Buying an L-2
Old May 18th 04, 06:05 PM
Robert M. Gary
Default Buying an L-2
I'm considering by an L-2 that is being offered for sale. I went down
and looked at it the other day and found it to be a nice plane.
However, I have two questions...
1) I've not had a chance to fly it yet. I've heard its a dog. I can
believe it. The gross weight is pretty high, higher than any other 65
hp plane I've seen. However, I find it hard to believe it would be
more of a dog than the Chief of J-3 I used to fly.
2) How do a eveluate the price? There are is no Vref or Bluebook for
this plane. Should I just consider it to be a Champ?
3) With me in the back and my friend up front we'd come out 1/2"
behind he CG range. I assume this is probably a common problem. Are
there cowl weights to move the CG? I'm thinking it shouldn't take much
weight to shift the CG .5".
-Robert, who finds that a Mooney is great for long trips but needs a
second plane for fun flying.
Old May 19th 04, 03:35 AM
Skyking
Rev No. 5 - - - - - -
Reformatted 4/94.
DEPARTMENT OF TRANSPORTATION
FEDERAL AVIATION ADMINISTRATION
A-746
Revision 5
TAYLORCRAFT
(Army L-2, L-2C) DC-65
(Army L-2E) DF-65
(Army L-2D) DL-65
(Army L-2A, -2B, -2M) DCO-65
April 3, 1972
AIRCRAFT SPECIFICATION NO. A-746
Type Certificate Holder: Mr. Robert J. Kuhlow
15740 Fieldbrook Drive
Brookfield, Wisconsin 53005
I - Model DC-65 (Army L-2, L-2C), 2 PCLM Approved 25 November 1941.
(Army L-2 same as DC-65 except for overhead window in cabin.)
Engine Continental A-65-8 (See item 308 for optional engines)
Fuel 73 min. octane aviation gasoline
Engine limits For all operations, 2300 rpm (65 hp)
Airspeed limits Level flight or climb 110 mph ( 96 knot)
(True Ind.) Glide or dive 140 mph (122 knot)
Propeller limits Static r.p.m. at maximum permissible throttle setting:
Not over 2210, not under 2040.
No additional tolerance permitted.
Diameter - not over 72 in.; not under 70 in.
C.G. range (+11.8) to (+19.5)
Empty weight C.G. range (+12.6) to (+16.7)
Maximum weight 1250 lb.
No. seats 2 (+11) and (+40). Placard required: "SOLO FROM FRONT SEAT ONLY."
(See NOTE 3 for swivel type seats).
Maximum baggage 20 lb. (+60)
Fuel capacity 14 gal. total (2 gal. fuselage tank (-18) and two 6 gal. wing
tanks (+23))
Oil capacity 4 qt. (-38)
Control surface movements Elevator 28° Up 28° Down
Elevator trim tab 41° Up 41° Down
Aileron 28° Up 21° Down
Rudder 25° Right 25° Left
Serial Nos. eligible 4002 and up and all AAF No. Use mfg. no. if available.
Required equipment Items 101, 102, 103, 104 and 105
A-746 Page 2
II - Model DF-65 (Army L-2E), 2 PCLM Approved 25 November 1941.
(Same as DC-65 except for engine installation)
Engine Franklin 4AC-176-B2 (See Item 308 for optional engines)
Engine limits For all operations, 2200 rpm (65 hp)
(1) With 4AC-176-B2 engine - not over 2170
not under 2050
(2) With 4AC-176-BA2 engine - not over 2315
not under 2150.
Empty weight C.G. range (+12.9) to (+16.8)
If empty weight C.G. falls within this range, it is unnecessary to check
critical forward and aft C.G. positions. Range is not valid for
non-standard arrangements.)
tanks (+23))
Oil capacity 5 qt. (-45)
4001
eligible at 1200 lb. maximum weight.
III - Model DL-65), 2 PCLM Approved 25 November 1941.
Engine Lycoming O-145-B2 (See Item 308 for optional engines)
Engine limits For all operations, 2550 rpm (65 hp)
Airspeed limits Level flight or climb 110 mph ( 96 knots)
(True Ind.) Glide or dive 140 mph (122 knots)
A-746 Page 3
Not over 2315, not under 2100.
