In article , Rick
Durden wrote: There is no problem with slips with full flaps on a 172, it's another of aviation's old wives tales. Why does the 1979 C172N have a placard by the flap switch that states, "AVOID SLIPS WITH FLAPS EXTENDED"? |
"EDR" wrote in message
... Why does the 1979 C172N have a placard by the flap switch that states, "AVOID SLIPS WITH FLAPS EXTENDED"? The insightful folks at Cessna were experimenting with trolling USENET. HECTOP PP-ASEL-IA http://www.maxho.com maxho_at_maxho.com |
EDR wrote
Why does the 1979 C172N have a placard by the flap switch that states, "AVOID SLIPS WITH FLAPS EXTENDED"? The following paragraph is copied from the book "Cessna, Wings for the World" written by William D. Thompson, an Engineering Test Pilot and later Manager of Flight Test and Aerodynamics at the Cessna Aircraft Co. I would hope that everyone would copy this to their documents folder and recall it every time that the subject comes up. "With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered a nose down pitch in forward slips with the wing flaps deflected. In some cases it was severe enough to lift the pilot against his seat belt if he was slow in checking the motion. For this reason a caution note was placed in most of the owner's manuals under "Landings" reading "Slips should be avoided with flap settings greater than 30° due to a downward pitch encountered under certain combinations of airspeed, side-slip angle, and center of gravity loadings". Since wing-low drift correction in cross-wind landings is normally performed with a minimum flap setting (for better rudder control) this limitation did not apply to that maneuver. The cause of the pitching motion is the transition of a strong wing downwash over the tail in straight flight to a lessened downwash angle over part of the horizontal tail caused by the influence of a relative "upwash increment" from the upturned aileron in slipping flight. Although not stated in the owner's manuals, we privately encouraged flight instructors to explore these effects at high altitude, and to pass on the information to their students. This phenomenon was elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware of its existence and know how to counter-act it if it occurs close to the ground. When the larger dorsal fin was adopted in the 1972 C-172L, this side- slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher-powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed." Bob Moore |
zatatime wrote in message . ..
On 16 May 2004 02:06:53 GMT, (Teacherjh) wrote: "why do some 172's have 40 degrees of flap avalible and others only have 38?" Dunno about 38, but the newer ones have 30, because full 40 degree flaps were causing problems (which I can't recall) due to poor technique of some sort. Might have something to do with slips with flaps, IIRC. Jose Yep, slips with flaps was part of it, but a nose high attitude with full flaps on go-around is what bit most of the people before they changed to 30. z This month's edition of Flying has a good article by Richard Collins about landings and a lot of the article is devoted to the use (or when appropriate, the non-use) of flaps Blue Skies John |
On Sun, 16 May 2004 15:14:19 GMT, Bob Moore
wrote: EDR wrote Why does the 1979 C172N have a placard by the flap switch that states, "AVOID SLIPS WITH FLAPS EXTENDED"? The following paragraph is copied from the book "Cessna, Wings for the World" written by William D. Thompson, an Engineering Test Pilot and later Manager of Flight Test and Aerodynamics at the Cessna Aircraft Co. I would hope that everyone would copy this to their documents folder and recall it every time that the subject comes up. "With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered a nose down pitch in forward slips with the wing flaps deflected. In some cases it was severe enough to lift the pilot against his seat belt if he was slow in checking the motion. For this reason a caution note was placed in most of the owner's manuals under "Landings" reading "Slips should be avoided with flap settings greater than 30° due to a downward pitch encountered under certain combinations of airspeed, side-slip angle, and center of gravity loadings". Since wing-low drift correction in cross-wind landings is normally performed with a minimum flap setting (for better rudder control) this limitation did not apply to that maneuver. The cause of the pitching motion is the transition of a strong wing downwash over the tail in straight flight to a lessened downwash angle over part of the horizontal tail caused by the influence of a relative "upwash increment" from the upturned aileron in slipping flight. Although not stated in the owner's manuals, we privately encouraged flight instructors to