Speaking of Gasoline
Old May 18th 04, 07:20 PM
TO THE GROUP
Default Speaking of Gasoline
There is an interesting thread going on in
rec.crafts.metalworking concerning the quality of gasoline
and how it pertains to small engines such as weedwackers etc.
I've quoted an interesting comment made by just one individual this
past hour for your information and comments as to how this might
effect other types of engines such as aircraft engines.
The subject line is OT Garden Equipment Manufactures Say
Don't Use gas Over 30 Days Old???
And here is one quoted comment........
Dropped in to 2 repair shops this morning and asked them
about gas problems.
Both of them told me the same thing, refineries are removing
some of the additives that makes gas last a reasonable time
in storage. Customer complaints about poor starting etc.
are driving them crazy.
I still say we are paying more and getting sub standard gas
from our refineries and the leaning out the fuel supply to
these newer machines is shortening the life expectancy of
all the gas driven equipment we are buying.
Anybody here starting to hear comments from their FBO
on old gasoline in airplanes.
Old May 18th 04, 09:51 PM
Michelle P
They may be able to do this to Auto Gas but if they change the
formulation on AvGas they need to get it re-certified.
Michelle
about gas problems.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old May 18th 04, 11:10 PM
Dylan Smith
It's nothing new - it's well known that mogas goes 'bad' after a
relatively short period of time (and it may be pretty random whether it
goes bad or not, depending on who it came from I suppose) and this has
happened for as long as I can remember.
Avgas on the other hand always keeps well.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old May 18th 04, 11:19 PM
Jay Honeck
Ah, yet another reason to fly often!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 19th 04, 12:00 AM
Bob Noel
In article uZvqc.22771$qA.2534609@attbi_s51, "Jay Honeck"
Does anyone need another reason?
Bob Noel
Old May 19th 04, 12:15 AM
Jim Wilson
about gas problems.
30 days may be okay, but auto gas starts getting pretty gummy after 6
weeks or so. Always use a stabilizing product (such as STA-BIL) in
your gasoline (and carburetor) when you store your small engines for a
lengthy time.
On the other hand, aviation gasoline has different properties and stays
fine for extended periods of time. The biggest risk from storing av
gas for long periods is water and/or rust from tanks.
Old May 19th 04, 04:05 PM
MikeM
I have a boat and pickup which remain parked for up to 9mo a
year. I always keep them full of gas. NO problems due to
"stale" gas.
The reason that I dont have problems with my boat, truck and airplanes is
that they have large, sealed tanks. Gas goes stale when stored in small
(1-3gal) vented tanks. The volatile aromatic hydrocarbons evavorate, leaving
behind stuff that doesnt vaporize well. In large tanks, the ratio of
volume to surface area is larger, and if the tank is not vented, the
aromatics stay in the tank (vapor pressure reaches an equilibrium).
In a small vented tank, the aromatics just leak away, leaving behind
the "stale" stuff...
Stabil will keep the gallon or two in the mower/snowblower/generator from
going bad...
MikeM
Old May 20th 04, 01:40 AM
Newps
"MikeM" wrote in message
Those are all vented, although depending on the year the newer cars vent
into that coffee can looking container under the hood. A small portable
tank is only vented when you open the vent to pour out the gas. Close that
vent and it is airtight.
Old May 20th 04, 02:09 AM
Judah
Bob Noel wrote in
it goes bad or not, depending on who it came from I suppose) and
this has happened for as long as I can remember.
It's not a question of needs...
Old May 21st 04, 12:33 AM
mikem
I was referring to the small tank on my lawnmower, which has a
vent in the gas cap. It will "go bad" in the 8 months that it
sits unused. If I drain it completly, or pour a few oz of
Stabil in it, then it will run ok the next spring...
MikeM
FS : two Augusta gasoline engines John Bartley Home Built 7 June 7th 04 07:27 AM
FS : two Augusta gasoline engines John Bartley Aviation Marketplace 0 June 5th 04 12:10 PM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
sealing cork float against gasoline - how to... jt Home Built 13 July 18th 03 10:51 PM