Diameter - not over 70 in.; not under 68 in.
critical
forward and aft C.G. positions. Range is not valid for non-standard
arrangements.
tanks (+23))
IV - Model DCO-65 (Army L-2A, L-2B AND L-2M), 2 PCLM Approved 24 February
1942
(Same as DC-65 except for rear view transparent cabin enclosure, revised
cockpit arrangement, and revised
fuselage, and landing gear structure. Army L-2M is same as model DCO-65
except for revised rear
transparent enclosure, revised instrument panel, revised 6 gal. wing tank,
closed cowl, revised engine
installation, spoiler installation, and operating limits as noted below
Engine Continental A-65-8.
Airspeed limits Level flight or climb 110 m.p.h. ( 96 knot)
(True Ind.) Glide or dive 140 m.p.h. (122 knot)
Spoilers extended (L-2M) 90 m.p.h. ( 78 knot)
(DCO-65, L-2A, L-2B) Not over 2350, not under 2000.
(L-2M) not over 2325, not under 2135.
Center of gravity (DCO-65, L-2A, L-2B) (+12.3) to (+19.3)
(C.G.) range (L-2M) (+12.3) to (+17.56)
A-746 Page 4
Empty weight C.G. range (DCO-65, L-2A, L-2B) (+13.2) to (+17.1)
(L-2M) (+13.2) to (+15.3)
critical forward and aft C.G. positions. Ranges are not valid for
Maximum weight (DCO-65, L-2A, L-23) 1300 lb.
(L-2M) 1325 lb.
No. of seats 2 (+11) and (+37). Placard required: "SOLO FROM FRONT SEAT."
(See NOTE 3 for swivel type rear seats).
Maximum baggage (DCO-65, L-2A, L-2B) 20 lb. (+59)
(L-2M) None.
tanks (+23));
(L-2M) (+24)
Spoilers (L-2M) 50° Up 0° Left
Serial Nos. eligible (DCO-65, L-2A, L-2B) 4002 and up and all AAF No. Use
Mfg. No. if available.
(L-2M) 5166 and up
Required equipment (DCO-65, L-2A, L-2B) Items 101, 102, 103, 104 and 105
(L-2M) Items 101, 102, 302 (e) and 304.
Specifications Pertinent to all Models
Datum Leading edge of wing
Leveling means 3/8 in. above top of stabilizer L.E. and top of stabilizer
rear beam at fuselage.
Certification basis Type Certificate No. 746 (CAR 4a)
Production basis None. Prior to original certification a CAA representative
must perform a detailed
inspection for workmanship, materials, and conformity with the approved
technical
data, and a check of the flight characteristics.
Export eligibility Eligible for export to all countries subject to the
provisions of Advisory Circular 21-2.
Equipment: A plus (+) or minus (-) sign preceding the weight of an item
indicates net weight change
when that item is installed.
Propeller and Propeller Accessories
1. Propeller - Hartzell ground adjustable, hub HA-12U, blades 7414 to 6814
or 7214 to 6814M. 18 lb. (-58)
Eligible at diameter and static r.p.m. limits shown above for fixed pitch
wood propellers.
2. Propeller - McCauley Model 1A90 with following limits: 21 lb. (-58)
Not over 2250, not under 2070
Diameter: Not over 74 in., not under 72.5 in.
(Eligible on DCO-65 model only.)
101. Propeller - wood (fixed or adjustable pitch) 11 lb. (-58)
A-746 Page 5
Engines and Engine Accessories - Fuel and Oil System
No aircraft of these models shall be eligible for original certification
with single ignition engines after August 1, 1941. In
addition, no aircraft of these models shall be eligible for recertification
with single ignition engines unless such aircraft were
either previously certificated with single ignition engines or were
originally certificated prior to August 1, 1941.
102. Carburetor air heater 1 lb. (-51)
105. Muffler (No. D-A624) 6 lb. (-36)
106. Carburetor air intake & filter (Continental A-5810) (MODELS DCO-65 &
DC-65 only) 3 lb. (-49)
107. Carburetor air scoop & filter (Skinner Purifiers, Inc. model S-300A
scoop & F-300A filter) 3 lb. (-47)
(Model DCO-65 (L-2 Series) only) (Filter must be installed on airscoop at
all times.)
