Rutan hits 200k feet! Almost there!
Old May 16th 04, 03:43 AM
Peter Stickney
Chad Irby writes:
In article .net,
"Steven P. McNicoll" wrote:
"Chad Irby" wrote in message
om...
...for a tiny fraction of the cost, and having the ability to
repeat the feat in less than two weeks (which the government
program didn't manage).
So what's significant about it?
If I have to explain to you the significance of the tech behind a
reusable spaceplane, then why have you even bothered posting to this
thread to begin with?
There ain't a whole lot of tech, there, Chad - Burt's taking a very
low-speed approach, (Rather Grand Fenwickian, in fact) with a low
thrust, long burning rocket motor, and a fairly lightweight, high drag
reentry vehicle. Peak speeds are around Mach 2 on ascent, and
somewhere around Mach 1.9 on the re-entry. There's nothing
particularly exotic about those speeds. Heating is low - around 100
Deg C, and an Aluminum or Composite airframe can deal with those
temperatures and dynamic pressures without a whole lot of trickery.
He's also designed a self-stabilizing shape, (In some ways not too
different from the behavior of a badminton birdie) that doesn't need
sophisticated systems, such as adaptive flight control systems or
reaction controls, to set and hold its attitude. While it's a good
design, it's not significant in advancing technology. It also can't
be expanded much beyond the X-Prize requirements. You aren't going to
see an orbital Spaceship !, or a Semi-Ballistic Spaceship 1 Hypersonic
Transport.
It's a very clever design very highly optimized to do only one thing -
meet teh X-Prize requirements.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
  #154
Old May 16th 04, 04:38 PM
Steven P. McNicoll
.com...
What we have is two "qualifying" flights in July/August, separated by a
month, two hardware failures and a couple of weather failures. So, by
your own admission, they couldn't do it.
Please explain how not doing it proves they couldn't do it.
But, in the actual records, they *couldn't*. Computer overheat,
vulnerability to weather, bad APU... nope, they couldn't manage
it, even with the less-stringent "rules" in effect.
Nonsense. The X-15 achieved turnaround times of less than two weeks and was
flown over 100 km, that proves they could have flown it twice over 100 km
within two weeks if they had chosen to do so.
  #155
Old May 16th 04, 04:40 PM
Steven P. McNicoll
.com...
Every time I've mentioned it so far, you've gotten a sudden case of
amnesia, with a side-dose of "I didn't say that."
**** off.
If you knew of a single statement of mine that was incorrect you'd have
cited it. Your level of credibility has been established.
  #156
Old May 16th 04, 04:42 PM
Steven P. McNicoll
"Keith Willshaw" wrote in message
Because without reaching orbit you cant do anything useful.
Have you followed all of this thread? That's my point.
Thats obvious
Is it? Your message suggested you were not aware of that.
  #157
Old May 16th 04, 04:44 PM
Steven P. McNicoll
"Steve Hix" wrote in message
So much for sounding rockets. Let's shut down Wallops Island
and White Sands...
I don't think the X Prize was offered in order to find a replacement for
sounding rockets.
  #158
Old May 16th 04, 04:57 PM
Jim Weir
Would you mind showing how I attributed that little snippet to Hillary? I made
no attribution at all, and only mentioned Hillary several paragraphs above.
Mary Shafer
- You do it...
- because...
- it is there.
-Wrong guy. George Leigh Mallory said "because it is there", not
-Edmund Hillary.
-Mary
http://www.rst-engr.com
  #159
Old May 16th 04, 05:52 PM
Steven P. McNicoll
"Peter Stickney" wrote in message
The first non-stop flight between North America and the U.K. The
NC-4's final destination was Southampton.
The Daily Mail prize did not require a non-stop flight, but it did require
that any intermediate stoppage be made only on water. The NC-4 didn't
qualify for the Daily mail prize because it stopped at Horta and Lisbon. It
wouldn't have qualified even if it hadn't stopped in the Azores, as the
Daily Mail prize required a flight between any point in the US, Canada, or
Newfoundland and any point in Great Britain or Ireland.
  #160
Old May 16th 04, 06:06 PM
Chad Irby
In article . net,
.com...
"two hardware failures and a couple of weather failures."
I would think that you could read at least that much of the paragraph.
You're reading the failures as "given some luck and a few more tries,
they might have been able to do it," while I read it as "they tried to
do it and failed."
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Rutan hits 200k feet! Almost there! Thomas J. Paladino Jr. Military Aviation 150 May 22nd 04 07:20 PM
Spaceship 1 hits 212,000 feet!!!!!! BlakeleyTB Home Built 10 May 20th 04 10:12 PM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) Peter Stickney Military Aviation 45 February 11th 04 04:46 AM