explore these effects at high altitude, and to pass on the information to their students. This phenomenon was elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware of its existence and know how to counter-act it if it occurs close to the ground. When the larger dorsal fin was adopted in the 1972 C-172L, this side- slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher-powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed." Bob Moore Thank you for this information! I've experienced this at high altitude and try to pass along the info to others, but most of the time I receive stubborn feedback like "I've never had a problem so...." Now I can show documentation! One of my biggest pet peeves are CFIs who actually teach people to slip a 172 with flaps. Thanks again. z |
slip a 172 with flaps. Interesting that the only thing you picked up on was that which supported your preconception. |
![]() "zatatime" wrote in message Thank you for this information! .... One of my biggest pet peeves are CFIs who actually teach people to slip a 172 with flaps. ??????? Did you read what Cpt Moore posted? |
Bob,
Yeah, Bill Thompson sometimes got a little sensational to sell his books. sigh The POH for the new 172s deals specifically with the subject. Slips with full flaps can cause some oscillation in the control wheel, but it does not affect control of the aircraft. And that was only in a very significant, controls nearly to the stop, slip. For a normal crosswind landing, it's a non-event. Pilots are more at risk by landing with partial flaps and losing control because they touch down fast than landing with full flaps at a slower touchdown speed. Ah, well, the discussion will continue without resolution forever, while pilots continue to land with partial flaps and lose control of their airplanes on rollout and then are puzzled as to why it happened. All the best, Rick Bob Moore wrote in message .6... EDR wrote Why does the 1979 C172N have a placard by the flap switch that states, "AVOID SLIPS WITH FLAPS EXTENDED"? The following paragraph is copied from the book "Cessna, Wings for the World" written by William D. Thompson, an Engineering Test Pilot and later Manager of Flight Test and Aerodynamics at the Cessna Aircraft Co. I would hope that everyone would copy this to their documents folder and recall it every time that the subject comes up. "With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered a nose down pitch in forward slips with the wing flaps deflected. In some cases it was severe enough to lift the pilot against his seat belt if he was slow in checking the motion. For this reason a caution note was placed in most of the owner's manuals under "Landings" reading "Slips should be avoided with flap settings greater than 30° due to a downward pitch encountered under certain combinations of airspeed, side-slip angle, and center of gravity loadings". Since wing-low drift correction in cross-wind landings is normally performed with a minimum flap setting (for better rudder control) this limitation did not apply to that maneuver. The cause of the pitching motion is the transition of a strong wing downwash over the tail in straight flight to a lessened downwash angle over part of the horizontal tail caused by the influence of a relative "upwash increment" from the upturned aileron in slipping flight. Although not stated in the owner's manuals, we privately encouraged flight instructors to explore these effects at high altitude, and to pass on the information to their students. This phenomenon was elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware of its existence and know how to counter-act it if it occurs close to the ground. When the larger dorsal fin was adopted in the 1972 C-172L, this side- slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher-powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed." Bob Moore |
Hi,
Recently, Rick Durden posted: I'm always amazed at the amount of misinformation running around here. (snip) There is no problem with slips with full flaps on a 172, it's another of aviation's old wives tales. So... I suppose that Cessna was so taken with this "old wive's tale" that they decided to include a warning against it in the POH? ;-) That said, I have slipped 172s with full flaps and lived to tell about it. Neil |
Flap Hinge Moment Calc | Bo | Home Built | 2 | February 2nd 05 10:26 AM |
Flap Hinge Moment Calc | Bo | Home Built | 0 | February 2nd 05 06:01 AM |
TAS vs. flap reflex angle | ELIPPSE | Home Built | 3 | January 13th 05 06:00 AM |
Duluth - Blue Angles this weekend | Montblack | Piloting | 18 | September 23rd 03 03:00 AM |
What should the flap postions be while taking off? | Shi Jin | Military Aviation | 2 | September 10th 03 01:22 AM |