108. AC air filter 1529265 (Aircooled Motors Dwg. SK-534-4) (Model DF-65
only) 1 lb. (-41)
308. Engines
A. Model DC-65 (Continental - Per Engine Specification No. 205)
(1) A-65-7 -11 lb. (-34)
(2) A-65-9 +3 lb. (-34)
B. Model DL-65 (Lycoming - Per Engine Specification No. 210)
(1) 0-145-B1 -11 lb. (-45)
C. Model DF-65 (Franklin - Per Engine Specification No. 221)
(1) 4AC-176-BA2 Neglect weight increase
Engine limits - For all operations, 2300 r.p.m. (65 hp)
110. Oil Filter, Fram PB-5, Weight includes 1 quart of oil 4 lb. (-30)
(a) (DC-65 and DCO-65)
Kit No. 510, Fram Installation Drawing No. 61544
(b) (DL-65) Kit No. 520, Fram Installation Drawing 61550
(c) (DF-65) Kit No. 501, Fram Installation Drawing 61564
Landing Gear and Floats
103. 6.00-6 wheels (Shinn 6C4) with 6.00-6 2-ply tires 22 lb. (+0)
104. Tailskid - Spring 5 lb. (+190)
302. Tail wheel (+198)
(a) Omitted
(b) 6x2.00 steerable (Aircraft Associates) +3 lb.
(c) 6x2.00 full swiveling (Taylorcraft) +3 lb.
(d) 6x2.00 steerable (Lake State Products 5-40-31) +4 lb.
(e) 6x2.00 steerable (Taylorcraft) +4 lb.
(f) 6x2.00 steerable (Scott Model TA-8B) +4 lb.
303. Parking brake 3 lb. (-13)
304. 6.00-6 wheels (Shinn 6C4HB) with brakes +6 lb. (0)
307. 6.00-6 4-ply tires Neglect with increase
A-746 Page 6
313. Skis (Eligible on any airplane of these models provided the propeller
installation meets the
minimum 9 in. ground clearance. The maximum weight for the skiplane will be
the same
as for the corresponding landplane of that shown in parenthesis after each
ski model,
whichever is less) Use actual weight change
(a) Federal SC-1 (Maximum 1400 lb.)
b) Heath 725 or 725A (Maximum 1450 lb.)
c) Air Transport 1224-580-1 (Maximum 1220 lb.)
d) Jacobsen (formerly Escanaba) EAS-100 (Maximum 1200 lb.)
e) Federal A-1500 (Max. 1500 lb.) Federal Installation Dwg. 11R232
f) Federal A-1500A (Max. 1500 lb.) Federal Installation Dwg. 11R232
g) Federal A-1850 (Max. 1850 lb.) Federal Installation Dwg. 11R232
h) Federal A-2000 (Max. 2000 lb.) Federal Installation Dwg. 11R232
i) Federal A-2000A (Max. 2000 lb.) Federal Installation Dwg. 11R232
j) Federal CA1850-6 (Max. 1850 lb.) Federal Installation Dwg. 11R232
Electrical Equipment
301. Position lights (Grimes B) 2 lb. (+24)
305. Battery
(a) 6 volt Willard SYR-7-3 (10 A.H.) with box 9 lb. (-30)
(b) 6 volt Reading 333LD (33 A.H.) 14 lb. (-25)
(c) 12 volt Willard SYR-7-6 (10 A.M) with box 16 lb. (-25)
(d) 6 volt Reading 324L (24 A.H.) with box 12 lb. (-24)
311. Generator, wind driven
(a) 6 volt General Armature Co. 10 lb. (0)
(b) 12 volt Lear No. 1030-A 10 lb. (+5)
(c) 6 volt Champion Model W612-6V with rotor brake 10 lb. (+1)
(d) 6 volt Champion Model W612B 9 lb. (0)
Interior Equipment
306. Cabin heater Neglect weight increase
309. Taylorcraft compass (Carwell) 2 lb.
401. (a) Cabin heater (Surface Combustion Inc. 5 lb. (-37)
Model AAV-15N-12 fuel burning heater)
(b) Duct for above heater installation 2 lb. (+20)
402. (a) Cabin heater (Stewart Warner Model No. 24809) 10 lb. (-32)
(b) Duct for above heater installation 2 lb. (+5)
NOTES
NOTE 1. Current weight and balance report including list of equipment
included in certificated weight empty, and loading
instructions when necessary, must be in each aircraft at the time of
original certification and at all times thereafter
(except in the case of air carrier operators having an approved weight
control system).
