Happened today. Winds were kind and I took the chance. The 25 min flight
went fine, took off smoothly and touched down nicely without a bounce inspite of 7kts cross wind. There is some tweaking to be done; radio worked intermittently - lost communications with traffic, but the standby airport rescue crew covered for me; the engine was near top temperature limit at climb; and oil temperature was high - at only 70F outside, maybe I need bigger oil cooler for the Franklin? Any Franklin experts out there? Recommended oil cooler size? ------------------------------------------- Paul Lee, SQ2000 canard www.abri.com/sq2000 |
Paul Lee wrote:
Happened today. Winds were kind and I took the chance. The 25 min flight went fine, took off smoothly and touched down nicely without a bounce inspite of 7kts cross wind. There is some tweaking to be done; radio worked intermittently - lost communications with traffic, but the standby airport rescue crew covered for me; the engine was near top temperature limit at climb; and oil temperature was high - at only 70F outside, maybe I need bigger oil cooler for the Franklin? Any Franklin experts out there? Recommended oil cooler size? ------------------------------------------- Paul Lee, SQ2000 canard www.abri.com/sq2000 Welcome back to Earth, Paul! Od curiousity, what did you build? Richard |
Congratulations Paul !
Let us know how the propeller work when you don some more testing and tweaking. Jan Carlsson www.jcpropellerdesign.com "Paul Lee" skrev i meddelandet m... Happened today. Winds were kind and I took the chance. The 25 min flight went fine, took off smoothly and touched down nicely without a bounce inspite of 7kts cross wind. There is some tweaking to be done; radio worked intermittently - lost communications with traffic, but the standby airport rescue crew covered for me; the engine was near top temperature limit at climb; and oil temperature was high - at only 70F outside, maybe I need bigger oil cooler for the Franklin? Any Franklin experts out there? Recommended oil cooler size? ------------------------------------------- Paul Lee, SQ2000 canard www.abri.com/sq2000 |
Richard Riley wrote:
On Thu, 03 Jun 2004 01:49:41 GMT, Richard Lamb wrote: :Paul Lee wrote: : : ------------------------------------------- : Paul Lee, SQ2000 canard www.abri.com/sq2000 : : :Welcome back to Earth, Paul! : :Od curiousity, what did you build? : : :Richard That would be an SQ2000 canard, Richard... I'm behind the curve on that one, RIchard. Do you have some pics posted somewheres? Richard |
Ron Mirken wrote:
In article , Richard Lamb says... Richard Riley wrote: On Thu, 03 Jun 2004 01:49:41 GMT, Richard Lamb wrote: :Paul Lee wrote: : : ------------------------------------------- : Paul Lee, SQ2000 canard www.abri.com/sq2000 : : :Welcome back to Earth, Paul! : :Od curiousity, what did you build? : : :Richard That would be an SQ2000 canard, Richard... I'm behind the curve on that one, RIchard. Do you have some pics posted somewheres? Richard You might take a look at http://www.abri.com/sq2000/ ![]() Ron O-Tay! Thanks Ron. I didn't recognize the name, but that shape certainly looks familiar... Way to go, Richard Riley! |
"Jan Carlsson" wrote in message ...
Congratulations Paul ! Let us know how the propeller work when you don some more testing and tweaking. Jan Carlsson www.jcpropellerdesign.com Actually it worked fine for the short operating range I used this time. At takeoff it had real good punch (or maybe it was the combo of 220HP engine, electronic ignition...) . And when I reached about 110 kts I had to increase the pitch to keep it from over revving. The adjustment was smooth and short meaning it had plenty of pitch left for higher speeds. I kept the RG down and went no more than 120 kts. BYW the Dynon EFIS-D0 worked well too - agreed with the backup horizon, speed and altitude meters. |
Good to hear it worked well.
I will make a Clarification; Don't get the analyze I made earlyer the wrong way, I am sure there are other props that will be more effective, even an fixed pitch prop can be better at specific design speeds, but the overall performance will gain from the adjustable prop, specially on high performance plane like this beauty, it is all about speed range. Jan Carlsson "Paul Lee" skrev i meddelandet om... "Jan Carlsson" wrote in message ... Congratulations Paul ! Let us know how the propeller work when you don some more testing and tweaking. Jan Carlsson www.jcpropellerdesign.com Actually it worked fine for the short operating range I used this time. At takeoff it had real good punch (or maybe it was the combo of 220HP engine, electronic ignition...) . And when I reached about 110 kts I had to increase the pitch to keep it from over revving. The adjustment was smooth and short meaning it had plenty of pitch left for higher speeds. I kept the RG down and went no more than 120 kts. BYW the Dynon EFIS-D0 worked well too - agreed with the backup horizon, speed and altitude meters. |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 11:20 PM |
| Glasair 1-RG first flight | R&R Sherwood | Home Built | 4 | February 15th 04 02:02 AM |
| Commemorating the 100th Anniversary of Flight (1903-2003) | Snuffy | Home Built | 2 | December 11th 03 02:18 AM |
| ALTRAK pitch system flight report | optics student | Home Built | 2 | September 22nd 03 12:49 AM |
