Cirrus SR22 Purchase advice needed.
Old May 5th 04, 04:28 AM
Greg
"Dude" person,
I have really been reluctant to add a post to this thread because I
don't think I have seen so much misinformation in my life, but I feel
an obligation to correct patently false statements which I can refute
from a position of knowledge. I have been flying an SR22 for 2 1/2
years and have been a COPA member for 3 years.
You said that there are problems with the engines needing work at 700
hours. This is absolutely false. If this were happening, it would be
all over the COPA forums and I read them almost everyday. I have not
read the first report of an engine needing major work at 700 hours and
your statement about the interconnection between the prop and throttle
being problematic to the engine is so ridiculous as to be humorous. I
also have a very good relationship with my Service Center and we have
had a lot of conversations about various Cirrus issues, major engine
work at 700 hours has never been mentioned. And shock cooling
problems??!! Huh? I have never had this problem even once.
As far as slowing the plane down, I have never had a problem with THAT
either. I have had to start slowing down a little sooner BECAUSE I
WAS GOING FASTER TO START WITH! I have flown an ILS down to the
middle marker at 120kts (faster than the cruise speed of a 172) and
dropped flaps to land in the normal touchdown zone. It's just not a
problem and I have never wished I had speed brakes. By the way, THAT
is the correct way to spell "speed brakes".
And ANOTHER thing, if anybody thinks they are going to recover from an
inadvertent spin in less than 1,000' in any common four place or six
place airplane without hitting terra firma first, they are living a
fantasy. You just might barely make it if you are well practiced in
spins in the aircraft you are flying and perform spins on a regular
basis and you are at a very light weight. However, it will not happen
like that. It will happen unexpectedly, probably when you are heavy
with an aft CG, while you are doing something else like changing to
departure control frequency. You look up from the radio to see the
world spinning. You have less than five seconds to figure out what
happened and determine the correct control inputs. You must execute
them perfectly, or you die. Depending on the plane, loading, and
pilot proficiency in spin recovery, I would not expect many scenarios
like this to end favorably with less than 2,000' for an average pilot.
Geez, this thread has the worst signal to noise ratio I have seen in a
long time. You know, it started out with just some guy asking for a
little information, I don't think he wanted an earful of crap from
someone with an agenda. Until you fly a Cirrus for more than a
demonstration flight, you would do well to stick to verifiable facts.
Greg
"Dude" wrote in message ...
"Thomas Borchert" wrote in message
Dude,
This could reduce the stalls, at least on approach.
Oh? So how many have stalled on approach again? Right, none.
Yet.
Don't get so frigging defensive. My point is that the Cirrus can be hard to
slow to approach speed. It takes more care than many other planes because
it is slick, and you cannot control the pitch of the prop to add drag. If
you had speed breaks you would allow the pilot more options to control
descent given that right now the system that governs the RPM/MP has limited
ability to slow the plane without cutting the throttle.
Bottom line is that if a person has speed breaks, he is less likely to fly
slow because he can shed speed whenever needed.
It would also reduce
the severe shock cooling they are seeing due to their engine control
system.
So you can prove damage through shock cooling? Wow! I know no one else who
can. And where is the connection to the "engine control system"?
Presently, according to some COPA members, there are many people having
excessive engine wear and needing lots of cylinder work early. One
suspected reason is shock cooling due to pilots cutting throttle to get the
plane down without gaining too much speed. The cirrus design simply adds
more penalty to poor vertical planning than most planes, and so the engine
is often asked to pay the price.
Another theory is that the engines are constanlty being run at set rpm's
that may not be the best rpm's or the smoothest. The pilot cannot control
it.
Bottom line, the phony Fadec system isn't really all that good.
Thomas Borchert (EDDH)
  #102
Old May 5th 04, 10:15 PM
Dude
Greg,
Sorry if I am calling your baby ugly, but...
I get information from lots of different pilots. That means that I may end
up spreading some bad poop, but I am open to being refuted.
The information you are disagreeing with mostly comes from a very
experienced pilot who is a COPA member, but does not own a Cirrus. I have
no reason to suspect his lack of objectivity or that he has an axe to grind.
He is very knowledgeable.
I know someone who recently aquired an SR 22 on brokerage, so perhaps I will
be able to get a better experience with the plane. Cirrus reps do not
demonstrate the plane well enough for people to make a decision, you are
right about that.
My only agenda is safety, and frankly, Cirrus has a poor rating. You can
make excuses all day, but the facts are the facts. They have killed too
many people in too short of time with too few planes. Has Cirrus done good
things for aviation, maybe they have. On the other hand, maybe they are
hurting it with their bad record.
Have you thought to consider the black eye that BRS has over this whole
thing? The anti parachute crowd has lots of ammo now, thanks to Cirrus.
How about the anti composite folks? I think composites are safer, but
thanks to Cirrus, it doesn't necessarily look that way in reality.
Whether anyone can recover from a spin @1000 feet is an interesting
discussion, but you are using it as a straw dog. I don't care what the
answer is, I know that if you take off in a Cirrus, and I take off in almost
any other new single, the odds are in my favor. Enjoy getting there faster,
those few saved minutes may be a large percentage of the rest of your life.
