistakes led to "pulling the handle." Better to concentrate on better decision skills than equipping all GA aircraft with a parachute. You suggest, by your choice of words, that the pilots in both cases had no business pulling the handle -- that their decision making skills were somehow defective. If you are in IMC at low altitude and you have instruments going haywire, you have a situation that can turn deadly in an instant, with no room to recover. You weren't in that airplane. You cannot judge that pilot's choice the way you are. You have no specific knowledge (any more than the rest of us) of what was actually happening. Reread Rick Durden's words about the adoption of parachutes in the military and observe how your words mimic the attude that had to be overcome then. I will be the first to admit that I am not the best pilot. But I will compare my decision making with any other pilot and come out quite well. I'm afraid that your words suggest a different evaluation. You demean the use of safety devices that have been empirically shown to work in the field -- devices that you are not being forced to use. yours, Michael Simply put, which pilot do you want to be? The live one on the ground saying words like, "maybe" or the dead one on the ground with a chute still packed and the last words spoken, "I can recover"? Which crutch would you rather use? A chute or ego? I'd rather be the "maybe" guy myself. Seems Ron would rather be the later. I'm with ya Michael! |
#48
Cap, you may be right but my point remains that there may be
underlying training/judgement issues that if solved will save many more lives than the parachutes ever will. For every possible live saves by a airplane chute, there may be a hundred or more lost because of pilot error. So unless plane parachutes are mandated, the payback is mucho better on fixing the pilot problem. Ron Lee (Captain Wubba) wrote: (Ron Lee) wrote in message ... Greg Copeland wrote: Simply put, which pilot do you want to be? The live one on the ground saying words like, "maybe" or the dead one on the ground with a chute still packed and the last words spoken, "I can recover"? Which crutch would you rather use? A chute or ego? I'd rather be the "maybe" guy myself. Seems Ron would rather be the later. I'm with ya Michael! I would rather be the pilot that does not need a parachute. Will you be going out and buying a Cirrus...or will you continue to fly "less safe" planes without that system? Ron Lee Well, I'd *rather* be the pilot who doesn't have an engine failure. I'd *rather* be the pilot who doesn't have a vacuum failure in nasty hard IMC. I'd *rather* be the pilot who never got a bad vector into a thunderstorm cell. Let me know when you can guarantee that these things won't happen to me (or you), OK? But most of all I'd *rather* be the pilot with one more option to save the lives of my passengers and myself when things go South. That I *can* guarantee...buy flying a plane with a BRS chute. That is all this is - an option. You think a pilot is going to pop a chute on a $200,000 airframe and turn it into nifty piece of non-flying avante-garde artwork because he wants to see what the ride down feels like? This is no more a 'crutch' than GPS is a crutch. Should we go back to four-course radio ranges, because these 'new-fangled' VORs encourage pilots to rely on them, and not maintain the skills that they had 'way back then'? Flying is *all* about risk management. To accomplish virtually anything, one must take certain risks, and smart pilots judge those risks based on the availability of options to deal with the problems they might bring. I know some very good pilots who will not fly single-engine at night in hard IMC. Their call...they understand the risks, and they are the ones putting their butts on the line. That might change now if they can fly a Cirrus, because they would have one more, final option in case things get *really* bad. Would they want to pull the chute? Obviously not...nor would they want a forced landing off field...but they would take *either* if the other choice is a nice headstone with their name on it somewhere. Yes, I'll continue flying Cessnas. But if I have my choice between flying a plane that has a chute and one that doesn't, all else being equal, of *course* I'd choose the plane with the chute. Who wouldn't? Would you go to a restaurant with 5 things on the menu, instead of an identical place that had 20, just because you *might* choose not to eat any of the other choices? There is no doubt the BRS system has saved lives. There is no doubt that it is an added safety feature. It is a great, new tool in the risk-management portfolio of the wise pilot...an option to save lives when all the other options are gone. As such, it is a great benefit to the aviation community, and I can only hope that it becomes increasing common. Cheers, Cap |
#49
Thomas, I see your point. Let's take it to an extreme. I am a pilot
flying a parachute equipped plane. I have to use an airports facilities really, really bad. I see an airport under me. I decide the best way down is to deploy the parachute so that the leather seats are not ruined. The plane is destroyed but it was my call and my call alone that my course of action was right. You have no right to respond negatively to my course of action because only I and I alone was there to assess all the factors involved. However, I will say that I was an idiot. Ron Lee Thomas Borchert wrote: Richard, whether the parachute is the correct option to deal with vacuum failure or even total electrical failure. I don't think that is ever the question. If the pilot in command thinks it is, then it is. I can't believe you're suggesting the speech at the grave containing the words "Ah, but he chose the correct option" - which, in effect, you do. -- Thomas Borchert (EDDH) |
#50
Answer to question 1 is one. A CAPS-like system would not have
helped. He had an engine failure at relatively low altitude and turned back to the airport, hit a utility pole and ultimately died from horrific burns. Pilot error. Ron Lee (Dean Wilkinson) wrote: Hi Ron, A question for you: How many pilots that you knew well on a personal level have died in general aviation accidents? A second question: If your answer is other than zero, what did you say to other people afterwards about the circumstances of their accident? Did you assign any blame to them? Might a CAPS system saved their lives? Your attitude on this subject indicates to me that your answer to question number 1 will be zero, but if not, I would be interested in hearing your answer to question number 2. Dean (Ron Lee) wrote in message ... (Rick Durden) wrote: Ron, It's interesting to read of your anti-safety perspective...the approach that if a pilot errs, he is sentenced to death. Rick, you completely missed my point. I am hardly "anti-safety." I am opposed to potential crutches that allow poor flight decisions to be rectified by "pulling the handle." To suggest that any error means death is unsupportable and a gross mischaracterization of reality. We don't know that either of these two events would have been fatal and certainly we do not know that a series of mistakes led to "pulling the handle." Better to concentrate on better decision skills than equipping all GA aircraft with a parachute. I will be the first to admit that I am not the best pilot. But I will compare my decision making with any other pilot and come out quite well. Ron Lee |
Cirrus SR22 Purchase advice needed. | Dennis | Owning | 170 | May 19th 04 04:44 PM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