NOTE 2. Placard required, "SOLO FROM FRONT SEAT ONLY."
NOTE 3. The swivel type rear seats with folding backs on all Taylorcraft L-2
series aircraft must be permanently fastened so
that there is no possibility of interference with the rear control stick.
The back should be bolted or welded in place
and the seat should be permanently locked in the forward facing position.
A-746 Page 7
NOTE 4. The following parts from TG-6 gliders can be used directly on
Taylorcraft D series aircraft. The replacement of
such complete component parts is considered a minor repair in accordance
with Cam 18.3006:
1. Tail surfaces except the fin.
2. Landing gear tires and wheels
3. Tail wheels.
4. Wings. Wings with the spoiler installation should be used only on the
model Army L-2M. The spoiler
installation should be removed and a suitable covering placed over the upper
surface opening on wings for
use in other Model D series airplanes.
5. Certain parts and assemblies of the control system from (and including)
the middle occupant aft.
6. Wing struts.
7. Instruments, same as or equivalent to those used on powered aircraft.
The fuselage primary structure of the TG-6 glider aft of the firewall
station can be used on Taylorcraft D series
airplanes; however, the use of such parts entails a major repair and must be
handled as such in accordance with
CAM 18.
om...
It depends on what you consider a Dog, most any 65 HP airplane isn't going
to blaze through the sky. The 11AC
Chief has 1250# gross and the L-3 is 1260.
The L-2 has the T-Craft airfoil so it may not get off the ground a quick.
I think that it would be a fun machine.
What kind of shape were the engines in?
No, it's not a Champ but it qualifies as a Warbird.
The price will be what the seller will accept and
what the buyer is willing to pay. No Bluebook
can determine the value of a Classic.
Have you tried Atkins?
Gook Luck,
Skyking
Old May 20th 04, 05:23 AM
EDR
Are the spoilers wired closed?
Old May 20th 04, 08:04 AM
Robert M. Gary
Carl Ellis wrote in message .97.136...
(Robert M. Gary) wrote in
om:
Robert -
If you are looking at a Taylorcraft L-2 then you need to check out the
Taylorcraft sites. There is lots of help out there. Where are you
located?
vb.taylorcraft.com
www.taylorcraft.info
www.taylorcraft.com
The L-2 is nice airplane but it is heavy compared to a BC-12.
- Carl -
I have checked them out. There is some information, but not much on
the L-2. The main problem is a lack of information about what L-2s are
selling for. Its hard to evaluate the price of something when you
don't have previous sales to look at.
-Robert
Old May 20th 04, 03:55 PM
Carl Ellis
om:
.97.136...
om:
down and looked at it the other day and found it to be a nice
plane. However, I have two questions...
65 hp plane I've seen. However, I find it hard to believe it would
be more of a dog than the Chief of J-3 I used to fly.
for this plane. Should I just consider it to be a Champ?
much weight to shift the CG .5".
a second plane for fun flying.
Robert -
the Taylorcraft sites. There is lots of help out there. Where are
you located?
vb.taylorcraft.com
www.taylorcraft.com
- Carl -
-Robert
Join the forum and make a post asking this very question. We are a very
friendly bunch with some very knowledgeable members so I would be very
suprised if you don't get a useful response. Several L-2 in the group
have sold in the last six months so the data is out there.
- Carl -
Old May 20th 04, 06:40 PM
Robert M. Gary
How does it fly? Is it more of a dog than the J-3? I know the J-3 is
lighter but its certainly not short field or fast plane (lots of stuff
hanging from it). (I'm not looking to buy a J-3, I'm just looking for
a compare)
-Robert
Old May 22nd 04, 11:15 PM
EDR
They can be a real bitch to get in and out of.
Old May 23rd 04, 01:28 AM
Carl Ellis
EDR wrote in :
Worse than a Cub?
- Carl -
Tips on buying a cessna 182 Matteucci Aviation Marketplace 4 September 15th 04 09:42 AM
"Why Raptor? The Logic of Buying the World's Best Fighter" Mike Military Aviation 0 August 11th 04 04:20 PM
Advice on buying a 152? rajek Owning 27 June 21st 04 09:09 PM
Information on buying an aircraft Marco L Piloting 6 August 20th 03 09:58 AM
Buying my first plane Gilles Leblanc Piloting 7 July 29th 03 06:21 AM