I hope you are paying attention to all your fellow owners who are dying and
being careful.
Lastly, if you want to make a point, correct my facts, spelling, grammer, or
disagree with me, then that is great. I will likely learn from it. On the
other hand, if you want to question my motives or insult me, stay on the
porch. We KNOW as an owner of an SR22 that you have an agenda, but I would
rather take each post at face value rather than prejudging them.
"Greg" wrote in message
om...
"Dude" person,
Greg
Dude,
Yet.
hard to
because
If
limited
fly
system.
who
adds
engine
control
it.
  #103
Old May 6th 04, 12:02 AM
David Megginson
That's a tricky conclusion to draw from so little data. After all, if two
Cirrus planes have a midair, they might double the Cirrus fatal-accident
rate for that year.
The Cirrus is a new design, and any new technology is risky until people
acquire the experience to use it safely (look at the crashes and midair
breakups with the earliest jetliners). Unfortunately, there will have to be
many more crashes before people are able to spot the
statistically-significant patterns (assuming that any exist) and put out
SB's and AD's, design new training methods, etc.
All the best,
David (a Piper owner, with no axe to grind either way)
  #104
Old May 6th 04, 09:09 AM
Thomas Borchert
Dude,
Well, then why have we been having this long, long thread? It ain't that
simple. "The Cirrusses have killed..."??? Come on, you know better. The
statistics may not look too good for the Cirrus at the moment, depending
on how you interpret them. Are those statistics significant already with a
new aircraft? Some doubt it. Are the underlying reasons clear? Not at
all. Do we know it is something to do with the aircraft? Nope. Do we know
it is the kind of pilots/owners that are attracted by this aircraft?
Possibly. Have we seen this before with other conceptually new aircraft?
Yes.
So, your conclusions are a wee bit too simplistic, IMHO.
And statements like that, frankly, tend to drown all the sensible things
you might have to say.
  #105
Old May 6th 04, 04:48 PM
Dude
That would be true, but that would be for ONE year. That is why you need
over a million flight hours before the numbers mean much. Had this sort of
thing been what was driving the numbers it would be obvious wouldn't it.
They have a big enough fleet now, so this argument isn't winning me over
like it did in the beginning.
Also, the training they are doing seems to be helping. However, if you
believe that the numbers are too small to be valuable, then perhaps we don't
know if the training is helping at all do we?
Also, its not the number of fatalaties that worries me as much as the number
of accidents that result in a fatality.
In fact, a valuable number that I have not seen studied would be the ration
of survivors for all souls on board for all accidents. That would tell you
a lot about the crash worthiness of the design. Except for people that
don't believe in statistics.
"David Megginson" wrote in message
news
rate for that year.
be
All the best,
  #106
Old May 6th 04, 04:54 PM
Dude
Dude,
Yes.
Perhaps they are. At what point do we say its relevant, and how long do we
take to see if the trend is improving based on training or other changes.
I think a million hours is a good number, and if there is not significant
improvement by the third set of a million hours then they had best change
the design. That is admittedly a simplistic approach, but I have not seen
anyone set a more scientific objective standard.
Mea Culpa, my only excuse is that he aggravated me.
  #107
Old May 6th 04, 05:31 PM
Fred Wolf
Have any of you actually rad all of the NTSB reports? Most of the accidents
were hair brained, in my opinion, and not a fault of the plane
FW
Dude,
too
a
know
Yes.
we
  #108
Old May 6th 04, 07:16 PM
TripFarmer
Read this article in AVflash.............
http://www.avweb.com/eletter/archive...ll.html#187234
It will tell you more about the bad safety record of the Cirrus.
Trip
n article , says...
Greg,
right about that.
being careful.
. com...
"Dude" person,
Greg
Dude,
Yet.
hard to
because
If
limited
fly
system.
who
adds
engine
control
it.
  #109
Old May 6th 04, 09:47 PM
Teacherjh
Not really, the parachute is sort of separate, even though it's part of the
procedure and the aircraft.
Jose
(for Email, make the obvious changes in my address)
  #110
Old May 6th 04, 10:19 PM
Dude
As is the case with the rest of the fleet. The bottom line is you cannot
really know in most cases what makes up the causes in any real way. The
results are not that tough to interpret though. Fatal accidents per 100,000
hours takes all the subjectivity out of the equation.
"Fred Wolf" wrote in message
accidents
FW
Dude,
too
that
The
depending
with
a
know
aircraft?
Yes.
we
changes.
significant
change
seen
dying
things
Advice and experts with 400 series Cessnas (414 and 421), purchase and training [email protected] Owning 36 January 9th 05 02:32 AM
Air Shares Elite and Cirrus Sr22 Teranews \(Daily\) Owning 4 September 5th 04 05:28 PM
Cirrus SR22 Purchase advice needed. Dennis Owning 170 May 19th 04 04:44 PM
New Cirrus SR22 Lead Time Lenny Sawyer Owning 4 March 6th 04 09:22 AM
Fractional Ownership - Cirrus SR22 Rich Raine Owning 3 December 24th 03 05:36 AM
